Dioramas
Survival in the Vidda
Jberardi
KitMaker: 62 posts
Armorama: 55 posts
Posted: Saturday, August 11, 2018 - 11:47 AM UTC
For my next build, I’m venturing back to WWII. I tend to look for compelling stories so I bounce around in time a bit. A few months ago, my son read a book on the various operations carried out by the British and the Norwegians to stop German heavy water production in Vemork in Norway. Operations began with Grouse, an advance team of British-trained Norwegians dropped into the Hardangervidda, a mountain plateau in central southern Norway. Their mission was to pave the way for the British assault team (Gunnerside) that would conduct the assault on Vemork. Grouse began in October 1942 and due to multiple mishaps and setbacks, the Gunnerside team didn’t arrive until February 1943. During that time, the Grouse team was forced to survive the winter in the Vidda.
There was a particular section in the book where the Grouse team found refuge from the elements in a hunting cabin nestled in a copse of birch trees, but they were beginning to starve. Close to Christmas 1942, one of the Grouse team was finally able to track and hunt a herd of reindeer. This build will attempt to capture the moment when the hunter returns with his quarry to the delight of his team.
In the process of assembling kits and working on the size/layout of the cabin. I found an old ICM kit depicting Finnish rifleman in winter. I'll wind up heavily converting these figures and probably scratch building a few as well. I was mainly after the skis and the reindeer.
General cabin layout with one of the Fins for scale
Working with balsa foam to sculpt the rock foundation. More to come...
JordoWiebo
KitMaker: 7 posts
Armorama: 7 posts
Posted: Tuesday, August 14, 2018 - 04:36 AM UTC
Interesting subject matter! Looking good so far, can't wait to see the final product!
KitMaker: 4,602 posts
Armorama: 3,895 posts
Posted: Tuesday, August 14, 2018 - 06:24 AM UTC
Jberardi
KitMaker: 62 posts
Armorama: 55 posts
Posted: Tuesday, August 14, 2018 - 07:09 AM UTC
Thanks Jordan and Robin.
Robin, the image below served as inspiration. It is in Karasjok - the opposite end of Norway - but the same general construction type as those cabins shown in your photos. Seeing that the cabin at the center of the story was built in the prewar 1930's, I'll have to take a liberal amount of artistic license.
Posted: Tuesday, August 14, 2018 - 08:52 AM UTC
Good choice of cabin
Here is what a copse of those birches look like:
Fjällbjörk, Betula pubescens subspecies tortuosa, a subtype of downy birch.
Youtube clip showing some fun that one can have with these small "trees"
https://www.youtube.com/watch?v=ZkqpSPP5WBE
Jberardi
KitMaker: 62 posts
Armorama: 55 posts
Posted: Saturday, August 18, 2018 - 03:13 PM UTC
Thanks for the birch pictures. Lot's of character in those trees.
Had some time to do a bit of work on the cabin. After experimenting with some clapboard sheeting, I decided to become a mini carpenter and cut the boards from bass wood. I used a grey stain and will do some additional weathering with oils once the whole structure is complete.
cheyenne
KitMaker: 1,758 posts
Armorama: 1,386 posts
Posted: Saturday, August 18, 2018 - 11:18 PM UTC
Jim , looking good !!! Basswood is a great material and it takes stain nicely . After staining you can even use a darker acrylic wash to give it some depth .
Like what you're doing here .
TonyE78
Hordaland, Norway
KitMaker: 86 posts
Armorama: 86 posts
Posted: Sunday, August 19, 2018 - 02:42 AM UTC
Some comments on the lodge/hut, not to sound harsh or anything, but as most of these still exist and several are still in use, their real ww2 appearence is known and they were rather modest affairs as they were located in a total wilderness with no road access. Here is one of them called "Svensbu" in the late 1930s:
A few years ago a 6-part war/drama series called "Kampen om Tungtvannet", released in english as "The Heavy Water War", portraying the whole action was made and got rather good reviews. Google either title for screenshots and clips.
Jberardi
KitMaker: 62 posts
Armorama: 55 posts
Posted: Sunday, August 19, 2018 - 03:26 AM UTC
No offense taken. I actually watched some of that series after reading the book. Good source material.
The book describes the cabin as built during the prewar peace. It was a 10' x 20' single room structure. It had four beds, a table, a stone hearth and cupboards. Mine scales out about 12' x 17'.
I know I'm walking a fine line between historical accuracy and artistic license - probably erring toward artistic.
Jim
Jberardi
KitMaker: 62 posts
Armorama: 55 posts
Posted: Friday, August 24, 2018 - 02:44 AM UTC
A little help needed from you Brit experts. Since the Norwegians were British trained and equipped both in parachute and commando tactics, is it safe so assume they wore the No. 5 Uniform under the white anorak? Not sure if there was a cold weather variant.
I plan to depict a couple of the guys inside the cabin, and I want to make sure I have the uniform correct.
Thanks in advance,
Jim
Jberardi
KitMaker: 62 posts
Armorama: 55 posts
Posted: Sunday, September 16, 2018 - 01:32 PM UTC
A few more progress shots of the cabin. Completed the exterior and interior walls and floor. I'll save the roof for last so I can set up the interior before closing it in.
Jberardi
KitMaker: 62 posts
Armorama: 55 posts
Posted: Thursday, September 20, 2018 - 12:25 AM UTC
Beginning to flesh out the interior. Door and window to follow.
cheyenne
Posted: Thursday, September 20, 2018 - 11:33 AM UTC
Nicely done Jim , did you make the fireplace ?
I like the wood/coal stove plumbed into the fireplace . Most of fireplace heat goes up the flue whereas a stove radiates much more heat , brilliant .
Dioramartin
KitMaker: 831 posts
Armorama: 830 posts
Posted: Friday, September 21, 2018 - 01:53 AM UTC
Been lurking on this one & it’s looking real good Jim – nice balsarama & superb wood tones perfectly understated
strongarden
KitMaker: 662 posts
Armorama: 557 posts
Posted: Saturday, September 22, 2018 - 03:41 AM UTC
Excellent work Jim, very clean. And I greatly appreciate the change in subject matter from the usual 1/35 military dios seen on here.
My 24yr old recently completed his first internship in Norway, and what a great experience he had. After arriving in Oslo, then by train north to Evenstad and the university there. Then even more travel into the region followed by eight weeks of studying/recording the environmental impact of moose, elk, deer etc on the local trees and ground cover.
Sorry to be But your start is amazing, and I'll def be following!
Dave
Jberardi
KitMaker: 62 posts
Armorama: 55 posts
Posted: Sunday, September 23, 2018 - 04:06 AM UTC
Tim and Dave:
Thanks for the kind words. I've had this build in the "idea box" for a while and looking forward to seeing it through.
Cheyenne:
Appreciate the encouragement. The fireplace is carved balsa foam - same as the stone foundation of the cabin. I'm contemplating running a small orange LED light into the furnace to create the appearance of hot stove in the cabin.
Jberardi
KitMaker: 62 posts
Armorama: 55 posts
Posted: Monday, October 01, 2018 - 01:27 PM UTC
Starting to make the transformation from beast of burden to dinner. In the book, one of the troops field dressed the deer and put as much in his pack as he could carry. That would be hard to convey in the dio, so I decided to have one of the troops pulling the reindeer on a sledge back to the cabin. My original intent was to cover the deer with a blanket, to avoid a heavy conversion, but I couldn't pass up the challenge. The reindeer was cast with blanket, saddle bags and harness. Sanded all that off and gave the deer a more, well dead, look. Next up, I'm going to try my hand at sculpting some fur.
Norwegian wooden sledge is complete.
Enjoy.
deathdork
KitMaker: 235 posts
Armorama: 223 posts
Posted: Monday, October 01, 2018 - 05:33 PM UTC
This is really a fun project. Thank you!
Jberardi
KitMaker: 62 posts
Armorama: 55 posts
Posted: Friday, October 12, 2018 - 05:32 AM UTC
Found some time to devote to the fireplace. It wouldn't be a hunting cabin without a trophy.
The wood and fire grate are various Plastruct pieces bent and carved. I used the reindeer antlers from the ICM kit, but sculpted the skull.
Working on the first figure as well. This fella has the envious job of pulling the dinner sled back to the cabin. I started with the base ICM kit. It came sculpted with a full combat load out, so I sanded all that off. Ultimately, he'll only be carrying a backpack. I also bent the figure over a bit more to simulate the strain of pulling the sled.
I'm using a Hornet head. The head needed to convey happiness as he's scored some dinner. Sculpted the hat, scarf and boot covers. Next up is the winter parka.
Enjoy.
KitMaker: 447 posts
Armorama: 408 posts
Posted: Friday, October 12, 2018 - 06:23 AM UTC
looks great.
If your looking for another antler set.
https://www.shapeways.com/product/VY7DWZGV6/1-48-elk-and-deer-antlers?optionId=15508422&li=marketplace
Kuba_Bartosik
Wroclaw, Poland
KitMaker: 20 posts
Armorama: 20 posts
Posted: Friday, October 19, 2018 - 11:30 PM UTC
I like your diorama.
Kuba
cheyenne
Posted: Saturday, October 20, 2018 - 12:50 AM UTC
Jim the fireplace is very cool !!! The start on the figure looks to be coming along nicely too . Liking what you're doing !!!
Jberardi
KitMaker: 62 posts
Armorama: 55 posts
Posted: Saturday, October 20, 2018 - 02:04 AM UTC
Cheyenne & Kuba
Thanks for the kind remarks and for following along.
Except for rifle and sling, the first figure is complete. I had a good time with the ski bindings. A bit grainy, but you get the idea.
And here he is in context, pulling dinner...
I'm trying my hand at wire armature trees. Since the cabin is set in a copse of birch trees, I'll probably include three. Here's the first.
Enjoy
KitMaker: 7,007 posts
Armorama: 7,001 posts
Posted: Saturday, October 20, 2018 - 02:33 AM UTC
Great basic idea for the overall theme of this dio.
I like what you have done so far and how you went about it as well. The building and fireplace are great! The figure is a super nice conversion as well. Maybe the rucksack buckles are a bit oversized?
Great mods on the deer and also building that sled. You are well on your way here.
strongarden
KitMaker: 662 posts
Armorama: 557 posts
Posted: Thursday, October 25, 2018 - 03:43 AM UTC
What a nice diorama idea and a great start as well. A subject not seen too often. Excellent work Jim.
Looking for more.
Dave
