Constructive Feedback
T-35 Soviet gigant
habouji
Jihocesky Kraj, Czech Republic
KitMaker: 45 posts
Armorama: 45 posts
Posted: Sunday, December 17, 2017 - 01:41 AM UTC
my new work are heavy Soviet multituret tank. From ICM and PE part Eduard
many wheals :-)
little bend here
here is scale its really huge
start motor and driver position
some part are improvment
paited motor and manifold by wire
compled motor and gearbox
this be visible
and some turet
some weld and PE part
Gun turet
weld and little update from Evegreen profile
KoSprueOne
Myanmar
KitMaker: 4,011 posts
Armorama: 1,498 posts
Posted: Sunday, December 17, 2017 - 04:22 AM UTC
Ok, looking good esp with your added details.
ColinEdm
KitMaker: 1,355 posts
Armorama: 1,229 posts
Posted: Sunday, December 17, 2017 - 05:35 AM UTC
Good stuff, I've always liked these beasts.
JSSVIII
KitMaker: 1,169 posts
Armorama: 1,067 posts
Posted: Sunday, December 17, 2017 - 05:36 AM UTC
Good start Jan, nice weld beads, I wish there were photos of the interior of the real thing, or at least the turrets. You would be able see quite a bit of the turret interior through those hatches.
habouji
KitMaker: 45 posts
Armorama: 45 posts
Posted: Sunday, December 17, 2017 - 09:09 PM UTC
unfortunately this kit has no interior. I completed the main turret there is a detail more.
It´s hard find interior photo
habouji
KitMaker: 45 posts
Armorama: 45 posts
Posted: Monday, December 18, 2017 - 05:46 PM UTC
i completed main gun turet.
spongya
MODELGEEK
Budapest, Hungary
KitMaker: 2,365 posts
Armorama: 1,709 posts
Posted: Monday, December 18, 2017 - 05:52 PM UTC
Just wow.
habouji
KitMaker: 45 posts
Armorama: 45 posts
Posted: Tuesday, December 26, 2017 - 08:16 PM UTC
reworked aerial
new headlight + latch and PE horn
adding mising nuts and failsafe wire
20 ton jack and compled reworked and adding nuts and weld
on this kit is bad loophole (for T28) in T35 there is photo
habouji
KitMaker: 45 posts
Armorama: 45 posts
Posted: Saturday, December 30, 2017 - 03:35 PM UTC
little progres
Muftyman
Praha, Czech Republic
KitMaker: 29 posts
Armorama: 18 posts
Posted: Saturday, December 30, 2017 - 04:04 PM UTC
Hi Jan
Nice progress being made. I'm following with interest.
Greetings from Prague
Tobias5555
Hessen, Germany
KitMaker: 446 posts
Armorama: 445 posts
Posted: Saturday, December 30, 2017 - 08:37 PM UTC
Great updates on this Monster.
Scarred
KitMaker: 1,792 posts
Armorama: 1,186 posts
Posted: Saturday, December 30, 2017 - 10:01 PM UTC
What a beast from someone's warped mind. And it's looking great!
Posted: Monday, January 01, 2018 - 04:22 PM UTC
Impressive detailing!
habouji
KitMaker: 45 posts
Armorama: 45 posts
Posted: Tuesday, January 02, 2018 - 01:42 AM UTC
Thank you all for the nice comments, I'm happy that you like my work!
dutik
Germany
KitMaker: 134 posts
Armorama: 134 posts
Posted: Tuesday, January 02, 2018 - 03:09 AM UTC
Very impressive! Your added details bring this old kit to new life!
Watching with interest
Dioramartin
KitMaker: 1,476 posts
Armorama: 1,463 posts
Posted: Tuesday, January 02, 2018 - 03:43 PM UTC
I agree with everyone Jan – this land-battleship is looking superb thanks to your excellent detailing. It really deserves to star in a diorama with figures, to emphasise it’s size
Posted: Tuesday, January 02, 2018 - 07:52 PM UTC
Hi Jan,
Many years ago I built both the T-35 and IT-28 from ICM.
One of them, and I do not remember which one, had problems with how the track fitted over the sprocket wheel.
With one track link on each tooth there was a gap between the links. I "solved" this by reducing the diameter of the sprocket until the links would join to form a continous track.
There was some kind of edge/shelf inside of the teeth which I filed down and then I had to file down the teeth as well.
sgtreef
KitMaker: 6,043 posts
Armorama: 4,347 posts
Posted: Wednesday, January 03, 2018 - 04:47 PM UTC
Nice work bringing this early kit up to par.
Pushing the bar up, and glad after what you have to do, I am not trying one. LOL
Great job.
habouji
KitMaker: 45 posts
Armorama: 45 posts
Posted: Wednesday, January 03, 2018 - 05:11 PM UTC
Hi Jan,
i wan using Fruil metal track I hope there will be no problem
habouji
KitMaker: 45 posts
Armorama: 45 posts
Posted: Monday, January 15, 2018 - 12:55 AM UTC
here little progres
habouji
KitMaker: 45 posts
Armorama: 45 posts
Posted: Monday, January 29, 2018 - 06:43 PM UTC
and start coloring and fading and wash
VMIVince
North Dakota, United States
KitMaker: 42 posts
Armorama: 36 posts
Posted: Friday, February 09, 2018 - 10:09 PM UTC
Great work. I'm curious, what technique do you use to recreate those beautiful weld lines? Thinned putty in a syringe?
C[ ]
habouji
KitMaker: 45 posts
Armorama: 45 posts
Posted: Sunday, February 11, 2018 - 01:22 AM UTC
Thank you! I use two ways to make the weld lines. Either I roll a very thin thread out of the putty (I use Miliput) and then use a toothpick (I cut the tip to make it sharper and narrower) to create the weld texture. Or I cut a piece of the plastic frame left over after taking out all the model parts, I heat it above a flame (normal candle) and stretch it to get a thin line. I lay this on the place where I want to have the weld, tap some thinner over it to soften it and use some metal round-pointed tool to form the weld structure. The putty is good for corner welding while the other technique is better for rims and edges.
habouji
KitMaker: 45 posts
Armorama: 45 posts
Posted: Tuesday, February 20, 2018 - 04:07 PM UTC
and finaly photo. This tank is really monster
210cav
KitMaker: 6,149 posts
Armorama: 4,573 posts
Posted: Wednesday, February 21, 2018 - 03:38 AM UTC
Jan-- Outstanding workmanship
Very well done
DJ
