K59 Half-Track Suspension Upgrade
keenan
Indiana, United States
KitMaker: 5,272 posts
Armorama: 2,844 posts
Posted: Monday, February 25, 2008 - 10:39 AM UTC
Gary Kato reviews K59's M2/M3 Half-Track Suspension Upgrade Set for Dragon's 1/35 M2/M3 Half-Track kits.
CDK
KitMaker: 358 posts
Armorama: 339 posts
Posted: Monday, February 25, 2008 - 02:00 PM UTC
Nice review Gary. I agree about the point you make regarding the question of whether or not this set is necessary.
While the drain holes in the suspension basement arms are nice, like you said, they're easy enough to scratch build. The 3-D effect of the springs is nice as well, but they are called DUAL idler springs for a good reason, why not cast the inner spring as well ? there was more than just a rod in there ! The rib detail on the sprockets is very nice and in my opinion, it's the sets strongest point, almost making it worth while to me . . . . almost. The exhaust bracket is OK, but like the drain holes, easy enough to make.
To top it off, they produce this set to replace the Dragon kit parts and still forget to put the rivets on the bogie arms. I don't see a picture in this review, but just looking at this kit on Perth for example shows the outer surface of the bogie arms which are clearly missing this detail.
Whats the point of making a set to correct things for all the rivet counters and forget the rivets in the process?
I'll detail the kit parts myself .
c5flies
KitMaker: 3,684 posts
Armorama: 2,938 posts
Posted: Monday, February 25, 2008 - 06:47 PM UTC
Great review, Gary. I agree with you and Lamont, fairly easy fixes without this set.
GaryKato
KitMaker: 3,694 posts
Armorama: 2,693 posts
Posted: Tuesday, February 26, 2008 - 01:36 AM UTC
Thanks for the support, guys. I was a bit nervous about writing that.
