Scale Modeling Sponsors
See Your Ad Here!
DAK colours?
phantom_phanatic309
#372
KitMaker: 2,080 posts
Armorama: 335 posts
Posted: Tuesday, August 07, 2018 - 04:56 AM UTC
Got a couple of Afrika Korps vehicles I'm planning on starting and just wondering what colours I should use for the base sand colour.
From what I can tell its a different shade to the usual dark yellow seen in Russia and Europe.
My lhs stocks Vallejo, Mig, Revell, Humbrol, Tamiya and Gunze.
Thanks in advance.
Removed by original poster on 08/19/18 - 10:00:03 (GMT).
brekinapez
KitMaker: 1,321 posts
Armorama: 1,195 posts
Posted: Tuesday, August 07, 2018 - 05:10 AM UTC
At the very beginning you would have gray vehicles that were overpainted with some paints obtained from Italian stocks or simply smeared with mud and dirt to hide the gray.
When they began painting desert camo at the factory, in the early part of the war it would be RAL 8000 with RAL 7008 covering about a third of it as the camo pattern. In March 1942 that was switched to RAL 8020 with RAL 7027 as the 1/3 color.
Removed by original poster on 08/08/18 - 11:56:10 (GMT).
phantom_phanatic309
#372
Armorama: 335 posts
Posted: Tuesday, August 07, 2018 - 05:21 AM UTC
It's the old tool Tamiya Pzkpfw II and Sdkfz. 251. Had them for ages and want to get them built and they'll make good guinea pigs for practicing shading and weathering. Been years since I've done a tank.
Thanks I'll have to cross reference those with the paint ranges. I'm not very familiar with the ral system.
Removed by original poster on 08/19/18 - 09:58:39 (GMT).
brekinapez
Posted: Tuesday, August 07, 2018 - 07:17 AM UTC
You could do an image search for the RAL colors and see if you already have something close; I wouldn't worry about an exact match as long as it seems pretty close.
I tend towards Tamiya and Vallejo paints myself, but almost every big paint company has their version.
AgentG
KitMaker: 1,038 posts
Armorama: 1,024 posts
Posted: Tuesday, August 07, 2018 - 10:24 AM UTC
Tamiya mix for RAL 8000
50/50 Flat Earth and Dark yellow. Add drops of Yellow Green to suit.
RAL 7008
Tamiya Khaki with a drop or two of OD. Then add Yellow Green a drop at a time until it's tone matches that of your RAL 8000.
phantom_phanatic309
#372
Armorama: 335 posts
Posted: Tuesday, August 07, 2018 - 12:38 PM UTC
In that case, since Tamiya Panzer II is ausf. F and Sd.Kfz. 251 is ausf. C, you can go for factory painted Ral 8000, without gray under. Now, I can't tell you which colour to use for Ral 8000 because I use only Revell Aqua. Maybe someone can help?
Thanks. I'll keep that in mind as one thing I wanted to try was sand blasted chipped paint down to the dark grey. Maybe another time perhaps.
I've had a look and it does appear that Mig do all of those suggested colours straight out of the bottle. I'll also make a note of mixing suggestions to vary the finishes.
The colours are a lot more subtlety different to each other than I would have thought. I'm a lot more used to british dessert schemes that had far more contrasting colours. Stone and black for example.
I'll pick up some RAL8000 & 7008 at the weekend and see how it turns out. Just need to research the cammo schemes.
Thanks for the help.
Removed by original poster on 08/19/18 - 09:59:12 (GMT).
Removed by original poster on 08/19/18 - 09:59:31 (GMT).
Removed by original poster on 08/19/18 - 09:59:46 (GMT).
Removed by original poster on 08/19/18 - 10:01:10 (GMT).
AgentG
Posted: Wednesday, August 08, 2018 - 12:21 AM UTC
RAL8000 & 7008
No, that's RAL 8020 with RAL 7008 added as camo. That photo was from the Tunisian campaign and those 251's were brand new.
Removed by original poster on 08/19/18 - 10:01:25 (GMT).
AgentG
Posted: Wednesday, August 08, 2018 - 02:45 AM UTC
And... based on time frame those brand new 251's could have, maybe, been painted in Dark Yellow. That's somewhat of a stretch, but plausible knowing DY was coming as a base color for all vehicles anyway.
Removed by original poster on 08/19/18 - 10:00:56 (GMT).
phantom_phanatic309
#372
Armorama: 335 posts
Posted: Wednesday, August 08, 2018 - 04:51 AM UTC
Sorry BogiBg, I probably caused a bit of confusion with the wording of my question.
You and everyone have been a big help and those references photos are great. Those jerrycan racks on the 251 are certainly something I will try to add.
I might try a weathered and worn early finish on the Panzer II and a later RAL8020 & 7027 finish on the 251.
Thanks for the help
Removed by original poster on 08/19/18 - 10:01:40 (GMT).
AgentG
Posted: Wednesday, August 08, 2018 - 10:10 AM UTC
This post got me confused. Shouldn't it be other way around? I mean, Tiger was brand new, and it was painted RAL 8000 / RAL 7008. which means that it was official scheme at that moment?
It is confusing. Based on the timeline, Tigers should have been painted RAL 8020 with RAL 7027 camo. Instead Tigers were painted in the original tropen colors. I also believe Pz III N's from sPzAbt 501 were also RAL 8000/7008.
Note that the 8000/7008 combo was better suited for the terrain in northern Tunisia.
b2nhvi
KitMaker: 489 posts
Armorama: 420 posts
Posted: Wednesday, August 08, 2018 - 12:49 PM UTC
sPzAbt.501s Tigers were intital production and were built right after the change in regs. But common practice was use up existing stocks first. Actually some had 8020 parts ... storage bin and air filters ... being add on parts.
Removed by original poster on 08/19/18 - 10:02:00 (GMT).
Removed by original poster on 08/19/18 - 10:02:30 (GMT).
Removed by original poster on 08/19/18 - 10:02:45 (GMT).
Removed by original poster on 08/19/18 - 10:03:13 (GMT).
