| Subject: Oto Melara Centauro versions |
 | Samuel Facchin Samuca | Location: Rio Grande do Sul, Brazil Member Since: February 22, 2004
Posts: 28 entire network,
23 this site
| Posted: Thursday, October 15, 2009 - 01:17 AM UTC |
S! I'm wondering what are the differences between the two Centauro versions depicted by Trumpeter kits (386 and the future release, 387). The future release, Centauro AFV 3rd serieshttp://www.trumpeter-china.com/war513/products/en_message.asp?id=749  The first Centauro released by Trumpeter, Italian B1 Centauro Tank Destroyer http://www.trumpeter-china.com/war513/products/en_message.asp?id=659 |
"Battles are won by slaughter and maneuver. The greater the general, the more he contributes in maneuver, the less he demands in slaughter"
Sir Winston Churchill (1874-1965) | | |
| HIDE SIGNATURE AREAS |
 | Roy Kinsella RKinsella | Location: Dublin, Ireland Member Since: September 29, 2007
Posts: 199 entire network,
194 this site
| Posted: Thursday, October 15, 2009 - 03:53 AM UTC |
whatever the difference between the two, I imagine the additional parts are that small that they could of been packaged together instead of selling two seperate kits! ..but thats buisness talk I guess |
| "problems cannot be solved by the same level of thinking that created them" | | |
 | Olivier Carneau bison126 |  | Location: Oise, France Member Since: June 10, 2004
Posts: 1,803 entire network,
1,694 this site
| Posted: Thursday, October 15, 2009 - 05:11 AM UTC |
The so-called 3rd series should be the long hull version. So for once Roy, this is not only a business trick |
Visit my site Click the banner
"La reine des batailles, j'ai nomme l'infanterie"
Napoleon | |  |
 | Alejandro kurassier | Location: Gibraltar Member Since: September 06, 2009
Posts: 14 entire network,
13 this site
| Posted: Thursday, October 15, 2009 - 05:28 AM UTC |
Long hull version, meaning what differences with the Spanish Centauro VCR 105? Any side views to see them? Thanks!!! |
23 this site
| Posted: Thursday, October 15, 2009 - 05:31 AM UTC |
S! That's what I wanna know too. The difference between short and long hull. |
 | Carmen Manning csmanning |  | Location: Alberta, Canada Member Since: March 23, 2008
Posts: 153 entire network,
152 this site
| Posted: Thursday, October 15, 2009 - 05:41 AM UTC |
The major differences between the 2nd series and the 3rd series is a short hull and long hull. I'll look through my reference pictures tonight and see if I have some good pictures which show the hull extension. Otherwise - Blue Steel publishing has a great photo refernce book on the Italian Centauros that were deployed in Lebanon called "White Thunder". In it they describe and show the differences. http://www.blue-steel.info/WT-sample-Cover.html As for the Spanish Centauro... I'm pretty sure, but don't quote me on it.. they they received all 3rd series Centauros. I'll try and confirm that tonight when I'm home. |
| "It's not the size of the dog in the fight ... but rather the size of the fight in the dog" - Don Cherry - Hockey Night in Canada | | |
152 this site
| Posted: Thursday, October 15, 2009 - 05:50 AM UTC |
http://trumpeter.cool.ne.jp/gallary3/TY-centauro.html Compare the rear picture of this VRC-105 build to that of the series 2 Centauro box art and you'll see the differences. The rear of the long hull version (3rd series) is squared and boxed out on either side of the rear door compared to the series 2 Centauro. |
 | stephane HERVE stephane |  | Location: Hauts-de-Seine, France Member Since: October 10, 2005
Posts: 62 entire network,
61 this site
| Posted: Thursday, October 15, 2009 - 06:03 AM UTC |
For those who are interresting by Italians Centauro,from memory the long version could be build as KFOR version or Iraq one and the short version as IFOR/SFOR versions with rear hull add on armor (but you'll have to scratchbuild the armor). |
1,694 this site
| Posted: Thursday, October 15, 2009 - 06:08 AM UTC |
Spanish Centauro Italian long hull They are the same. According to the Auriga book, the differences between Italian and Spanish are few as follows : on the Spanish version there are additional armor plate bolted to the turret, some additional brackets for ammo boxes have been fitted ot the turret, the smoke dischargers are of the Wegmann type instead of the Galix one, an additional protection is fitted to the bow belly and various brackets have moved. Olivier |
Napoleon | |  |
23 this site
| Posted: Thursday, October 15, 2009 - 06:11 AM UTC |
S! Hum, I see The short hull version has a full sloped rear hull meanwhile the "long" hull has only the rear door sloped, while the rear "wall" is vertical. Did I am too far from the true? |
 | Dan Hay PiperDan |  | Location: Ontario, Canada Member Since: January 02, 2004
Posts: 156 entire network,
131 this site
| Posted: Thursday, October 15, 2009 - 08:22 AM UTC |
The length of the hull on the series 3 vehicles is longer only by virtue of the battery boxes on either side of the rear door. The batteries were moved from inside (Series 1 and 2 vehicles had the batteries in the rear of the hull) to make room for optional seating for 4 infantry types. It should be noted that the 4 seats could only be fitted by removing the 105mm ammo bins normally occupying much of the rear compartment. So, the 'long hull' vehicle has those battery box bulges on the back while the series 1 and 2 do not. It's worth pointing out that the Trumpeter early Centauro represents a series 2 vehicle. I hope this helps. Cheers - Dan |
Dan Hay
Isn't it interesting that the same people who laugh at science fiction listen to weather forecasts and economists?
-- Kelvin Throop III
23 this site
| Posted: Thursday, October 15, 2009 - 11:14 AM UTC |
S! Olivier, Carmen, Herve and Dan thank you very much. I just had a real class about the Centauro. Abusing yours patiance, what are the colors for the Italian versions? I wanna buy the paints in the same order. Again, thank you. |
13 this site
| Posted: Friday, October 16, 2009 - 01:38 AM UTC |
Maybe I´m a bit dumb, so be patient, but to clarify this : the spanish Trumpeter Centauro is the "long" version? I understood that it is, but want to be sure Thanx again!!!! |
1,694 this site
| Posted: Friday, October 16, 2009 - 02:25 AM UTC |
As the saying tells it : it's better looking dumb 5 minutes by asking aquestion than being it your life long by keeping it unanswered All the Spanish Centauros are long hull ones. |
Napoleon | |  |
13 this site
| Posted: Friday, October 16, 2009 - 02:32 AM UTC |
Completely agree.... Thanks a lot Oliver!!!! |
194 this site
| Posted: Friday, October 16, 2009 - 07:15 AM UTC |
I learn something new everyday on this site, thanks Olivier |
 | Richard Smith casailor | Member Since: June 22, 2007
Posts: 36 entire network,
18 this site
| Posted: Friday, October 16, 2009 - 07:28 AM UTC |
as my drill instructor in the US Arny told me "the only dumb question is the one you don't ask". This advice has served me well in life. |
