Constructive Feedback
corugated steel
drabslab
European Union
KitMaker: 2,186 posts
Armorama: 190 posts
Posted: Monday, June 11, 2018 - 07:00 PM UTC
Hoi,
Just a small reference as I see many of you search for ideas to make corugated steel:
corugated
its a tool used in barbershops to squeeze tubes of substances empty
I have seen something like this used for( makign corugated steel for a WW 1 diorama. Mainly, there are two types, made of plastic (not good) or made of metal (much better).
I can't immediately fidn a metal one but in case you are interested I suppose at least one AFV builder should have someone near that is a hairdresser
drabslab
European Union
Armorama: 190 posts
Posted: Monday, June 11, 2018 - 07:03 PM UTC
got it
HermannB
Bayern, Germany
KitMaker: 4,099 posts
Armorama: 4,067 posts
Posted: Monday, June 11, 2018 - 07:14 PM UTC
Hopefully, it has the right wave pattern for Wellblechplatten.
Vicious
KitMaker: 1,517 posts
Armorama: 1,109 posts
Posted: Monday, June 11, 2018 - 07:20 PM UTC
I have the same one in aluminium buy for couple of bucks from aliexpresss it works well with aluminium foil with perfect pattern
HermannB
Bayern, Germany
Posted: Monday, June 11, 2018 - 07:22 PM UTC
Brief history of Galvanized Corrugated Iron.
https://en.wikipedia.org/wiki/Corrugated_galvanised_iron
Vicious
Posted: Monday, June 11, 2018 - 07:36 PM UTC
i have this one
https://www.aliexpress.com/item/Aluminum-Tube-Squeezer-Dispenser-Tool-For-Squeezing-Hand-Cream-Toothpaste-Hair-Dyes-Unguent-Bathroom-Accessories/32858232634.html?spm=2114.search0104.3.1.692668d7nAc3gF&ws_ab_test=searchweb0_0,searchweb201602_5_10152_10151_10065_10344_10130_10068_10547_10342_10343_10340_10548_10341_10696_10084_10083_10618_10307_10131_10132_10133_10059_100031_10103_10624_10623_10622_10621_10620,searchweb201603_11,ppcSwitch_7&algo_expid=568bf1f2-7eb5-4d86-9d9a-bb7c1c4aacb9-0&algo_pvid=568bf1f2-7eb5-4d86-9d9a-bb7c1c4aacb9&priceBeautifyAB=0
depending on the pressure and the material, it is possible to come out not enough rounded the shape but just go over with a tool of the right shape to be perfect
sgtreef
KitMaker: 6,043 posts
Armorama: 4,347 posts
Posted: Tuesday, June 12, 2018 - 01:01 AM UTC
Small shop has one made in resin.
And use lead sheet, or real thin aluminum.
zorrolobo
Distrito Federal, Mexico
KitMaker: 1,457 posts
Armorama: 1,440 posts
Posted: Tuesday, June 12, 2018 - 02:46 AM UTC
Mine is home made and works just fine:
obg153
KitMaker: 1,063 posts
Armorama: 1,049 posts
Posted: Tuesday, June 12, 2018 - 03:24 AM UTC
Or you might check this out: Many packages of cookies/crackers/candy, etc., have dividers or tray sections (some in thin plastic) which closely resemble corrugated metal. Many cardboard boxes have corrugated "innards," you just dampen the outer layers of paper, carefully peel them away, and you're left with "corrugated" material. May take some searching for the right size, but then you have some munchies to nibble on while you're building.
Posted: Tuesday, June 12, 2018 - 12:50 PM UTC
One word: Suydam
KitMaker: 1,112 posts
Armorama: 886 posts
Posted: Thursday, June 14, 2018 - 11:14 PM UTC
https://masterpiecemodels.com/product/35th-the-corr-u-gator/
or
http://umm-usa.com/onlinestore/product_info.php?cPath=21_102&products_id=64
HTH
JClapp
#259
KitMaker: 2,265 posts
Armorama: 180 posts
Posted: Friday, June 15, 2018 - 11:13 AM UTC
yup
JPTRR
RAILROAD MODELING
#051
KitMaker: 7,772 posts
Armorama: 2,447 posts
Posted: Friday, June 15, 2018 - 11:33 AM UTC
Johnathan,
Those are great!
sgtreef
Posted: Sunday, June 17, 2018 - 11:58 PM UTC
https://masterpiecemodels.com/product/35th-the-corr-u-gator/HTH
That is the one good deal, and extra material can be had at the small shop which also sells the tool,as takes up to 2 weeks to make and ship. Seems they stopped selling the tool, but have the sheet, which might seem high for a 6 X 6 sheet,but lead and micro thin , also Dick Blick has metal sheet also, aluminum.
https://www.dickblick.com/products/amaco-artemboss-metal-sheets/
https://thesmallshop.com/collections/photo-etch-rolling-and-forming-tools/products/sms010-extra-foil-for-nutter-set-6-x-6
