Civilized Beasts
ReluctantRenegade
Solomon Islands
KitMaker: 1,929 posts
Armorama: 1,916 posts
Posted: Saturday, January 06, 2018 - 02:53 PM UTC
Ex-military vehicles in civilian service. Feel free to contribute, just please number the pictures according to the sequence.
T-34 based Czech bulldozer (en.valka.cz)...
1.
...and it's IS based bigger brothers
2.
3.
4.
5.
6.
7.
8.
9.
There's a T-55 variant too
10.
11.
12.
ReluctantRenegade
Solomon Islands
Posted: Saturday, January 06, 2018 - 03:02 PM UTC
Various Sherman based drilling/logging equipments
13.
14.
15.
16.
17.
18.
19.
20.
21.
22.
23.
24.
25.
26.
27.
ReluctantRenegade
Solomon Islands
Posted: Saturday, January 06, 2018 - 03:26 PM UTC
M4 based variant
28.
29.
30.
What running gear is this?
31.
32.
33.
ReluctantRenegade
Solomon Islands
Posted: Saturday, January 06, 2018 - 03:48 PM UTC
Russian 'Berge' T-55
34.
35.
36.
37.
38.
39.
40.
41.
42.
ReluctantRenegade
Solomon Islands
Posted: Saturday, January 06, 2018 - 04:01 PM UTC
T-34 based extra-terrestrial firefighter...
43.
...and it's T-55 based bigger brother.
44.
45.
46.
ReluctantRenegade
Solomon Islands
Posted: Saturday, January 06, 2018 - 04:14 PM UTC
Other T-55 based fire-fighting equipment
47.
48.
49.
50.
51.
52.
Bravo1102
KitMaker: 2,305 posts
Armorama: 1,987 posts
Posted: Saturday, January 06, 2018 - 07:19 PM UTC
15, 16 and 17 have Sherman HVSS suspension with replaced springs. Some enterprising soul replaced the drive sprocket rings so it could use T142 M60 track.
One Sherman based one has four bogie units! The ones with the dropped rear idler could be M4A4 Israeli M50 based or extended suspensions to bear the weight of the huge rigs on top.
Some Sherman based ones look like they just used the track and bogie units on new extended and widened hulls. It also looks like some of the road wheels had their rubber removed as opposed to chunked off from wear.
And #31? I don't think there is one base running gear there, it looks cobbled together from bits and pieces. Some bits look like they came from an M24 or M41 and others?
corsutton
KitMaker: 540 posts
Armorama: 507 posts
Posted: Sunday, January 07, 2018 - 12:45 AM UTC
Love 44, 45, 46. The "Big Wind". Google "T-55 Big Wind" for some cool videos.
ReluctantRenegade
Solomon Islands
Posted: Sunday, January 07, 2018 - 01:07 AM UTC
The T-34 and its Hungarian firefighter team was deployed to Kuwait after Saddam Hussein set the oilfields on fire.
KitMaker: 11,609 posts
Armorama: 11,407 posts
Posted: Sunday, January 07, 2018 - 01:43 AM UTC
Converted M3 Stuart in Australia :
53
54
55
56
57
Sherman crawler tractor :
58
59 :
ReluctantRenegade
Solomon Islands
Posted: Sunday, January 07, 2018 - 01:47 AM UTC
Thanks, Frenchy! Could you please just number them for discussion purposes?
Posted: Sunday, January 07, 2018 - 02:04 AM UTC
More conversions from Down Under. Matilda-based dozers:
60
61
ReluctantRenegade
Solomon Islands
Posted: Sunday, January 07, 2018 - 02:06 AM UTC
Another conversion from Down Under. Matilda-based dozer
Wow, I didn't see this one coming! I wonder when this picture was taken...
Posted: Sunday, January 07, 2018 - 02:11 AM UTC
I've found #60 here
Valentine-based...What ?
62
63
ReluctantRenegade
Solomon Islands
Posted: Sunday, January 07, 2018 - 02:16 AM UTC
And I thought Australian Matildas in Borneo in '45 was an oddity...I guess that bulldozer went through quiet a lot in its life...
Posted: Sunday, January 07, 2018 - 02:27 AM UTC
Maybe the Valentine was used as a tree-crusher...
More Sherman-based crawler tractors :
64
65
According to the caption , the crane on the left is a NCK 205 on on a Chieftain chassis and the other is a Jones KL 11-7 on a Centurion chassis.
66
Das_Abteilung
KitMaker: 355 posts
Armorama: 341 posts
Posted: Sunday, January 07, 2018 - 04:09 AM UTC
Some interesting oddities in here, some of which I've seen before on other sites.
10-12 are interesting because that T-55 is clearly an airfield snow plough. But it's running on all-steel tracks, and so will tear up the tarmac!
13-27 are mostly forestry vehicles, some missing their various booms and arms. Many of them - certainly the red ones - look like products of the Canadian company Madill.
28-30 are based on the M4 HST, to be clear that it isn't the M4 tank.
The suspension in 31-33 looks strange because, in addition to replacing the HVSS springs with coil springs, the bogie shock absorbers have been removed and the wheels replaced with solid steel ones. The rear road wheel and idler are from an M26-48. The standard Sherman HVSS sprocket should have been compatible with that track type, but might indeed have needed the ring changed.
66 shows the 2 Kirkudbright Cranes, the first one being a Centurion chassis and the second a Chieftain as noted. They were used at the British MOD (PE) experimental firing range at Kirkcudbright in South West Scotland. It's a coastal range covering several thousand acres and something capable of operating on land, dunes, beach and shallow wading all at a decent speed was needed, hence building these special vehicles rather than just buying a commercial mobile crane. One of their main uses was positioning heavy target armour slabs for penetration testing. When that range closed as an experimental station and became a general firing range they may have been transferred to Eskmeals on the Cumbria coast, but were more likely sold.
Das_Abteilung
KitMaker: 355 posts
Armorama: 341 posts
Posted: Sunday, January 07, 2018 - 04:57 AM UTC
Here are some more forestry-type conversions.
67. This is one of the Really Big Madill Yarders
68. This is apparently a recovery tractor for forestry vehicles.
69. This is a LeTourneau-built scrapyard crane.
70. This thing is allegedly also LeTourneau, and is clearly on an Allis Chalmers M8 HST chassis. Enormous backhoe excavator. Looks hugely top heavy and overloaded.
71. Another cut-down M8-based thing, possibly another forestry tractor
Das_Abteilung
KitMaker: 355 posts
Armorama: 341 posts
Posted: Sunday, January 07, 2018 - 05:08 AM UTC
Here are some pics of the Shervick tractor. This was a UK post-war government-funded scheme by Vickers to convert M4A2s into agriculural tractors, primarily for use in Africa (although the last known survivor was in Belgium before scrapping).
Bizarrely, because the M4A2 GM 6-71 engines were "handed" left and right - although capable of being configured either way - Shervicks also appeared in left and right handed versions with the engine exhaust and air intakes reversed. Not also double return rollers on rear bogie.
72.
73.
74.
75.
76.
77.
78.
79.
80.
Removed by original poster on 01/08/18 - 00:18:41 (GMT).
Das_Abteilung
KitMaker: 355 posts
Armorama: 341 posts
Posted: Sunday, January 07, 2018 - 05:17 AM UTC
This image was tagged as a Sherman but is in fact an Australian Sentinel chassis. There were several hundred surplus at the end of WW2. Conversions of old tanks seems to have been commonplace in Australia: Stuarts, Lees, Matildas, Valentines, Sentinels all pop up.
81.
Das_Abteilung
KitMaker: 355 posts
Armorama: 341 posts
Posted: Sunday, January 07, 2018 - 05:20 AM UTC
This very poor photo is a forestry conversion of an M3 Lee, or a very early M4.
82.
This was an attempt by the old British company Rotinoff to make commercial M4-based dozers, probably on M4A2 again.
83.
m75
KitMaker: 562 posts
Armorama: 557 posts
Posted: Sunday, January 07, 2018 - 05:43 AM UTC
Talk about some extreme weathering examples!!
bat-213
Canada
KitMaker: 902 posts
Armorama: 788 posts
Posted: Sunday, January 07, 2018 - 05:47 AM UTC
kool pics,my dad was a driller blatster and he used acut down bren gun carrier,but no pics .
firstcircle
KitMaker: 2,140 posts
Armorama: 1,904 posts
Posted: Sunday, January 07, 2018 - 05:52 AM UTC
84 Panther crane
85 FV432 funeral hearse
