Hosted by Richard S.
TAKOM - Campaign
Bluestab
KitMaker: 2,160 posts
Armorama: 1,906 posts
Posted: Monday, May 08, 2017 - 10:32 AM UTC
Some nice looking builds getting underway.
I might be in with Takom's German Civilian Car. Alot depends on if I can get some other builds caught up.
dtniedert
KitMaker: 152 posts
Armorama: 139 posts
Posted: Monday, May 08, 2017 - 07:21 PM UTC
I'm in. I will put a ZSU 57-2 on order soon.
Thirian24
KitMaker: 2,493 posts
Armorama: 2,344 posts
Posted: Tuesday, May 09, 2017 - 07:21 AM UTC
Some good looking kits being entered.
Here is my entry. With any luck, once I get a handful of other kits done, I'll be starting this.
Knuckles
Oregon, United States
KitMaker: 525 posts
Armorama: 266 posts
Posted: Tuesday, May 09, 2017 - 10:32 AM UTC
LOVE that Chieftain^^^
I spent about 8 hours total so far on this one. It's a really easy kit to get together--the fun will be the paint and weathering!!
Thirian24
Posted: Tuesday, May 09, 2017 - 06:12 PM UTC
Very nice! Any idea what scheme you're going with?
Knuckles
KitMaker: 525 posts
Armorama: 266 posts
Posted: Tuesday, May 09, 2017 - 07:07 PM UTC
Not made up my mind on that one yet. Khaki and British, or German and buntfarbenanstrich. Either way, it will be very, very dirty.
I built it as the hermaphrodite version, so historical accuracy is right out, and the fun-times are in!
bulldawg380
KitMaker: 347 posts
Armorama: 338 posts
Posted: Tuesday, May 09, 2017 - 07:20 PM UTC
Hopefully I have done everything right so y'all can see these photos
https://vault.myvzw.com/webcs/app/share/invite/30GhFnZAiU
bulldawg380
KitMaker: 347 posts
Armorama: 338 posts
Posted: Tuesday, May 09, 2017 - 07:48 PM UTC
Hopefully that worked
Lower chassis started
Armorsmith
KitMaker: 1,063 posts
Armorama: 1,000 posts
Posted: Tuesday, May 09, 2017 - 10:31 PM UTC
Dustin-Good choice. Goes together pretty well. Only tricky part I found were the headlight guards, they are a bit fiddly.
Knuckles
KitMaker: 525 posts
Armorama: 266 posts
Posted: Tuesday, May 09, 2017 - 11:12 PM UTC
...Only tricky part I found were the headlight guards, they are a bit fiddly.
Aren't they always? IM are too thick, PE are too fiddly, stowage and sandbags make them juuust right
ClaytonFromEllijay
#454
KitMaker: 1,273 posts
Armorama: 1,138 posts
Posted: Wednesday, May 10, 2017 - 12:27 AM UTC
...and nothing a little indirect mortar round won't take care of!
Thirian24
Posted: Wednesday, May 10, 2017 - 09:36 AM UTC
Thank you Armorsmith. I've seen a lot of people complain about the headlight guards.
dcandal
Buenos Aires, Argentina
KitMaker: 918 posts
Armorama: 212 posts
Posted: Saturday, May 13, 2017 - 03:14 AM UTC
I'm going to participate with the Takom Krupp Raumern,
roteck
KitMaker: 274 posts
Armorama: 159 posts
Posted: Sunday, May 14, 2017 - 02:22 AM UTC
Hi guys,
here is my entry for this campaign, a Leopard C2. I am building it hoping that it will be ready for CapCon 2017 here in Ottawa. I have built the C2 MEXAS and really enjoyed it, so I'm guessing this one will be the same! :-)
Chris
m4sherman
KitMaker: 1,866 posts
Armorama: 1,808 posts
Posted: Sunday, May 14, 2017 - 04:35 AM UTC
Change of plans, or another kit I want to build! Sort of lost my mojo on the T-55 while making, and waiting for the 3D printed parts I'm doing, so decided to work on this one. The T-55 will be worked on as well as both are part of the scene I have been thinking over.
m4sherman
Posted: Sunday, May 14, 2017 - 04:47 AM UTC
The model is simpler than the Meng pick ups, but is detailed enough for what I have planned. I was warned about the body, and this is because the box is not large enough for the kit and the body gets pressed down to fit.
Knuckles
KitMaker: 525 posts
Armorama: 266 posts
Posted: Sunday, May 14, 2017 - 06:56 AM UTC
My Mk IV made it into the prime and paint booth today. Primed with Mr. Surfacer 1500 (PIA to airbrush), then a black coat with Tamiya NATO black, mixing the white now for the pre-shading, then will apply the primary color later tonight.
I decided on a British khaki version of this one.
Thirian24
Posted: Sunday, May 14, 2017 - 07:10 AM UTC
Hey fellas! Nice to see all of these new entries.
Christian, the paint is looking good so far.
Knuckles
KitMaker: 525 posts
Armorama: 266 posts
Posted: Sunday, May 14, 2017 - 08:24 AM UTC
Post-pre-shade.
Cracked a fresh beer, shaking a bottle of Tamiya khaki.
Knuckles
KitMaker: 525 posts
Armorama: 266 posts
Posted: Sunday, May 14, 2017 - 09:22 AM UTC
Base coat applied
jugjunkie
South Africa
KitMaker: 140 posts
Armorama: 50 posts
Posted: Sunday, May 14, 2017 - 12:36 PM UTC
That is simply appalling considering the day and age we are at with modelling - the box is too small!!!! Unacceptable.
Knuckles
KitMaker: 525 posts
Armorama: 266 posts
Posted: Sunday, May 14, 2017 - 09:07 PM UTC
ANd base coats down, all mocked-up with the tracks on. Tracks were primed black, then hit with a coat of Humbrol's Track color.
Next is detail the guns, paint the red and white ID markings, rust the exhaust and glue it up, then a post-shade with Tamiya's Smoke. Then it'll get sealed and move to weathering!
Thirian24
Posted: Monday, May 15, 2017 - 01:04 AM UTC
Looks good! How do you post shade with smoke? First I've heard of that. I'm interested in hearing more about it.
Knuckles
KitMaker: 525 posts
Armorama: 266 posts
Posted: Monday, May 15, 2017 - 01:37 AM UTC
Just thin down some smoke, and spray it along the panel lines/shadow areas. It's an exaggerated effect (or can be) that I've borrowed from painting aircraft panel lines. You weather over the top of it. It'll really lend itself well to this particular build. Sooty, dirty, sodden, muddy, and mean.
m4sherman
Posted: Monday, May 15, 2017 - 02:31 AM UTC
If the box was 1/2 (12.5mm) longer or taller the body would be less prone to warping. I have Trumpeter trucks that have a protective box around the cab. That would have saved the body.
