News
Slingshot Models: M48 Patton drive sprockets
Isherman
KitMaker: 40 posts
Armorama: 38 posts
Posted: Tuesday, May 12, 2015 - 04:43 AM UTC
Some newM48 Patton drive sprockets to replace the undersized Academy kit items, have been released by slingshot models.
Read the Full News Story
jwest21
KitMaker: 3,374 posts
Armorama: 3,126 posts
Posted: Tuesday, May 12, 2015 - 05:30 AM UTC
Will they work with Dragon's kits? Easier than drilling out the lightening holes
warhog
KitMaker: 568 posts
Armorama: 398 posts
Posted: Tuesday, May 12, 2015 - 05:45 AM UTC
I have several of Slingshots conversion kits. And the casting has been first rate. And further more Slingshot ships fast and responds quick to emails.
Posted: Tuesday, May 12, 2015 - 05:51 AM UTC
I am more interested in seeing if they actually fit the Academy M48A5 with the wider AFV Club tracks mentioned (T92E and T142). The Academy M48A5 has narrower tracks and sprockets because the fenders were narrowed to fit the side skirts, which attach incorrectly. I doubt the wider tracks will fit under the narrow fenders.
Posted: Tuesday, May 12, 2015 - 01:41 PM UTC
Oh dear ....
Any images somewhere showing how the side skirts should be
attached (the correct way ...) ??
Posted: Tuesday, May 12, 2015 - 03:50 PM UTC
On M48s, the track end connectors extend slightly beyond the fenders, that would make fitting the skirts impossible.
On ROK M48A5s, there is a spacer that extends from the side of the fender to make room for the side skirts to clear the tracks. You can see the extensions at the edges of the fenders where a small piece sticks down below the original fender line.
For some reason, instead of adding the spacers to the fenders, Academy added the side skirts and kept the overall width of the fenders the same, so the tracks and sprockets had to be narrowed to fit under the side skirts.
ColDunwerk
Maryland, United States
KitMaker: 20 posts
Armorama: 12 posts
Posted: Tuesday, May 12, 2015 - 04:11 PM UTC
Would these also be appropriate for the new 1/35 Revell M48A2c? The sprocket interiors on that kit are marred by large sink holes and poor bolt detail (at least on my copy).
Posted: Tuesday, May 12, 2015 - 04:18 PM UTC
DEF Models makes a set of replacement M48 outer sprockets that should fit any of the current 1/35 kits. They look really nice too.
The set was reviewed here at Armorama a while ago.
Also, DEF Models has sets of T97E2 and T142 track that include resin sprockets and AFV Club indi-link tracks.
Cantstopbuyingkits
European Union
KitMaker: 2,099 posts
Armorama: 1,920 posts
Posted: Tuesday, May 12, 2015 - 05:58 PM UTC
Those DEF model items look pretty good, but why is the outer cast in frosted clear resin then the real think was obviously opaque?
Posted: Tuesday, May 12, 2015 - 06:00 PM UTC
Does it really matter since it will be painted anyways? I could care less if it was pink w/purple polka-dots.
Seriously, I think it is because they are 3-D printed. A clear, frosted finish is the norm for 3-D printing.
Posted: Tuesday, May 12, 2015 - 06:11 PM UTC
My guess is they cast one in clear so we could see through it, or perhaps it is a 3D-printed "master" from which the rubber moulds will be made? (Those white rear doors look like Evergreen plastic, perhaps also masters for mould-making?) Either way, adding paint will soon hide the resin!
Ranchhand
KitMaker: 289 posts
Armorama: 257 posts
Posted: Tuesday, May 12, 2015 - 07:49 PM UTC
its a master shot, the one you get is resin cast ( i have the def sprocket set for dragon )
Slinger
Attica, Greece / Ελλάδα
KitMaker: 9 posts
Armorama: 7 posts
Posted: Tuesday, May 12, 2015 - 08:03 PM UTC
No they don't fit on the Dragon's kits,or they need a lot of work to do so.
A replacement set specially for the Dragon M48 will be available shortly.
Slinger
KitMaker: 9 posts
Armorama: 7 posts
Posted: Tuesday, May 12, 2015 - 08:08 PM UTC
Hi Gino,
you are right,they will not work on a Korean M48A5K.
Thank God,the rest of the nations does not use side skirts on their M48's or M60's!
jwest21
Posted: Tuesday, May 12, 2015 - 08:23 PM UTC
great news, thanks!!
jwest21
Posted: Wednesday, May 13, 2015 - 03:37 AM UTC
DEF Model is really nice, but they aren't easy to find. Plus if you don't need the unarmored rear panel, you are paying for more than you need.
C_JACQUEMONT
Loire-Atlantique, France
KitMaker: 2,433 posts
Armorama: 2,325 posts
Posted: Wednesday, May 13, 2015 - 04:02 AM UTC
Agreed, I'm normally a big fan of DEF's but in this case Slingshot Models is much more flexible, I don't need rear grilles or tracks, half sprockets are kind of useless unless you want to upgrade a Dragon M48A3.
Christophe
M4A1Sherman
KitMaker: 4,403 posts
Armorama: 4,078 posts
Posted: Thursday, May 14, 2015 - 06:05 PM UTC
Try ebay- I can get anything DEF on that site...
M4A1Sherman
Posted: Thursday, May 14, 2015 - 06:07 PM UTC
Patience... All good things come to those that wait...
I WANT IT NOW!!! I WANT IT NOW!!!
Slinger
KitMaker: 9 posts
Armorama: 7 posts
Posted: Wednesday, May 20, 2015 - 01:32 AM UTC
They are ready!
Check https://www.slingshotmodels.com/p/products-135.html
