Tiger I Early Friul ATL-25 Question
Brianlee
KitMaker: 199 posts
Armorama: 198 posts
Posted: Monday, January 22, 2018 - 10:50 PM UTC
First time I've done these for a Tiger I - the Pz II/Pz III & IV are all easy to see orientation based on photos, but which direction are tracks supposed to be on the finished model?
Does that make sense?
d6mst0
#453
KitMaker: 1,925 posts
Armorama: 601 posts
Posted: Tuesday, January 23, 2018 - 01:10 AM UTC
If you look on the drawing on the box there is a small extension on the end of the track link. This extension goes on the outside, not on the inside. You can clearly see it in the photo of the tank and track links.
Byrden
Wien, Austria
KitMaker: 2,233 posts
Armorama: 2,221 posts
Posted: Tuesday, January 23, 2018 - 02:38 AM UTC
They go in different directions on each side of the tank. And they will fit only one way on the sprocket so you can't go wrong.
David
Brianlee
KitMaker: 199 posts
Armorama: 198 posts
Posted: Tuesday, January 23, 2018 - 10:31 AM UTC
Ah ok - I understand the orientation so they will have to be right when the overhang is on the outside and my clipped / glued pins on the inside
Got it
On this subject, I've never done these on a non-return roller tank. Do you guys link them fairly taught with a little sag. I know I can just look at pictures
GazzaS
#424
KitMaker: 4,648 posts
Armorama: 2,248 posts
Posted: Tuesday, January 23, 2018 - 10:40 AM UTC
The Tiger's tracks were very heavy. If you look at a few photos, you'll see that the tracks sits on top of almost all of the roadwheels.
Gaz
Brianlee
KitMaker: 199 posts
Armorama: 198 posts
Posted: Tuesday, January 23, 2018 - 11:16 AM UTC
Not much sag really at all I suppose. Will the workable links make it look inauthentic unless the runs are basically straight over the tops of the road wheels?
SpeedyJ
Bangkok, Thailand / ไทย
KitMaker: 1,617 posts
Armorama: 1,150 posts
Posted: Tuesday, January 23, 2018 - 11:30 AM UTC
Hi.
Heavy it is.
A single combat track link (including pin) has a weight of 30,11KG. That is about 2,8 Tons for each side (with 96 links)
The weight for transport track link (including pin) is 21,09KG. Will be about 1,9 Tons for each side (with 96 links)
RJ
Brianlee
KitMaker: 199 posts
Armorama: 198 posts
Posted: Thursday, January 25, 2018 - 09:07 PM UTC
So I'm still a tad confused about the direction of the tracks .... I'm keeping my built sections separate but even with the pins on the inside, still not sure which direction.
Any front looking (or any appropriate angle) photos illustrating the direction would be great for ATL-25 type Early tracks
Brianlee
KitMaker: 199 posts
Armorama: 198 posts
Posted: Sunday, January 28, 2018 - 04:03 AM UTC
Bump for any picts/diagrams illustrating the direction for atl-25
BunkerBuster
KitMaker: 157 posts
Armorama: 122 posts
Posted: Sunday, January 28, 2018 - 06:58 AM UTC
Tiger 1 early tracks are not handed. They only fit one way on the sprocket and the left and right sides are interchangeable. The guide horns are offset to the inside of the links, so they go on the side nearest the tank hull.
The Tiger I "initial" track configuration was handed, so they are mirrored. I believe there were very few tanks delivered with the mirrored tracks, and even those would have been changed out to the non-mirrored tracks after the originals wore out.
Brianlee
KitMaker: 199 posts
Armorama: 198 posts
Posted: Monday, January 29, 2018 - 05:07 AM UTC
But these are in two different bags so there is a left/right ..... right? Still trying to post the pics of two runs, side by side, so you guys can confirm. Can I send them to someone to post here???
TopSmith
KitMaker: 1,742 posts
Armorama: 1,658 posts
Posted: Monday, January 29, 2018 - 07:06 PM UTC
1. Have you assembled the track already?
2. Look online at pictures of tiger tanks. In this case the Bovington tiger will do fine. Look at the front view of the tank and observe for track orientation.
3. They should only fit one way.
4. Sag amount is a personal choice look at different Tiger photos and decide which is best.
5. If you have already glued the suspension together then the only sag adjustment will be to add or take away links.
AgentG
KitMaker: 1,109 posts
Armorama: 1,095 posts
Posted: Monday, January 29, 2018 - 08:59 PM UTC
easyco69
KitMaker: 2,275 posts
Armorama: 2,233 posts
Posted: Monday, January 29, 2018 - 10:57 PM UTC
keep measuring as you get closer to the length needed...don't add too many links..get it just right .
TopSmith
Posted: Tuesday, January 30, 2018 - 12:32 AM UTC
There is no left/right versions in your case.
Brianlee
KitMaker: 199 posts
Armorama: 198 posts
Posted: Tuesday, January 30, 2018 - 02:29 AM UTC
I have assembled most of one side and half the other - ive worked with Friuls before but for some reason, I cant tell which direction.
It's obvious on the Pz II, Pz III & Pz 4 ---- even the mid/late Tiger tracks have those angled marks on the cleats to go off of.
Brianlee
KitMaker: 199 posts
Armorama: 198 posts
Posted: Tuesday, January 30, 2018 - 02:31 AM UTC
Nice --- that pic should help
