| Subject: Input on IWATA Revolution CR |
 | Bill Gormley BillGorm | Location: New Jersey, United States Member Since: November 02, 2009
Posts: 18 entire network,
7 this site
| Posted: Monday, November 02, 2009 - 04:33 AM UTC |
I tried to post this earlier, but could only see a small portion of the text. Question is / was about an IWATA Revolution CR as a first airbrush: 1) Is it a reasonable first choice for an airbrush (budget < $125) and 2) What other brushes would you consider in that price range? I'm looking at the Paasche Talon, Premi-Air G35, and IWATA Eclipse HP-CS. Thanks. |
| HIDE SIGNATURE AREAS |
7 this site
| Posted: Monday, November 02, 2009 - 05:17 AM UTC |
Just to add to my original post - what about the MIG Productions airbrushes? I don't hear much about them and they seem to be very reasonably priced. |
 | Mike Land Kelley |  | Location: Georgia, United States Member Since: November 21, 2002
Posts: 1,709 entire network,
1,416 this site
| Posted: Monday, November 02, 2009 - 10:15 AM UTC |
Bill, I have a Revolution CR which as I use as my general purpose AB and I would highly recommend it. It can be used for larger coverage and it's not bad for some detail work. It's easy to use, and clean and also very solidly built. The only thing I would buy to go with it would be a pre-set handle, that just makes it easier to use if you're trying to do a camo scheme or some detail work. I can't comment on the other brushes you listed except to say I have two Iwata AB's and love 'em both, you can't go wrong with them! Oh, and for some of the best prices around check out: http://www.dixieart.com/ (I'm not affiliated, just a happy customer!) Best, Mike |
7 this site
| Posted: Tuesday, November 03, 2009 - 02:41 AM UTC |
Mike - Thanks for the input. Sounds like you find the Revolution CR less than ideal for detail work. I guess that's the trade-off of buying the CR rather than a more expensive airbrush? Also, the pre-set you suggest ... I assume that's a non-standard part I need to specify when I purchase the brush? |
 | Neil Page FalkeEins | Location: England - South East, United Kingdom Member Since: March 07, 2005
Posts: 545 entire network,
40 this site
| Posted: Tuesday, November 03, 2009 - 03:01 AM UTC |
 | Matan metooshelah |  | Location: Jerusalem, Israel Member Since: February 06, 2009
Posts: 337 entire network,
287 this site
| Posted: Tuesday, November 03, 2009 - 05:22 AM UTC |
I have the HP-CS and I'm very satisfied with it. Good for over-all spray, and can produce very fine lines for detailing. Mind you, you will need to learn to control the trigger for that. I believe that iwata has a brush with a screw that lets you adjust how far the needle goes (and thus, how fine will you spray). If I'm not mistaken, it's the hp-c brush |
George: "If we do happen to step on a mine, Sir, what do we do ?"
Blackadder: "Normal procedure, Lieutenant, is to jump 200 feet in the air and scatter oneself over a wide area."
On the bench: Sherman M4
 | Jim McIntosh JimMrr | Location: Ontario, Canada Member Since: January 03, 2007
Posts: 1,084 entire network,
331 this site
| Posted: Tuesday, November 03, 2009 - 07:45 AM UTC |
Ive got the revolution and the Hi line ...I squeezed some very fine lines and finishes out of my revolution ...but I must say the Hi line is MUCH more fun to work with ..and probably your best bang for buck out of Iwata in my opinion..(and a freind who is a salesman of Iwata brushes..) |
Projects:
HMCS Snowberry,and Trillium
Supermarine Stranraer
Gorland Missle ship
