| Subject: Grass Tufts Homemade |
 | Fred Rick Boucher JPTRR
Associate Editor
|  | Location: Indiana, United States Member Since: December 21, 2002
Posts: 1,957 entire network,
436 this site
| Posted: Friday, October 24, 2008 - 05:55 AM UTC |
Hi All, An alternative to Silfor, etc. This site is in German so you may need a translator. Making Grass Tufts |
"You don't need an airport where there aren't any people."
If they demand your loyalty, give them integrity; if they demand integrity, give them your loyalty.--Col John Boyd, USAF
We are given one mouth and two ears--to listen more than we speak. | |  |
| HIDE SIGNATURE AREAS |
 | Alan alanmac | Location: England - South West, United Kingdom Member Since: February 25, 2007
Posts: 1,677 entire network,
1,629 this site
| Posted: Friday, October 24, 2008 - 06:07 AM UTC |
Hi Fred
I think this has already been featured but I'm not sure if on this site. I've certainly read it in English without using a translation program.He put spots of glue down, and then he connected two leads from his dismantled static charge equipment and connected it to the metal tray (not ali' it doesn't work, must be steel) and it attracted the static grass to those glue spots, once dry slice off and stick in your scene if I remember correctly.
Alan |
| Another one for the album Gromit | | |
 | Claude Joachim roudeleiw |  | Location: Luxembourg Member Since: January 19, 2004
Posts: 1,301 entire network,
1,130 this site
| Posted: Friday, October 24, 2008 - 10:12 PM UTC |
Alan, i just read it in german and you are spot on. It is written what you just explained. Cheers Claude |
 | Scott Lodder slodder
Managing Editor
|  | Location: North Carolina, United States Member Since: February 22, 2002
Posts: 11,129 entire network,
6,702 this site
| Posted: Friday, October 24, 2008 - 11:16 PM UTC |
I have to say this is the most logical straight forward approach to static grass. The charge is the hardest thing to 'get'. Most people try to put the grass on a diorama then apply static, or charge it as they apply it. This way is one of the most effective looking clumps I've seen.
Now the big question - what is the charging equipment? |
Scott
Managing Editor - ModelGeek.com | |  |
1,629 this site
| Posted: Saturday, October 25, 2008 - 12:45 AM UTC |
Hi Scott I'm not sure what he used to produce the static charge. Sounds like he used one of the commercially available hand held units you use for "normal" static grass application, dismantled it and used it with relevant leads connected to the tray. That's my "guessimate" of what he described, I could be wrong. Having said that aren't the units quite expensive to buy, so ripping one apart sounds like a job not for the faint hearted, or if safety is a worry if it's mains connected  240 volts in the UK is a potential killer !! Alan |
1,130 this site
| Posted: Saturday, October 25, 2008 - 07:06 AM UTC |
Here is a building manuel for a home made electrostatic charger. It is also in english.
http://atw.huebsch.at/Elektronik/Elektrostat.htm
This is an item needed by Railroad modellers and on those sites there should be more infos if needed
Cheers Claude |
 | Aleksandar Pocuc elcrni | Location: Novi Sad, Serbia & Montenegro Member Since: December 05, 2008
Posts: 4 entire network,
2 this site
| Posted: Monday, December 08, 2008 - 06:10 AM UTC |
Hi Guys, No need for complicated equipment but just a few things from electronic supply store and about half an hour of work and you have a perfect tool for static grass. I just made one myself for under US$20
Link to "how to" http://www.009.cd2.com/flyswat2.htm
And a link to demo of what it can do: http://www.youtube.com/watch?v=OYSAK1ezou4
In this case you would need to put the alligator clip on the metal plate.
Cheers, A |
 | bbailey_33 | Location: Florida, United States Member Since: May 10, 2005
Posts: 47 entire network,
11 this site
| Posted: Tuesday, December 09, 2008 - 03:51 AM UTC |
how about the end of a magnet and some painted metal shavings? |
 | Harold Minkwitz hminky | Location: Delaware, United States Member Since: March 04, 2008
3 this site
| Posted: Monday, October 26, 2009 - 02:18 PM UTC |
I make the same thing with faux fur: Have a web article from my train days at: http://www.pacificcoastairlinerr.com/grass_clumps/ Harold |
