Tents, tarps, crates sets.
Posted: Monday, December 30, 2013 - 07:04 AM UTC
Roman Volchenkov reviews quarterscale sets from Value Gear Details.
Bizarre
Akershus, Norway
KitMaker: 1,709 posts
Armorama: 1,581 posts
Posted: Monday, December 30, 2013 - 09:16 AM UTC
Thanks for editing that, Darren. It is a wall of reviews today
210cav
KitMaker: 6,149 posts
Armorama: 4,573 posts
Posted: Monday, December 30, 2013 - 10:39 AM UTC
I have several sets of Value Gear. It is outstanding. Clean mold, detailed, just great stuff.
Isaella2
KitMaker: 44 posts
Armorama: 30 posts
Posted: Monday, December 30, 2013 - 07:55 PM UTC
Nice.. I want one for my project - T-34/76
KitMaker: 7,600 posts
Armorama: 6,110 posts
Posted: Tuesday, December 31, 2013 - 04:30 AM UTC
I have to admit that Value Gear is well detailed and reasonably priced, but everything (that I see in the 1/48) is made to go on a flat surface, as the illustrated Staghound. There is nothing curved, for instance, to fit over fenders. Then you have to go and buy a specialized set anyway, ie; Black Dog.
viper29_ca
New Brunswick, Canada
KitMaker: 2,247 posts
Armorama: 1,138 posts
Posted: Tuesday, December 31, 2013 - 05:06 AM UTC
Put the parts you want to curve in hot water, take out, shape as needed, and viola....curved items.
Posted: Wednesday, January 01, 2014 - 04:20 AM UTC
Will that work on thick resin castings, ie., tent rolls, tarps, etc? I know that works well on things like sword blades, scabbards, pole arms, etc., but these are thin items.
Bizarre
Akershus, Norway
Posted: Wednesday, January 01, 2014 - 04:48 AM UTC
I know that this technique is used to straighten bent hull parts from old Varja resin kits...
Posted: Wednesday, January 01, 2014 - 05:07 AM UTC
If the water is hot enough it will bend but you may need to give the part several swimming lessons before it conforms to the desired shape.
Posted: Thursday, January 02, 2014 - 03:48 AM UTC
bill_c
KitMaker: 10,553 posts
Armorama: 8,109 posts
Posted: Thursday, January 02, 2014 - 06:20 AM UTC
... everything (that I see in the 1/48) is made to go on a flat surface, as the illustrated Staghound. There is nothing curved, for instance, to fit over fenders. Then you have to go and buy a specialized set anyway, ie; Black Dog.
In addition to the suggestions about using hot water to bend the resin, you can also use a hobby knife or razor saw to cut out parts.
VG keeps their prices low by creating generic stowage, though their new Sherman series in 1/35 are intended for Sherman back decks (and include field-modified stowage platforms in many of the sets).
tankmodeler
#417
KitMaker: 3,123 posts
Armorama: 2,539 posts
Posted: Friday, January 03, 2014 - 02:44 AM UTC
If you are trying to bend a rolled up resin tarp over something a curvy as a Staghound fender, it is very, very unlikely to work. Polyurethane resin is a thermoset material, It can be moved a little with head, but is not a thermoplastic like polystyrene. It simply can not be moved that far. If you really push it, it will tear/break along the outside of the curvature.
A thin part may be able to be moved that much, but not a thicker piece. Anything thicker than, say 5ish mm is not going to move enough to drape nicely over a truck fender in 1/35 scale.
Do NOT buy a flat piece of stowage assuming you can move it to any shape you want later. You can't. You can get some movement out of it, but not a lot.
It really isn't _that_ hard to make rolled tarps and the like yourself out of epoxy putty and fit them exactly where you need them.
Plasticbattle
#003
Donegal, Ireland
KitMaker: 9,763 posts
Armorama: 7,444 posts
Posted: Saturday, January 04, 2014 - 04:31 AM UTC
You can even keep it simple and make a folded blanket which will fit around the arched surface (or even on detailed areas)and you set the resin parts into this, which helps them fit on most surfaces. I also like the value grear stuff, and a simple trick like that above means you can add them easily and also build them higher, convincigly.
Good review Roman.
Bizarre
Akershus, Norway
Posted: Saturday, January 04, 2014 - 07:28 AM UTC
Thanks, Frank.
True, it is all about knowledge, skills and time. You can do everything from scratch (if you can), you can combine the best of the two worlds, you can use what is on the market. When it comes to the latter - I would rather take something that is really easy to work with and VG sets are on that list.
