Badger Renegade Krome
c5flies
KitMaker: 3,684 posts
Armorama: 2,938 posts
Posted: Thursday, July 26, 2012 - 02:28 PM UTC
Darren Baker takes the Badger Renegade Krome for an outing to see if Badger still has it where it counts.
Karl187
#284
KitMaker: 3,094 posts
Armorama: 2,942 posts
Posted: Thursday, July 26, 2012 - 10:20 PM UTC
Excellent review Darren- I think you covered the main points of this piece of kit really well- and its interesting that you 'instantly felt comfortable with it'- that was my feeling as well the first time I picked it up, and I'd never used a Badger before!
I will say though, that having used the Krome for nearly a year now, it does need very thorough cleaning to ensure optimum performance with the .21mm needle.
Posted: Thursday, July 26, 2012 - 11:17 PM UTC
Firstly thank you for your feedback Karl. Out of interest what is your cleaning regime and with what paint type. Having used this brush a few times now without incident I would assume the area that is most at risk of paint build up is the cone behind the head of the brush? I will add that I bought an ultrasonic cleaner for my airbrushes and so cleaning holds no fears for me anymore.
Karl187
#284
Posted: Thursday, July 26, 2012 - 11:53 PM UTC
Yeah, I bought one of those ultra-sonic cleaners too- I never use it now! I clean my AB's using Mr. Hobby thinners, cotton buds, and a set of fine bristled cleaning brushes I got from the Airbrush Company. I mostly use Tamiya paint in the Krome and I always find the paint builds up were you said, behind the nozzle assembly on the needle. This builds up no matter what thinners I use to clean the brush- you'll now its dirty because, at least in my experience, the trigger action will be 'sticky' and not smooth.
Usually just a clean of the needle and a squirt of Mr. Hobby thinner's through the forward end of the AB is enough to sort things but usually after about two painting sessions I'll break it down- nozzle, tip, needle etc and give it all a nice clean. I also break down the rear of the AB from time to time aswell and give that a good clean- its very simple really- just take the needle out and unscrew the needle clamp and lift the trigger out- follow the instructions breakdown really.
This probably sounds like a lot of work but it usually only takes about 5-10 minutes!
