Constructive Feedback
Tasca M4A1 Grizzly Guardian
Removed by original poster on 05/13/19 - 19:33:03 (GMT).
Removed by original poster on 05/13/19 - 19:33:16 (GMT).
Cookiescool2
KitMaker: 273 posts
Armorama: 270 posts
Posted: Thursday, June 09, 2016 - 04:36 AM UTC
Wow I'm ecstatic that this build has returned, can't wait for the next update!
Purplepanzer
KitMaker: 5 posts
Armorama: 4 posts
Posted: Friday, June 17, 2016 - 02:17 AM UTC
Really, really impressive. Can I ask, where did you get all measurements etc. required for the build?
Removed by original poster on 05/13/19 - 19:33:27 (GMT).
M4A3E8Easy8
KitMaker: 302 posts
Armorama: 300 posts
Posted: Friday, July 01, 2016 - 02:07 AM UTC
Welcome back... to you and snuggles. Hope you have gotten your bearings aligned and are progressing along. I have not forgotten the E8 waiting in the wings.
Removed by original poster on 05/13/19 - 19:33:43 (GMT).
testpro
#383
KitMaker: 36 posts
Armorama: 30 posts
Posted: Sunday, July 10, 2016 - 12:30 AM UTC
i am so happy I found this build. the scratch building is just, well what I dream of doing. So if you do not mind I plan on using this to repeat all or sum of the work you done here. I love adding detail but I suffer from the SQU's (pronounced screws) Self Queen Undone. But I have recently returned to the hobby (over the last several years) and now starting to really build things.
any suggestions you can give would be helpful for me since I never really done much scratch building.
the work is excellent and I hop I learn a lot. keep it up while I follow along in amazement and hopfully not frustrated but I find this fun. So carry on
Removed by original poster on 05/13/19 - 19:34:01 (GMT).
Removed by original poster on 05/13/19 - 19:34:17 (GMT).
M4A3E8Easy8
KitMaker: 302 posts
Armorama: 300 posts
Posted: Thursday, January 18, 2018 - 11:48 AM UTC
A blast from the past... Now go out to the shed and get your little blue knife from all the motor bike stuff and pick this one back up.
Removed by original poster on 05/13/19 - 19:34:33 (GMT).
MaKrueger
KitMaker: 60 posts
Armorama: 60 posts
Posted: Sunday, January 21, 2018 - 10:54 PM UTC
I'm new to the party here. What an amazing thread. You have some real scratch skills. I hope to see your future progress on this soon.
DG0542
KitMaker: 125 posts
Armorama: 125 posts
Posted: Sunday, January 21, 2018 - 11:04 PM UTC
It might be that General Steel casted the hull like that. Just the way they cut the master.
easyco69
KitMaker: 2,275 posts
Armorama: 2,233 posts
Posted: Monday, January 22, 2018 - 02:44 AM UTC
Once your done the lower hull, you should make sesin copies of it through mold making rubber.
I'd buy one. )
Removed by original poster on 05/13/19 - 19:34:48 (GMT).
Removed by original poster on 05/13/19 - 19:35:03 (GMT).
rfbaer
KitMaker: 1,866 posts
Armorama: 1,696 posts
Posted: Tuesday, January 30, 2018 - 07:09 AM UTC
Man, talk about a blast from the past... I started over, back with page 1, just to get in the mood again.
This thread is so old, SK has gone to the great food bowl in the sky, we've moved, and I haven't built (or even started) a Sherman in well over a year.
Posted: Tuesday, January 30, 2018 - 11:28 AM UTC
If you are talking about that round hole in the rear of the tank highlighted in the square??? That is where you insert the engine crank. Applies only to radial engined Shermans. If it has been a bit since the engine has been run you (and two or three of your best friends) will need to turn the engine over a number of times using the crank.
Engine oil will have accumulated in the lower cylinders of the radial and if you simply try to start the engine as-is you stand a fair chance of blowing the cylinder head off one or more of the lower pistons.
That is why you often see, in old movies, the flight crew of a B 17 or 24 doing the "propeller walk", using the propellers to turn the radial engines over to redistribute the engine oil before starting.
Or maybe you were referring to something else in the photo. In which case, as Gilda would say, "never mind".
Removed by original poster on 05/13/19 - 19:35:20 (GMT).
Removed by original poster on 05/13/19 - 19:35:39 (GMT).
Removed by original poster on 05/13/19 - 19:35:57 (GMT).
Removed by original poster on 05/13/19 - 19:36:13 (GMT).
Removed by original poster on 05/13/19 - 19:36:31 (GMT).
Removed by original poster on 05/13/19 - 19:36:49 (GMT).
