Hosted by Richard S.
TAKOM - Campaign
imransz
Singapore / 新加坡
KitMaker: 38 posts
Armorama: 37 posts
Posted: Saturday, May 20, 2017 - 07:50 PM UTC
hey imransz is that the Tiran t-55
Yes..
Isn't the new Takom kit the Tiran 4 based on the T-54?
sorry....thought was based on t55.
Armorsmith
KitMaker: 1,063 posts
Armorama: 1,000 posts
Posted: Saturday, May 20, 2017 - 08:10 PM UTC
Tiran 4-T54, Tiran 5-T55, Tiran 6-T62. Could be wrong but this is my understanding.
m4sherman
KitMaker: 1,866 posts
Armorama: 1,808 posts
Posted: Sunday, May 21, 2017 - 08:12 AM UTC
Just about finished the basic build. I added welds from filler and bolts to the side beams and to hold the stake sides to the body. I added some welded on strips to hold the cut down doors closed.
There are big gaps under the body, and a number of holes that need to be filled in, or covered, but nothing I haven't seen before. And the tires don't look right. I'm looking for replacements.
I'm still thinking about the cargo for the truck. Some kind of boxed produce. Any suggestions?
Knuckles
Oregon, United States
KitMaker: 525 posts
Armorama: 266 posts
Posted: Sunday, May 21, 2017 - 08:22 AM UTC
Buy 92 of these:
http://www.ebay.com/itm/BEER-BOTTLES-WOODEN-CRATES-1-35-by-Mini-Art-35574-/302299773031?hash=item4662787867:g:CNsAAOSwlndZBLBl
m4sherman
Posted: Sunday, May 21, 2017 - 09:09 AM UTC
I was thinking more like the boxes seen here:
It is unlikely there would be a lot of beer available. Boxes of green beans would be more likely.
Knuckles
KitMaker: 525 posts
Armorama: 266 posts
Posted: Sunday, May 21, 2017 - 09:22 AM UTC
http://www.ebay.com/itm/Black-Dog-1-35-Food-Supplies-Crates-and-Barrels-Accessories-Set-Diorama-T35041-/170809287678?hash=item27c506e3fe:g:rF8AAOxy2E1SF806
This and some Blue Stuff & Miliput will make you a trainload.
m4sherman
Posted: Sunday, May 21, 2017 - 07:29 PM UTC
I don't think the poor T3 could handle a train load!
I did find this searching for food boxes on e-bay:
http://www.ebay.com/sch/i.html?_from=R40&_trksid=p4738.m570.l1313.TR0.TRC0.H0.TRS5&_nkw=DAN+models+35216+Packing+%28Cigarettes%2C+humanitarian+aid%2C+food%2C+a+box+of+bananas%29+&_sacat=0
A deeper search yielded more, priced at 3.99! Including another set with similar boxes that will work. Now I have a couple weeks to wait, snail mail from the Ukraine. That will give me time to figure out the best way to make green beans from stretched sprue. Lucky for me I have a lot of green plastic scrap!
Knuckles
KitMaker: 525 posts
Armorama: 266 posts
Posted: Thursday, May 25, 2017 - 10:54 AM UTC
Now things are getting pretty exciting...
ClaytonFromEllijay
#454
KitMaker: 1,273 posts
Armorama: 1,138 posts
Posted: Thursday, May 25, 2017 - 06:50 PM UTC
What have you got going there, Christian? It looks like a block of obsidian!
Removed by original poster on 05/26/17 - 14:40:09 (GMT).
Removed by original poster on 05/26/17 - 14:47:10 (GMT).
Knuckles
KitMaker: 525 posts
Armorama: 266 posts
Posted: Thursday, May 25, 2017 - 08:38 PM UTC
A styrene tub filled with balls of tin toil and covered with plaster, sprayed with gloss primer,
and then getting the mud:
Couldn't sleep, so I got in 3 hours on the base this morning before work.
petbat
KitMaker: 3,353 posts
Armorama: 3,121 posts
Posted: Friday, May 26, 2017 - 08:05 AM UTC
Yeah, the artillery rounds exploding around you will do that. Also, just when you think you can doze off, the Dawn Patrol comes buzzing past too
Looking excellent Christian. The weathering is fantastic.
Randall, to make green beans, use a bit of two part putty. Mix it up and then roll a small quantity into a thin sausage. Break that into smaller bits and roll that til the right size, making sure to roll the ends to a taper. Curve them a bit and let them harden.
You do similar for carrots but push a bit of stretched sprue in the top before they cure. Bundle them together gluing the sprue segments together to form a bunch. Then mix some PVA glue (white Glue) and water together to thin it a bit, soak the top of the carrot bunch in that and then dip in chopped up dried herbs (parsley is good). You may need to repeat the herbs. When dry paint them. It's easy and the colour gives a good contrast.
You can make tomatoes out of the putty too, again roll into a ball, push a bit of sprue (or a craft knife blade). in the top to form the valleys. If you shape the sprue you can press that into another tomato and that into another and have a series on the vine. Bits of paper can form the small leaves at the top of the tomato.
Same for apples but stick the sprue in and leave it. When dry add a bit of parsley or a piece of cut paper to the sprue of some to represent a leaf on the stem. It adds some character.
petbat
Posted: Friday, May 26, 2017 - 08:39 AM UTC
I had not intended to start this kit until I finished some other GB's I'm in, but the wife was in a 'come sit with me' phase this week, so while she watched her TV shows I commenced the Gepard.
Some turret work (the gun pods are loose fitting for the pic)
The hull sections:
and the wheels and tracks. Guess which bag is the cleaned up up track segments and which isn't. At least there are not as many to do, even with the separate connectors and guide horns, as the Hobby Boss SdKfz 254.
Knuckles
KitMaker: 525 posts
Armorama: 266 posts
Posted: Friday, May 26, 2017 - 08:53 AM UTC
Wait...it's just a phase?
I divorced all 3 of mine. Sh*t.
petbat
Posted: Friday, May 26, 2017 - 09:09 AM UTC
So three times in not a charm then. I'll have to remember that if Ms no 2 goes sour on me...
I presume you have learned the wisdom of not going for a 4th.....
Knuckles
KitMaker: 525 posts
Armorama: 266 posts
Posted: Friday, May 26, 2017 - 09:15 AM UTC
Oh yeah--my time is more enjoyed at my bench nowadays.
m4sherman
Posted: Sunday, May 28, 2017 - 03:49 AM UTC
Thanks for the tips.
canismalus
#465
KitMaker: 398 posts
Armorama: 394 posts
Posted: Sunday, May 28, 2017 - 06:06 PM UTC
Hey everybody -
Nice builds coming along - Christian, that Mk. IV looks pretty wicked. I finished build my Gepard a couple of days ago (except for the tracks, I always finish them right before/while I'm starting to paint.) Sorry that the hue in these pictures is weird - I took them outside in the shade and increased the brightness so details were visible:
I actually wanted to prime/preshade/get the base coat on this cat this past weekend but I discovered the part in my airbrush in the back that clasps the needle (the chuck/collet?) was bent beyond recovery and now I'm waiting for the new part to come in the mail. More pics to follow.
Jerry
imransz
Singapore / 新加坡
KitMaker: 38 posts
Armorama: 37 posts
Posted: Sunday, May 28, 2017 - 08:15 PM UTC
a little updates..
Knuckles
KitMaker: 525 posts
Armorama: 266 posts
Posted: Monday, May 29, 2017 - 06:36 AM UTC
DONE!
1/35 Takom Mk IV Hermaphrodite. British livery, somewhere in France in the mud. LOTS of products used to give this one an over-the-top, grittiness.
Based off of this photo:
And this is what I've got:
Armorsmith
Posted: Monday, May 29, 2017 - 07:03 AM UTC
Outstanding Knuckles. Captures the grittiness of the WWI battlefield very nicely even without no mans land and the trenches.
Thirian24
KitMaker: 2,493 posts
Armorama: 2,344 posts
Posted: Monday, May 29, 2017 - 04:56 PM UTC
Wow. That's outstanding. Congrats on the beautiful finish.
bulldawg380
KitMaker: 347 posts
Armorama: 338 posts
Posted: Monday, May 29, 2017 - 06:29 PM UTC
OUT #$-@$# STANDING looks great
ClaytonFromEllijay
#454
Posted: Monday, May 29, 2017 - 08:12 PM UTC
Great job, Christian, super build!
