Hosted by Richard S.
I Really Want To Build This KIT!
dtniedert
KitMaker: 152 posts
Armorama: 139 posts
Posted: Monday, May 08, 2017 - 07:00 PM UTC
Got a lot done the past two days.
ClaytonFromEllijay
#454
KitMaker: 1,273 posts
Armorama: 1,138 posts
Posted: Monday, May 08, 2017 - 08:07 PM UTC
You're flying through that, Doug! Very nice, plus I have those exact DR chairs too!
dtniedert
KitMaker: 152 posts
Armorama: 139 posts
Posted: Monday, May 08, 2017 - 08:52 PM UTC
Thanks Clayton.My problem is I am the absolute KING of completing 75% of a kit then storing in the closet for the next 20 years .
The painting/ weathering process is the most intimidating to me. I made it a point to start joining campaigns recently to thin the herd out a bit and have accountability in completions.
ClaytonFromEllijay
#454
Posted: Tuesday, May 09, 2017 - 03:09 AM UTC
Take your time, have fun, that's what it's all about!
d111298pw
#456
KitMaker: 654 posts
Armorama: 638 posts
Posted: Tuesday, May 09, 2017 - 07:51 PM UTC
More progress. The electronics are wired and installed. So far, the motors are working and it moves across the floor nicely. Need to connect the turret next and function check it. Then just add the tools and I'll be finished.
ltb073
KitMaker: 3,662 posts
Armorama: 3,078 posts
Posted: Wednesday, May 10, 2017 - 04:45 PM UTC
So with these Vac form kits you need something to glue the sides together. AS you saw Alex use some Styrofoam which works well on larger pieces. On thinner sides I used some of the leftover plastic to form a joint
 photo P1100251_zps2meepkdd.jpg photo P1100252_zpsln2z1lis.jpg photo P1100253_zpsj31fe0a7.jpg
Now the work begins on the seams
d111298pw
#456
KitMaker: 654 posts
Armorama: 638 posts
Posted: Wednesday, May 10, 2017 - 06:31 PM UTC
It is complete. All functions are working perfectly.
ClaytonFromEllijay
#454
Posted: Wednesday, May 10, 2017 - 07:03 PM UTC
Sal- looking good!
Mark- that is a fine-looking monster! Beautiful work!
Scipio2010
#401
KitMaker: 323 posts
Armorama: 221 posts
Posted: Thursday, May 11, 2017 - 06:24 PM UTC
Mark, that Mk IV is truly impressive! And kudos to you for the fast build.
I laid the ground work for the diorama last night and plan on letting it cure for 24-48 hours before I prime it. I have a set of Kamizukuri weeds coming in the mail to add some vegetation to the scene.
ltb073
Posted: Saturday, May 13, 2017 - 07:04 PM UTC
Nice Camo on the Pz IV Mark
Shawn nice diorama are you going with the pain scheme in the photo
I have made some progress. For the base I used a block of wood covered with Verlinden cobble stone
I saw trhis type od stone work all over Berlin when I was there last summer
And some of the props that will be included
d111298pw
#456
KitMaker: 654 posts
Armorama: 638 posts
Posted: Sunday, May 14, 2017 - 01:39 PM UTC
I appreciate the comments. It was a different type of build.
Shawn/Sal, I am enjoying watching your diorama's come together.
dtniedert
KitMaker: 152 posts
Armorama: 139 posts
Posted: Sunday, May 14, 2017 - 09:49 PM UTC
Small update.
ltb073
Posted: Friday, May 19, 2017 - 07:03 PM UTC
So I went through the spare parts box and found some stuff to add to my shed
Also broke out some balsa wood to make the racks and lumber
I think I might be ready to call it finished but Im not sure comments or suggestions will help
Lakota
#123
New Mexico, United States
KitMaker: 1,202 posts
Armorama: 635 posts
Posted: Saturday, May 20, 2017 - 01:27 AM UTC
Sal-Sweet! Congrats on finishing. If you're looking for suggestions I would add a little more dirt around the cobblestone seam to kind of hide it. Also, you might want to put some dirt/pigment on the tire.
Looks good, nice work!
Take care,
Don "Lakota"
petbat
KitMaker: 3,353 posts
Armorama: 3,121 posts
Posted: Saturday, May 20, 2017 - 01:39 AM UTC
Some really excellent work going on here. I have paused the Saurer build to get some done on my halftrack for that GB. It closes in a month so I have to get that done...
ClaytonFromEllijay
#454
Posted: Saturday, May 20, 2017 - 04:48 AM UTC
Maybe a little green/brown fluff to suggest some odd plants or bushes, weeds are everywhere....
Bluestab
KitMaker: 2,160 posts
Armorama: 1,906 posts
Posted: Saturday, May 20, 2017 - 10:35 AM UTC
Back to work.
Now for the iron-work. The top pair is unmodified. You have to trim off one bar and that gives you the lower pair. As mentioned, the kit didn't provide and ironwork for the small wall sections. I have extra ironwork sections from another Miniart Set that I will use for them.
As an aside, the hobby knife with the larger handle is what I use for cutting the Miniart pieces. This one isn't great but it does help save your hands. There's a lot of good handled hobby knives out there.
Modified ironwork sections put together. The problem is that they are a tad bit short. I added strip styrene to each end to fill the gaps and to give it a connection point for the ends.
I cut the small wall sections flush. The kit has the ends damaged. The ironwork for them was cut to size. I'll add the strip to them as well.
Tested-fitted the iron to the walls. I had to adjust the fit to get them to fit. I filed down the sides, reattached the strips, and set them until they fit. One side will not fit the other.
Also, the tilework was added to the tops of the gate and the posts.
A shot of the gate. The tile is supposed to extend to the sides about 2 cm on each side. I trimmed them smaller to match the lesser overhang on the posts and gate support buttresses.
Off to paint. I went with a basic light gray. The weathering and finish painting is what's going to sell this.
I plan on adding some ivy on the stonework. Of course the interior will have gravestones, shrubbery, and maybe some trees. There'll be a road in front. The kit comes with streetlamps, which I'll use. I've been thinking about adding some But that's the next step. Still a good bit to do...and things are subject to change on a whim.
ltb073
Posted: Tuesday, May 23, 2017 - 04:18 PM UTC
Hey Guys thanks for the suggestions
I added some more dirt and green stuff
Also found an Iron gate on the workbench
but that damn seam is still visible in the photos
Well im moving on to the nex built maybe when I put something on the base it won't be so noticeable
Looking forward to seeing Alex's dio come together
ClaytonFromEllijay
#454
Posted: Tuesday, May 23, 2017 - 07:17 PM UTC
Good looking base, Sal! Those final details really enhanced it!
Bluestab
Posted: Thursday, May 25, 2017 - 10:20 AM UTC
Looking good Sal.
Mine is coming together. I'm working through some trial and error on the stonework. Update coming soon.
Scipio2010
#401
KitMaker: 323 posts
Armorama: 221 posts
Posted: Friday, June 02, 2017 - 07:27 PM UTC
Update on the Israeli Sherman Dio. I laid the groundwork, and added plastic card along the outside edges of Styrofoam to create a neat edge. I primed and painted the entire dio. I used black to prime the entire base, and then I sprayed the various brown tones for the earth at different angles which helped create some shadowing. The shadowing effect turned out really well underneath the tank. I hand painted many of the rocks, and painted the fence and plants. I gave the tank an overall dark red oxide coat, and then used the Dark Rust Deposits in areas I know will be exposed after the graffiti paint job.
Once all of that was done I moved on to the fun part - painting the graffiti. I'm doing my best to mimic paint brush strokes with the graffiti.
ClaytonFromEllijay
#454
Posted: Saturday, June 17, 2017 - 09:27 PM UTC
Just bumping along...
TMoon
#152
KitMaker: 487 posts
Armorama: 441 posts
Posted: Sunday, June 18, 2017 - 08:27 PM UTC
Here is my startup photo of the P-47D Thunderbolt 1/32 scale.
ClaytonFromEllijay
#454
Posted: Monday, June 19, 2017 - 05:40 AM UTC
Looking forward to your build, Tom!
SGTJKJ
#041
Kobenhavn, Denmark
KitMaker: 10,069 posts
Armorama: 4,677 posts
Posted: Monday, June 19, 2017 - 09:23 AM UTC
That's a beauty in so many ways, Tom!
Looking forward to see more.
