| Subject: Help on Crusader Mk. III |
 | Ralph Emerson M. Dabao shonen_red | Location: Metro Manila, Philippines Member Since: February 20, 2003
Posts: 5,748 entire network,
2,271 this site
| Posted: Saturday, October 10, 2009 - 09:55 PM UTC |
I just picked up a 1/35 Revell Crusader Mk III (which I learned to be a re-box of Italeri). I haven't actually started on the kit but from the looks of it, the tracks are awful. I was thinking of a replacement, but I'm not sure which tracks to chose from? I'm not sure if Bronco or some other manufacturers out there had it in plastic, but spending on Fruils is I think a bit much  Suggestions? Any fault on this kit that needs careful attention? Thanks! |
--==Shonen Red==--
-=Filipino Modeler=-
| HIDE SIGNATURE AREAS |
 | Matan metooshelah |  | Location: Jerusalem, Israel Member Since: February 06, 2009
Posts: 335 entire network,
285 this site
| Posted: Saturday, October 10, 2009 - 11:35 PM UTC |
Removed by original poster on 10/11/09 - 12:58:03 (MST). |
George: "If we do happen to step on a mine, Sir, what do we do ?"
Blackadder: "Normal procedure, Lieutenant, is to jump 200 feet in the air and scatter oneself over a wide area."
On the bench: Sherman M4
 | Aidrian Bridgeman-Sutton Mad_Dan_Eccles | Member Since: July 30, 2007
Posts: 38 entire network,
32 this site
| Posted: Sunday, October 11, 2009 - 03:29 PM UTC |
The rubber band on mine aren't that bad - certainly I have seen many that are worse -, but the plastic seems ungluable and doesn't like paint much.
The A13 tracks from Bronco seem to represent an earlier pattern and while they have some similarities, aren't quite right for a Crusader. Accurate Arnour do or did a set of resin Crusader tracks, and while I haven't used this particular set, the one set I have used was good compromise between the fidelity of individual links and the relative ease of rubber bands |
2,271 this site
| Posted: Monday, October 12, 2009 - 03:03 AM UTC |
So I guess Fruils it is. Oh boy... Thanks for the help Edit: Does anybody remember the link on how to make Fruils? If this pushes through, this would be the first kit of mine that'll be receving a Fruil treatment |
--==Shonen Red==--
 | José Silva clay_cliff | Location: Lima, Peru Member Since: April 07, 2008
Posts: 179 entire network,
177 this site
| Posted: Monday, October 12, 2009 - 11:53 AM UTC |
I think there was a set of plastic tracks from Gum Ka (You can find the review in PMMS), but they might be difficult to find by now, so the Friul tracks are your best option. I think Italeri/Revell's Crusader tanks are very nice. I have the Mk.I Early, from Italeri. It has some time around but still nice and the only Crusader Mk.I Early out there. IMO, a PE set wuill be enough for your Mk.III (If there is any available). The only think I know to be added to all of them is some missing bolt heads on the hull sides, something totally useless is you are going to place the sideskirts in place. I don't know about any other improvements, there are very few publications about the Crusader, and nothing with very detailed pics or drawings, AFAIK. Good luck. Best regards.
José. |
2,271 this site
| Posted: Monday, October 12, 2009 - 03:05 PM UTC |
Thanks! I'm actually opting to buy Eduard's Crusader III PE set plus maybe a Jordi Rubio metal barrel aside from the Fruils I've mentioned a while ago. BTW, Eduard is selling Crusader side skirts but I'm not sure if it can be used for the Mk. III version? From the diagrams it resemble much of the same skirts for the Mk. III but Eduard labeled it for the Mk. II. Looks can be deceiving I guess. |
--==Shonen Red==--
177 this site
| Posted: Monday, October 12, 2009 - 06:00 PM UTC |
If they are the full-length side skirts, then they should be the same, not like the early half-length side skirts, they're slightly different for a very early Mk.I, compared to a late Mk.I or Mk.II, I'd say just go for them (full-length side skirts). BTW, I forgot about about the gun barrel. Jordi Rubio's barrel is a good choice. best regards.
José. |
2,271 this site
| Posted: Monday, October 12, 2009 - 08:09 PM UTC |
José.
It's this one: link |
--==Shonen Red==--
