T-44 with PT-34 mine roller build
kruppw
KitMaker: 1,117 posts
Armorama: 1,115 posts
Posted: Wednesday, June 27, 2012 - 04:42 PM UTC
Here is the newest project I’m looking at starting. I just got this kit in the mail a few days ago and I have to say it’s a pretty nice kit. It’s only the second kit I have ever gotten from Accurate Armour. The first one was a Staghound AA and the kit was so bad I could not even build the kit without a lot of work. I’m guessing the T-44 kit is based on the older Esci kit since most of the lower hull details match up with my VT-55 kit. My knowledge of this particular tank is limited, so I’m going to do the best I can with it and make some minor improvements along the way.
For this build I will be using
AFV Club T-34 500mm tracks
Legend Production T-54 spider wheels
Zvezda PT-34 mine roller from their T-34 kit
CMK 85mm barrel
Jurjen
Groningen, Netherlands
KitMaker: 3,040 posts
Armorama: 1,016 posts
Posted: Wednesday, June 27, 2012 - 07:44 PM UTC
Interesting subject! You have my attention
Spiderfrommars
Milano, Italy
KitMaker: 3,845 posts
Armorama: 3,543 posts
Posted: Wednesday, June 27, 2012 - 07:47 PM UTC
Yes, a quite rare subject. I have some reference pics about and I was thinking to scratch build one starting from an old T-55 lower hull and a T-34/85 turret.
I'll follow this thread for sure, I know you'll make a great job, as usual
here some reference
http://pro-tank.ru/bronetehnika-sssr/srednie-tanki/111-t-44
http://photo.qip.ru/users/pakuro/4070139/
http://groll.ru/wehr/t-44.html
http://hobbyport.ru/armor/t_44.htm
cheers
tanknick22
KitMaker: 1,139 posts
Armorama: 1,100 posts
Posted: Wednesday, June 27, 2012 - 10:39 PM UTC
sorry to tell you this no one had ever made a plastic kit of the t-44 the esci kit you are refering to was a t55 not the t44
kruppw
Posted: Thursday, June 28, 2012 - 02:50 AM UTC
Thanks guys, should be fun for me since I also play WOT and one the tanks I had to grind through to get the T-54.
Nick I know that no made a plastic T-44 kit, I was referring to the kit being based on the older esci T-55 kit. Did not clearify in my posting
Thanks Mauro for the references, I got most of what I have from a russian site. Most of the details I've seen on the tank are pretty basic and what comes in the kit are not too bad to begin with.
Chris
TheGreatPumpkin
KitMaker: 690 posts
Armorama: 672 posts
Posted: Thursday, June 28, 2012 - 05:04 AM UTC
Chris,
I built this baby a couple of years ago. I had lots of fun with it. Try to pick up an Esci T-54/55 kit for the detail parts and an Eduard PE set for the Trumpeter T-55's (the kit needs lots of help and therefore has lots in the set). I used DML Spider-web wheels from one of their T-34's and used the DML track. You hull looks good, mine had a warp that needed a bunch of putty to fill on the nose. Otherwise, good luck! I'll be watching this one with interest!
Georg
Jacques
KitMaker: 4,630 posts
Armorama: 4,498 posts
Posted: Thursday, June 28, 2012 - 06:20 AM UTC
Just to make clear : T-44 hull used in the making of the T-54 tank. Not IDENTICAL, but close enough that AA can start with a T-54/55 hull for a T-44.
Be careful with the mine roller...it might be the hardest part of the project to make look convincing.
Good luck.
kruppw
Posted: Thursday, June 28, 2012 - 06:49 AM UTC
Thanks for the heads up Jacques, I'm not going to hog wild on this build. Just as long as it looks like a T-44, I'm good with it, but I do plan to make some improvements to the kit.
Chris
kruppw
Posted: Thursday, June 28, 2012 - 07:13 AM UTC
I do need some clarification on the lower hull, I’ve seen two different version for the lower front hull. One tank has a smooth hull and another has mounting points like the T-54/55/62 series have. Is this an upgrade during the tanks service life? I’m wonder since I plane to attach the PT-34 to the hull and don’t have a clear picture showing if it is attach to the mounting point or directly to the hull.
Spiderfrommars
Milano, Italy
Posted: Thursday, June 28, 2012 - 09:36 AM UTC
Also T54 and T55 had two different kind of hull, one provided with mounting points and one which didn't have them. Here two Yugoslav exemplars:
https://www.dropbox.com/s/r0yzk7049alshlo/t-55a_006.jpg
https://www.dropbox.com/s/m2wg5j4f2mm9xhq/t-55a_035.jpg
Here two 1951 T-54 B
https://www.dropbox.com/s/vtsc9qidp20a96n/1951%201%20f1%20%288%29.jpg
https://www.dropbox.com/s/hvdp5unkhfj0303/10.%20t-54a%20pevn_%20kulomet%20v%20korb_.jpg
So, in my opinion, there were simply some T-44 exemplars which could carry the mine roller and some other ones which couldn't
kruppw
Posted: Thursday, June 28, 2012 - 10:08 AM UTC
Thanks Mauro, I wasn’t 100% sure about the mounting points. Being a tank I’m not real familiar with, just want to make sure that the mine roller would attach to the points and not directly to the hull like the T-34.
Either way I’ve begun to add some basic details to the lower hull. The torsion bars are not staggered like they should be on the real thing, but not a real issue. I’m using tamiya’s T-55 as a basic template for the details to be added. I found a few underside shots of the T-44 and the suspension looks very similar to the T-54/55 series.
tanknick22
Posted: Thursday, June 28, 2012 - 11:49 AM UTC
ill be following your build iv always wanted to add a t44 to my ww2 soviet armor collection for some time
kruppw
Posted: Friday, June 29, 2012 - 08:32 AM UTC
Well here is just a small update for now, I’ve finish adding some basic details to the bottom of the hull. I know it’s not 100% correct, but needed to add a few thing there just for illusion since most will not be seen. From here I’ll turn my attention to the rear hull and either add the ice cleats or spare track mounts. I’m still debating whether or not to open up a few hatches on the engine deck and use my verlinden T-55 engine drop in. I can’t glue together the 2 hull halves until I decide what to do.
More to follow soon
Spiderfrommars
Milano, Italy
Posted: Friday, June 29, 2012 - 06:54 PM UTC
I've found some hull drawings taken from the user's manual
here a pic
http://postimage.org/image/xwshv5vqn/full/
Hull looks slightly simplier and rougher than the T-54/55 one
Another thing which I've found out is that T-44 during is life had 3 different kinds of track links
As far as I've understood, T-34/85 track links were the earlier type, T-54 links were the later ones but in the mid times it carried those track links:
...as usual the recognition of Russian tank versions is a huge mess!
Anyway, you can find lots of very interesting close-up and drawings here
http://scalemodels.ru/modules/forum/viewtopic_t_24196_start_0.html
and here
http://scalemodels.ru/modules/forum/viewtopic_t_20245.html
Here some other walkarounds
http://svsm.org/gallery/t-44-family
http://legion-afv.narod.ru/T-44_Saratov.html
http://legion-afv.narod.ru/T-44_Zaslavl.html
cheers
kruppw
Posted: Saturday, June 30, 2012 - 03:18 AM UTC
Thanks Mauro for the pictures, as usual you come through with those I can not find. I’m planning to go with the early version with the spider wheels and T-34 tracks. I like this look more, plus I won’t need to buy new tracks or drive sprocket. I know there were also some that had the starfish road wheels just like the T-54/54 had.
Chris
Spiderfrommars
Milano, Italy
Posted: Saturday, June 30, 2012 - 05:39 AM UTC
Yes, that's the best choice Chris. Congrats for your job so far and for the originality. Your job makes me inspire to scratch built a T-44. I have a wreck of an old Esci kit, I haven't decided yet what I could do with it...that's one of the reasons why I've colleted some references
cheers
kruppw
Posted: Sunday, July 01, 2012 - 12:09 PM UTC
Thanks Mauro for the comments, hopefully someone will come to the rescue and give us a plastic version of the T-44. Afterall it was an important tank going from the medium to MBT concept.
Here is my latest installment, Finish the rear hull. I’ve rebuilt the storage mount for the ice cleats and added a few missing details to the rear hull. The ice cleats that came in the kit were fine, but had some miss casting and some of the details were missing.. Now I’m going to focus on the front hull and add the mounting point for the mine roller.
Chris
dvarettoni
KitMaker: 778 posts
Armorama: 763 posts
Posted: Sunday, July 01, 2012 - 03:23 PM UTC
chris love the build will be waching this one good luck
dave
kruppw
Posted: Sunday, July 15, 2012 - 03:16 PM UTC
Here is a small update on my progress with the build. Things have been slow since I’m jumping around on multiple builds at this time. So far I have finished off the front hull. The lower hull needed a shim added since the upper hull had some over hang. I’ve also added some mounting bosses taken from a T-55 kit and fashion a mounting plate for the mine roller. The glacis was pretty much straight forward other than what appears to be attachment points in the upper corners. For this I used some strip and plastic rod with welds made from epoxy putty. I also replaced the kit head light with one from trumpeter’s T-62 kit. The one supplied in the kit has a solid lens and frankly dos not look right once painted. From here I will turn my attention to the fenders and the engine deck. I’m also looking at the possibility replacing the AFV club tracks with some metal ones from fruil. I tried to assemble a few links and the pin that make the tracks work are far too easy to smash down when clicking the lings together making everything fall apart.
Chris
Spiderfrommars
Milano, Italy
Posted: Sunday, July 15, 2012 - 07:10 PM UTC
It's looking great so far.
Why are you thinking to replace the AFV tracks? They doesn't seem too bad in my opinion
kruppw
Posted: Monday, July 16, 2012 - 02:40 AM UTC
No, the details on the AFV club tracks are perfect. But once I start to assemble them, the two little pins that hold each track together fall apart. The pins them selves are too small and brittle and the minute I even touch the tracks, they come apart
example
Why I'm looking at the fruil tracks since a good solid wire is used to hold the tracks together.
dvarettoni
KitMaker: 778 posts
Armorama: 763 posts
Posted: Tuesday, July 17, 2012 - 07:45 PM UTC
chris have you seen the Spade Ace track yet if not you nead to check them out much better then fruil
dave
PantherF
Indiana, United States
KitMaker: 6,188 posts
Armorama: 5,960 posts
Posted: Saturday, July 21, 2012 - 10:42 PM UTC
I think anyone who attempts to build a mine roller in anything has my attention!
~ Jeff
KoSprueOne
Myanmar
KitMaker: 4,011 posts
Armorama: 1,498 posts
Posted: Sunday, July 22, 2012 - 01:28 AM UTC
Interesting subject and very fine detailed progress. I also like the mine rolling machines. Subscribed
kruppw
Posted: Sunday, July 22, 2012 - 02:41 AM UTC
Thanks guys for the comments, it's a fun build so far with very little problems.
Hoping to do some more updates todays. I do have AFV club's t-34/85 sitting on the shelf and looking at the possibility of modifying the turret since it comes with a great interior. I would have to reshape the back of the turret and add a big bump to the front of the turret on the commander's side. But i'm still thinking about it.
