Armor/AFV: Braille Scale
Ersatz M10 finished
KitMaker: 7,600 posts
Armorama: 6,110 posts
Posted: Sunday, March 01, 2015 - 05:05 AM UTC
Finally finished Ersatz M10 with some corrections/additions:
Cantstopbuyingkits
European Union
KitMaker: 2,099 posts
Armorama: 1,920 posts
Posted: Sunday, March 01, 2015 - 06:43 PM UTC
It looks awesome. But you I think you should add areas where he paint has come off to reveal the original German colours.
mdbond148
KitMaker: 24 posts
Armorama: 23 posts
Posted: Sunday, March 01, 2015 - 07:20 PM UTC
Very nice! I build 1/48 armor usually and I just started a 1/72 project. I know how hard it is to get that level of detail out of such a small project.
Matt
Posted: Sunday, March 01, 2015 - 07:43 PM UTC
I dont believe German colours would show as the vehicle had thin plate added to it.
Posted: Sunday, March 01, 2015 - 08:24 PM UTC
The only extra plating was thin sheet metal around the turret and mantlet, and on the front and rear. I painted mine mint condition - just out of the paint shop. No point in making it look worn or knocked out, or in a dio; as all hatches are molded shut! And it was more an exercise in doing corrections, and painting. I wasn't even going to finish it as it's not Dragon at their best, but I needed the exercise.
Giovanni1508
Napoli, Italy
KitMaker: 652 posts
Armorama: 600 posts
Posted: Sunday, March 01, 2015 - 08:59 PM UTC
Hi Biggles, very good result ! I like so much.
The exercise went well
Giovanni
JPTRR
RAILROAD MODELING
#051
KitMaker: 7,772 posts
Armorama: 2,447 posts
Posted: Sunday, March 01, 2015 - 09:06 PM UTC
Biggles,
impressive! Love the weathering.
Posted: Sunday, March 01, 2015 - 09:28 PM UTC
Thanks, all!
tread_geek
KitMaker: 2,847 posts
Armorama: 2,667 posts
Posted: Monday, March 02, 2015 - 12:13 AM UTC
Leo,
Very nice to see you finally display some of your work in the Braille Forum. The Ersatz M10 looks very good and I think the paint job is very well done. For an otherwise plain vehicle, it gives the model some life! I’ve seen and built a few Dragon Panthers and they all have an issue with the front tracks being canted to one side or the other and it appears that this model is no exception. The straight parts of the track links aren’t parallel to the surface that the tank sits on. Other than that, the build looks very good and thanks for sharing.
weathering_one
KitMaker: 458 posts
Armorama: 456 posts
Posted: Monday, March 02, 2015 - 02:00 AM UTC
This model is looking pretty sharp considering what you had to work with (Dragon kit). It could be a real show stopper.
AJ
Posted: Monday, March 02, 2015 - 08:25 PM UTC
I suspect that may be because the attachment points for the drive gear is too small or too weak, and the tension of the track pulls it back and to the side. I've also had the same problem with any Panther I've built.
KitMaker: 1,501 posts
Armorama: 1,485 posts
Posted: Wednesday, March 25, 2015 - 10:34 AM UTC
@Biggles2 – Leo,
I think you did a very good job on your rendition. I like the weathered paint and how well you managed to blend in the decals so there not so stark against the darker base color.
Leo, I’ve run into this issue of having canted rear idlers or drive wheels or both on the same kit, usually due to having a tight set of tracks. So here is what I do to remedy this problem.
I usually apply a small drop of super glue at the attachment points after the glue has had some time to cure to keep the wheels set in place. Hope this will help you on future builds?
Thanks for posting and sharing your builds, hoping to see more of your work here.
~ Eddy
Posted: Wednesday, March 25, 2015 - 07:59 PM UTC
Thanks for the info. I was planning to rip off the sprockets and reinforce them with CA and metal rod - a single rod like an old-time metal axle going right through the chassis. Maybe overkill, but that'll do it! BTW; good looking Tiger happening there. I see you've added some nice scratch work!
Posted: Wednesday, March 25, 2015 - 08:07 PM UTC
AJ
I was going to say, "In spite of everything Dragon still make the best injected plastic 1/72 kits", but in view of the announced Flyhawk FT's and Pz l kits, Flyhawk's quality just sweeps away Dragon's recent offerings!
