Hi Angel.
To be honest I thought is was some kind of wooden plank/ramp, because there's only one. Surprised there's only one on the trailer. The scratch build one is just phenomenal. For those parts you should consider making molds to produce resin pieces.
Kind regards,
Robert Jan
Hosted by Darren Baker, Richard S.
Once More Unto the Breach
SpeedyJ
Bangkok, Thailand / ไทย
KitMaker: 1,617 posts
Armorama: 1,150 posts
Posted: Wednesday, May 22, 2019 - 11:20 PM UTC
k_mero4
Sofiya, Bulgaria
KitMaker: 393 posts
Armorama: 369 posts
KitMaker: 393 posts
Armorama: 369 posts
Posted: Thursday, May 23, 2019 - 12:33 AM UTC
This is a good idea. All the more so in his mind are often thoughts of making resin details.
Posted: Thursday, May 23, 2019 - 12:51 AM UTC
Robert, thanks for your kind words!
The Bridge Column(Brueko) "B" had a total of:
24 Uebergangschienen(8t), carried as follows:
- 1 in each Pontonwagen(16 in total),
- 8 as Reserve;
8 Uebergangschienen(16t)-all carried as Reserve.
I guess the Reserve was loaded in the load beds of towing trucks.
I have no experience with resin casting.
But I can scratchbuild all these parts again.
I'm sure-now that I've made them once- I can make them look even better.
- 8 as Reserve;
petbat
KitMaker: 3,353 posts
Armorama: 3,121 posts
Posted: Thursday, May 23, 2019 - 02:21 PM UTC
Angel, I think Kalin is hinting that you are a 'scaredy cat' and avoiding learning to cast parts. I am with him, it's about time you expanded your already astonishing talents... if I can do it, you certainly can.
Posted: Thursday, May 23, 2019 - 07:44 PM UTC
Thanks Peter!
I know Kalin(the old muzovir) is hinting me
It is not that I don't want to learn something new from modelling perspective.
I've done "feasibility study" on casting resin myself and- at least at this stage-I find it economically unsound.
To make it viable, I need a project where big size parts are required in big numbers(like running wheels or crates and loads).
I'm sure this will happen one day,
SpeedyJ
Posted: Thursday, May 23, 2019 - 08:29 PM UTC
So I assume a future campaign called "Big loads with Crates" will get you there @:)
Best regards,
Robert Jan
Best regards,
Robert Jan
petbat
Posted: Friday, May 24, 2019 - 09:08 AM UTC
Best regards,
Robert Jan
petbat
Posted: Friday, May 24, 2019 - 09:25 AM UTC
Angel, it depends on your needs I suppose. But it does not need to be large pieces to make it economical. I have cast up AFV Club British radio components for other kits that do not have a radio. The cost is 100 times less the cost of buying a resin or accessory kit. The same with British Fire extinguishers. Instead of the blobs that come with kits, I have a mould of a great casting that I use. Flimsies, fuel cans, lamps, etc.
Same for German jack blocks, extinguishers, Notek lights, etc
I have cast up ammunition for the K9 Rail gun for a munitions panzer - no seams on a turned one.
I have also cast up small parts to replace malformed kit ones or get better detail than in a certain kit - I.e. Tamiya Cromwell wheel Hubs and their Churchill cupola for the Bronco Comet.
The cost of the mould making agent is not that expensive if you keep the moulds small and have minimal wastage (just make sure the side walls are strong enough to hold shape). I use Lego block frames pressed into artists clean clay to form the mould. Easy and you can make any size you want.
And yes make up moulds of any boxes, crates, etc you have, and when making other things any excess resin can be poured into the box moulds for future use.
and remember, you make a good master and cast it then Kalin may buy a few off you and share the cost!!
GulfWarrior
Campaigns Administrator
KitMaker: 1,051 posts
Armorama: 1,029 posts
Posted: Sunday, May 26, 2019 - 02:39 PM UTC
I've made a little progress on the M9 ACE.
Step 1:
Step 2:
Each road wheel pair is made of three pieces, D1-3. D3 is the rubber part of the outer road wheel pair. I'm leaving those off so they can be painted separately.
More to follow...
Step 1:
Step 2:
More to follow...
Posted: Monday, May 27, 2019 - 07:14 PM UTC
Best regards,
Robert Jan
Yeah Robert, such Campaign might be of help
Peter, thanks for your advices!
They'll be handy when I finally decide to dive into resin-casting,
Posted: Tuesday, May 28, 2019 - 01:07 AM UTC
Back to the Pf.11 again...
I thought it might be possible that at least one of the 32 trailers, delivered to Bulgaria in 1943, survives till today.
Here it is(in the Museum of Engineer Units in Svishtov,Bulgaria):
Will plan a trip soon,
SpeedyJ
Posted: Tuesday, May 28, 2019 - 02:54 AM UTC
When I come to Europe, I hope soon, I will make an appointment with you, so you can guide and show me around in Bulgaria, this is just so good to see they save history like this.
Kind regards,
Robert Jan
Kind regards,
Robert Jan
Illini
KitMaker: 345 posts
Armorama: 247 posts
KitMaker: 345 posts
Armorama: 247 posts
Posted: Tuesday, May 28, 2019 - 03:49 AM UTC
Here's my entry, a little slow getting the pictures up, sorry. Will post progress pictures shortly
GulfWarrior
Posted: Tuesday, May 28, 2019 - 04:09 AM UTC
That looks cool! I'll look forward to seeing your progress on this one!
Posted: Tuesday, May 28, 2019 - 05:19 AM UTC
Kind regards,
Robert Jan
Robert,
You will be warmly (in the best meaning of Bulgarian hospitality traditions) welcomed!
Illini
KitMaker: 345 posts
Armorama: 247 posts
KitMaker: 345 posts
Armorama: 247 posts
Posted: Tuesday, May 28, 2019 - 02:31 PM UTC
Progress on the M728. The suspension on this is a total PITA, and it doesn't even articulate.
GulfWarrior
Posted: Tuesday, May 28, 2019 - 10:57 PM UTC
Looks good, Dave!
Illini
KitMaker: 345 posts
Armorama: 247 posts
KitMaker: 345 posts
Armorama: 247 posts
Posted: Wednesday, May 29, 2019 - 04:10 AM UTC
A bit more progress
petbat
Posted: Wednesday, May 29, 2019 - 08:13 AM UTC
... this is just so good to see they save history like this.
Kind regards,
Robert Jan
Yes. If only others had done the same. There is just so much history lost over the years.
Progressing Nicely Dave. Welcome aboard.
GulfWarrior
Posted: Wednesday, May 29, 2019 - 02:28 PM UTC
More progress on the Takom M9 ACE...
I haven't put the tracks together yet. Those were in Step 3. These pics are from Step 6. The hull is starting to come together.
Illini
KitMaker: 345 posts
Armorama: 247 posts
KitMaker: 345 posts
Armorama: 247 posts
Posted: Sunday, June 02, 2019 - 08:01 AM UTC
Attaching the plow takes like four hands
The turret isn't attached, just sitting there. The boom will be raised and rigged.
GulfWarrior
Posted: Sunday, June 02, 2019 - 01:07 PM UTC
Nice work, Dave.
I might have to pick one of those up.
petbat
Posted: Sunday, June 02, 2019 - 10:14 PM UTC
Richard and Dave - nice progress guys. Very interesting subjects.
GulfWarrior
Posted: Monday, June 03, 2019 - 01:23 AM UTC
Thanks Peter!
Aside from a few fiddly bits that I've spent time crawling around on the floor to find , it's been a pretty fun build!
GulfWarrior
Posted: Sunday, June 09, 2019 - 02:25 PM UTC
I've masked off the horizontal surfaces of part of the hull. I used tape (as you can see) but also PVA (white Elmer's) glue for some of the smaller details.
The exposed areas will be covered with Valspar terra-cotta spray paint.
