Constructive Feedback
LAVIII TUA, no slip surface texture?
GCaughill
KitMaker: 2 posts
Armorama: 4 posts
Posted: Monday, August 06, 2018 - 03:07 PM UTC
Can anyone point me in the right direction for a good technique for anti slip on the LAV’s? I’ve seen the Gesso trick but just curious of others.
Anyways here’s some pics, haven’t been on here in over ten years...!
[img]https://gallery.kitmaker.net/data/31444/thumbs/435F6F3C-8C61-4E75-A631-22F0C9289CBF.jpeg" BORDER="0">/image.file[/img]
[img]https://gallery.kitmaker.net/data/518/thumbs/4D0BCF85-CE50-449F-8DCB-B070AE69D62C.jpeg" BORDER="0">/image.file[/img]
[img]https://gallery.kitmaker.net/data/518/thumbs/87B3AC83-3C6D-458A-9C52-FF5E00DFD903.jpeg" BORDER="0">/image.file[/img]
LeoCmdr
KitMaker: 4,085 posts
Armorama: 3,917 posts
Posted: Monday, August 06, 2018 - 03:20 PM UTC
An easy tried and true technique is Rustoleum Fine Textured Spray. Common colours are grey and terracotta.
If you take the time to properly mask off the areas the textured spray looks very realistic.
There are several grades of texture as well....stick with the fine texture as you can always spray on another light coat if you want more representation.
Check Loews, Home Depot, and Rona and you’ll find it.
Good luck finishing your LAV III TUA!
GCaughill
KitMaker: 2 posts
Armorama: 4 posts
Posted: Monday, August 06, 2018 - 03:43 PM UTC
Great, thanks for the tip!
Sandbox
KitMaker: 350 posts
Armorama: 158 posts
Posted: Monday, August 06, 2018 - 11:55 PM UTC
I have used the Rustoleum product on a Challenger I in progress and I think it looks spot on.
varanusk
KitMaker: 1,288 posts
Armorama: 942 posts
Posted: Tuesday, August 07, 2018 - 01:39 AM UTC
Hi Graeme,
Welcome back, VMS offers a couple of products that seem to have good results:
https://www.vms-supplies.com/vms-hull-tex
https://www.vms-supplies.com/vms-hull-tex-air
Posted: Tuesday, August 07, 2018 - 02:41 AM UTC
Rustoleum texture spray works great every time.
Adding anti-slip texture to modern armor.
GulfWarrior
KitMaker: 1,051 posts
Armorama: 1,029 posts
Posted: Tuesday, August 07, 2018 - 03:23 AM UTC
I shamelessly copied Gino's method and made a PowerPoint presentation I gave to my club back in 2011.
https://drive.google.com/file/d/0B1WixOlKiz5Zbk9pTkpSRk9Ua1U/view?usp=sharing
Posted: Tuesday, August 07, 2018 - 09:42 AM UTC
Nice tutorial. Good job on it.
GCaughill
KitMaker: 2 posts
Armorama: 4 posts
Posted: Tuesday, August 07, 2018 - 11:06 AM UTC
Richard S.
Thank you very much for that lesson, very straightforward. Just returned from the local hardware store with no luck but will try the Home Depot later this week.
My fighting LAV just arrived in the mail so I am eager to get the anti slip process sorted out.
Thanks for all the kind words.
Sandbox
KitMaker: 350 posts
Armorama: 158 posts
Posted: Tuesday, August 07, 2018 - 11:27 PM UTC
I got my supply of Rustoleum from Home Depot but had to order on line and pick up at my local store.
GulfWarrior
Posted: Wednesday, August 08, 2018 - 01:34 AM UTC
Thanks Gino!
Richard S.
The terra cotta paint is like that one bottle of Future we all still have. You only need a little bit so one can should last a loooooooong time. It didn't take too long for me to figure out that I could use white Elmer's glue on stuff like bolt heads. I wouldn't want to get it near any seams though. It might be a bear to get out completely.
GulfWarrior
Posted: Wednesday, August 08, 2018 - 08:58 AM UTC
Hey Gino! Whatcha think of this?!
https://www.businessinsider.com/watch-the-army-test-its-new-105mm-hawkeye-humvee-mounted-howitzer-2018-8
Posted: Tuesday, August 14, 2018 - 12:41 AM UTC
Hmm, sounds interesting. The lower rate of fire could be a problem though. The current M119A1 105mm howitzers and 120mm mortars don't take very long at all to set up, so I am not really sure this gives that much advantage.
