Reverse Post Order
REPLY
NEW TOPIC
ADD PHOTOS
SUBSCRIBE
For all military ground-force modelling subjects.
Subject: M-10 Wolverine and M-36 Jackson Upgrade
Fabio Morrone Moretti
CALLSIGN: FabioMoretti
Posts: 145 entire network, 114 this site
Visit this CommunityLance Corporal
PROFILE
PHOTOS
MESSAGE
HIDE USER DETAILS
REPLY
REPLY & QUOTE
Posted: Sunday, November 30, 2008 - 11:53 PM UTC
Hi friends, one more upgrade series post. This time two old Tamiya kits:
1:35 M-10 and 1:35 M-36, Both assembled circa of ī92.
This is a polemic kits, because they don't have a defined scale, some modellers say is 1:32 and other say donīt have a defined scale
Because of this unusual characteristics, they kits are to be exposed alone, therefore will not be displayed in vignettes or dioramas. Will be featured on individual bases.
. JACKSON M36 B2:
The idea is to get this model assembled in 92 and making some small modifications and additions to make more "presentable". Today the look of it is more of a toy than a kit.
We have already identified the main points that should undergo these changes / additions, but would like the participation of all that will accompany the post.
The model chosen is this, that was in action at Korea War:
. WOLVERINE M-10
This M-10 also suffer changes / additions. The model chosen is this, in action at Anzio:
The post will be developed in agreement of my availability of time, maybe a little slower, but always forward.
I plan to initially make a comparison between models and real, pointing to flaws found in the model and then making the fix them and over time, adjusting the model kit I want to represent.
I hope you enjoy it...
Fabio M. Moretti
REPLY
REPLY & QUOTE
HIDE SIGNATURE AREAS
PROFILE
PHOTOS
MESSAGE
HIDE USER DETAILS
REPLY
REPLY & QUOTE
Posted: Tuesday, December 02, 2008 - 01:10 AM UTC
Wolverine M-10
Analysis of the hull:
The kit has some inconsistencies to be corrected, considering that it uses the same hull of the M-36 Jackson, many changes / corrections will be the same for both:
1.The tools are merged in the hull, so it should be removed with sandpaper. New tools will be glued in these places.
2. The fixing bolts of side shield panels and front side of the hull are not satisfactory, the relief is too low and not out as they should, they should be removed with sandpaper, and new bolts will be molded and glued in these place.
3. Some voids should be removed with sandpaper and Putty, all accessories glued in the hull and the tower will be removed and is permanently excluded or replaced elsewhere so correct.
4. At the front a kind of support should be installed
Analysis of the turret, and gun mantelet:
Here too exist some inconsistencies that will be corrected:
1. The counterweight should be removed, corrected and replaced
2. Some imperfections will be corrected.
3. The rings (for the hooks) on the side of the turret, should be removed and pasted with the slope in accordance with the real
4. A hole and a cap should be made on the right side of the gun mantlet.
Underside:
1. Every holes will be closed
Wheels, suspension and rear:
1. Only the pintle hook should be removed and glued in the right way, the rest is ok if compared to the references.
The rest apparently is Ok.
REPLY
REPLY & QUOTE
Roy Chow
CALLSIGN: ericadeane
Posts: 2,347 entire network, 2,297 this site
Visit this CommunityMajor General
PROFILE
PHOTOS
MESSAGE
HIDE USER DETAILS
REPLY
REPLY & QUOTE
Posted: Tuesday, December 02, 2008 - 01:59 AM UTC
Your project is admirable but why not get an Academy or AFV Club kit instead?
Here are MAJOR things on the old Tamiya kits that you can't fix:
1) the tracks are completely inaccurate -- note the end connectors that don't join the treads
2) tools to be replaced -- will you find 1/35 replacements?
3) note the poor bolt strip at the top of the transmission cover.
I think you'll find making accurate the Academy or AFV Club kits to be less burdensome. For me, I find that if I run into too many challenges, I lose motivation and abandon the project. These Tamiya kits were designed over thirty years ago
REPLY
REPLY & QUOTE
Roy Chow
1st VP AMPS
www.amps-armor.org
PROFILE
PHOTOS
MESSAGE
HIDE USER DETAILS
REPLY
REPLY & QUOTE
Posted: Tuesday, December 02, 2008 - 04:50 AM UTC
Hi Roy,
I agree with you but I like to live dangerously
The questions # 2 and 3, I think that I fix it, but I don't understand the question #1.
What did you mean?
Fabio
REPLY
REPLY & QUOTE
Mike Taylor
CALLSIGN: modelguy2
This user has contributed written articles for Armorama in the past year.Location: Ohio, United States
Posts: 650 entire network, 189 this site
PROFILE
PHOTOS
MESSAGE
WWW
HIDE USER DETAILS
REPLY
REPLY & QUOTE
Posted: Tuesday, December 02, 2008 - 05:03 AM UTC
Hi Fabio,
"1) the tracks are completely inaccurate -- note the end connectors that don't join the treads"
The track end connectors are centered at the end of each link instead of being between 2 links. The tracks are held together with majic .
REPLY
REPLY & QUOTE
PROFILE
PHOTOS
MESSAGE
HIDE USER DETAILS
REPLY
REPLY & QUOTE
Posted: Tuesday, December 02, 2008 - 08:33 AM UTC
Okay, now I understand...well new tracks will solve the problem..
REPLY
REPLY & QUOTE
PROFILE
PHOTOS
MESSAGE
HIDE USER DETAILS
REPLY
REPLY & QUOTE
Posted: Tuesday, December 02, 2008 - 11:06 PM UTC
I think I found a solution to it well, at next weekend Iīll know
REPLY
REPLY & QUOTE
PROFILE
PHOTOS
MESSAGE
HIDE USER DETAILS
REPLY
REPLY & QUOTE
Posted: Tuesday, December 09, 2008 - 05:31 AM UTC
I Removed the tracks and identified some parts that should be closed with plasticard. In the case of the exhausts, thatīs OK, but the hull may become a serious problem because of small space to handle the plasticard in this area.
What I thought would be the easiest (removal of accessories) has proved an inconvenience, when I tried to remove them from plastic pieces of kit were torn, becausing the turret armor plates would be like a swiss cheese.
The removal of the counterweight was also difficult and demanded his price
Only the hull wasn’t much affected
Well I had to remove the sides of the turret and I scratch them with plasticard ...
Fortunately the internal mobile parts of the cannon were not affected, well upgrade is this and It will get worse.
REPLY
REPLY & QUOTE
PROFILE
PHOTOS
MESSAGE
HIDE USER DETAILS
REPLY
REPLY & QUOTE
Posted: Wednesday, December 10, 2008 - 01:45 AM UTC
Here the mold for the side armor plates to be cut from a piece of plasticard (ordinary old credit card)
The side armor plates glued with Araldite (bi-component glue)
Them I made the back armor plates and glued.
Now, Iīll waiting to begin with much putty and sandpaper
Don’t forget, that until now I only fixing the [auto-censored] that I done when I removed the turret accessories, in theory this was a job that I don’t had.
REPLY
REPLY & QUOTE
PROFILE
PHOTOS
MESSAGE
HIDE USER DETAILS
REPLY
REPLY & QUOTE
Posted: Monday, December 22, 2008 - 12:53 AM UTC
Well, continuation of M-10 upgrade, I made the side armor plates with a plasticard thinnest and glued on the side.
I applied putty on the turret, cannon and hull
Now I’m sanding and preparing the bottom of the hull which should be properly closed with plasticard. This part is very difficult because I don’t have access inside the kit, my next challenge.
Fabio M. Moretti
REPLY
REPLY & QUOTE
ADVERTISEMENTS
PROFILE
PHOTOS
MESSAGE
HIDE USER DETAILS
REPLY
REPLY & QUOTE
Posted: Monday, January 05, 2009 - 12:54 AM UTC
Continuing the upgrade, I sanded the side and frontal armor plates for remove the fixing bolts.
I opened vains in counterweights and and prepared the lower side of them.
I made the “box” of Thompsonīs magazines.
I glued the eight bolts of turret armor plates.
The next step will be pasting the box of Thopmpsonīs magazines in his place, making the tip of the bolts for fixing the turret armor plates and gluing the counter-weights.
Fabio M. Moretti
REPLY
REPLY & QUOTE
Ant Wilkes
CALLSIGN: padawan_82
Posts: 482 entire network, 362 this site
Visit this CommunityPetty Officer First Class
PROFILE
PHOTOS
MESSAGE
HIDE USER DETAILS
REPLY
REPLY & QUOTE
Posted: Tuesday, January 13, 2009 - 01:22 PM UTC
looking good so far fabio... i'm currently updating tamiya's original tiger... now that's a challenge... lots of oversized part's details missing i'll try to post some pic's once my home pc is fixed. good luck with your build mate i'll be watching this one with interest.
REPLY
REPLY & QUOTE
IMMORTALITY! take it it's yours - Achilles siege of Troy.
PROFILE
PHOTOS
MESSAGE
HIDE USER DETAILS
REPLY
REPLY & QUOTE
Posted: Saturday, February 28, 2009 - 02:35 PM UTC
Thank you Padawan_82...I hope you enjoy it.
More pictures....
More pics next weekend...
Cheers...
REPLY
REPLY & QUOTE
Ant Wilkes
PROFILE
PHOTOS
MESSAGE
HIDE USER DETAILS
REPLY
REPLY & QUOTE
Posted: Saturday, February 28, 2009 - 03:41 PM UTC
blown away Fabio i'm speechless the work you've done is nothing short of extraordinary i can see that you'll have no problem with the rest of the upgrading keep going mate can't wait to see this one finished. Ant
REPLY
REPLY & QUOTE
Tim Kelly
CALLSIGN: tjkelly
Posts: 1,122 entire network, 1,114 this site
Visit this CommunityColonel
PROFILE
PHOTOS
MESSAGE
HIDE USER DETAILS
REPLY
REPLY & QUOTE
Posted: Saturday, February 28, 2009 - 08:23 PM UTC
An interesting build you've got there Fabio! Lot's of work completed so far, looking good!
Thanks for sharing. Keep at it! Cheers -
Tim
REPLY
REPLY & QUOTE
Current projects:
Tamiya Vought F4U-1D Corsair
AFV 8.8cm Flak 18 (35088)
Next up:
TBD...
PROFILE
PHOTOS
MESSAGE
HIDE USER DETAILS
REPLY
REPLY & QUOTE
Posted: Friday, September 25, 2009 - 12:18 PM UTC
Well friendīs after a long...long...time...more pics
The pré-shading
Second layer (more thin)
The brazilian silly putty isnīt good...itīs like a "The bubble"
Camo marks with a pencil
Oh my god! Itīs very liquid..
Next:
- Finish paint job
- tracks
- Weathering and washes
- detail paint
- decaling
- accessories
Next weekend....
Fabio M. Moretti
REPLY
REPLY & QUOTE
PROFILE
PHOTOS
MESSAGE
HIDE USER DETAILS
REPLY
REPLY & QUOTE
Posted: Tuesday, October 06, 2009 - 12:30 PM UTC
Interior color
Rear white stripes
One of the best tools that I have...the Olfa compass
I cut p some chunks of wheels rubber
REPLY
REPLY & QUOTE
juan
CALLSIGN: juanocana
Posts: 39 entire network, 36 this site
Visit this Community2nd Lieutenant
PROFILE
PHOTOS
MESSAGE
HIDE USER DETAILS
REPLY
REPLY & QUOTE
Posted: Tuesday, October 06, 2009 - 03:01 PM UTC
hey fabio your work looks great congratulaions man keep it up!!!
i do really like the cmaou on your m10!!
cheers
REPLY
REPLY & QUOTE
"No man was never honored for what he did. Honor has been the reward for what he gave"
Bradley J
CALLSIGN: HONEYCUT
Posts: 3,605 entire network, 2,671 this site
Visit this CommunityCommand Sergeant Major
PROFILE
PHOTOS
MESSAGE
HIDE USER DETAILS
REPLY
REPLY & QUOTE
Posted: Tuesday, October 06, 2009 - 11:49 PM UTC
Fantastic recovery skills Fabio! I missed the original postings. You have some decent scratchbuilding skills mate. One thing you did miss however is the need for the 3 bolts placed along the underside of each bogey housing. A common Tamiya fault!
It looks great after the camouflage.
Brad
REPLY
REPLY & QUOTE
"There never was a good war, or a bad peace."
Benjamin Franklin
Joseph M. Callan
CALLSIGN: Splinty2001
Posts: 218 entire network, 125 this site
Visit this CommunityCorporal
PROFILE
PHOTOS
MESSAGE
HIDE USER DETAILS
REPLY
REPLY & QUOTE
Posted: Wednesday, October 07, 2009 - 12:43 AM UTC
Wow, you sure picked a tough project! Looks really good, I wish I had scratching skills like that. Can't wait to see more.
REPLY
REPLY & QUOTE
Volens Et Potens! Cottonbalers, Dco. 4/7 INF 3rd Inf Div-
Operation Desert Storm
Voice of Command: Aco 234 SIG BN- Operation Iraqi Freedom '03-'04
Wolverines! 46 MP CO-Operation Iraqi Freedom '06-'07
ADVERTISEMENTS
PROFILE
PHOTOS
MESSAGE
HIDE USER DETAILS
REPLY
REPLY & QUOTE
Posted: Sunday, October 25, 2009 - 01:45 AM UTC
Hi friends, some pictures and some troubles that I had to solve...
did a reassessment of the project and discovered some flaws
1st. How to apply the decals? Should have thought of that before but...now I fix it
First option, apply under the accessories, like this example
But I thought it would be cool that way, then I decided to remove the accessories that are disturbing and leave the space for the decals.
It all started when I found this profile ...
That is exactly the same vehicle that I'm trying to represent, but viewer of the other side.
Comparing both
I noticed that one of the profiles is different from the other, mainly fixing accessories racks.
The racks I decided to leave the way it is, but I had to remove some accessories...
2nd. Nuts and bolts.
3rd I forgot to put this in the vehicle
REPLY
REPLY & QUOTE
PROFILE
PHOTOS
MESSAGE
HIDE USER DETAILS
REPLY
REPLY & QUOTE
Posted: Sunday, October 25, 2009 - 01:48 AM UTC
The Rework...
After, more putty, and waiting to sand and painting.
The front side support
Nuts and bolts..
REPLY
REPLY & QUOTE
PROFILE
PHOTOS
MESSAGE
HIDE USER DETAILS
REPLY
REPLY & QUOTE
Posted: Sunday, October 25, 2009 - 02:00 AM UTC
Well the bomber running...
Apply decals (FCM) with Microset e Microsol.
On the back after I have done I made some modifications, I took two supporters that had the original model and added bolts, this caused more sanding and repainting this part of the M-10
Before...
After....
The interior almost ready.
And the tracks, already to 2nd part of the painting job.
I hope you enjoy it, next the final....
Thank you and cheers...
Fabio M. Moretti
REPLY
REPLY & QUOTE
Jeff Larkin
CALLSIGN: beachbm2
Posts: 222 entire network, 131 this site
Visit this CommunityCaptain
PROFILE
PHOTOS
MESSAGE
HIDE USER DETAILS
REPLY
REPLY & QUOTE
Posted: Sunday, October 25, 2009 - 04:08 AM UTC
All I can say is WOW!!!! You actually made a Silk Purse out of a Sows ear!!!! Fantastic Job !!!
REPLY
REPLY & QUOTE
PROFILE
PHOTOS
MESSAGE
HIDE USER DETAILS
REPLY
REPLY & QUOTE
Posted: Sunday, October 25, 2009 - 10:44 PM UTC
Thank you Ant, Tim, Juan, Bradley, Joseph and Jeff..
Fabio M. Moretti
REPLY
REPLY & QUOTE
PROFILE
PHOTOS
MESSAGE
HIDE USER DETAILS
REPLY
REPLY & QUOTE
Posted: Monday, November 02, 2009 - 03:53 AM UTC
This is the M-10 with a Judea betumen wash,
some overall rust
and the drybrush...
The next way...accessories, chalk powder and mud...
See you later friends...cheers
REPLY
REPLY & QUOTE
PROFILE
PHOTOS
MESSAGE
HIDE USER DETAILS
REPLY
REPLY & QUOTE
Posted: Monday, November 02, 2009 - 12:22 PM UTC
The chalks...
Next week more.....
Bye,,cheers
REPLY
REPLY & QUOTE
Reverse Post Order
REPLY
NEW TOPIC
ADD PHOTOS
SUBSCRIBE
TOP
REPLY
 ACTIONS LATEST POSTS FORUM FAQ ADD PHOTOS
Advertise Here!
