Dragon 251 D/7 command vehicle
johnstone
KitMaker: 77 posts
Armorama: 69 posts
Posted: Sunday, April 21, 2019 - 10:48 AM UTC
Hello all. Happy Easter!
I working on the 1/35th Dragon 251 D/7 Command vehicle. Does anyone know where I could get a wiring diagram for the radios? I've looked a lot on the internet but cannot find a clear shot of the configuration used in this vehicle.
Grateful for any help!
27-1025
KitMaker: 1,281 posts
Armorama: 1,222 posts
Posted: Sunday, April 21, 2019 - 12:46 PM UTC
I think the /7 was an assault engineer vehicle. Are you talking about the kit with the tall extended radio mast?
Posted: Sunday, April 21, 2019 - 06:26 PM UTC
https://en.wikipedia.org/wiki/Sd.Kfz._251
251/7 is the engineer type
251/3 is a command post
Pak_40
KitMaker: 392 posts
Armorama: 281 posts
Posted: Sunday, April 21, 2019 - 08:37 PM UTC
For what it is worth, there are two types of SdKfz 251 Kommandopanzerwagen you can make.
1. the /6 can be in Ausfuhrung A, B or C.
2. the later replacement is the /3 Ausfuhrung D Typ IV. Same equipment as above, but with the D model the /6 was phased out.
I hope this will help.
Chris
smorko
Serbia & Montenegro
KitMaker: 94 posts
Armorama: 89 posts
Posted: Sunday, April 21, 2019 - 11:21 PM UTC
Maybe he's refering to the /17 command version, it has the large radio rack in the back similar to the 250/3 greif. Although the /17 is only an ausf. C I believe.
LikesTanks
Wales, United Kingdom
KitMaker: 242 posts
Armorama: 234 posts
Posted: Sunday, April 21, 2019 - 11:39 PM UTC
I believe he's building the 3-in-1 251/7 ausf D. Choice of standard /7, one mounting a 2.8cm gun and the unit command version with the left rear bench seat replaced by a radio rack.
johnstone
KitMaker: 77 posts
Armorama: 69 posts
Posted: Monday, April 22, 2019 - 12:39 AM UTC
Yes, that is the kit I'm building.
Pak_40
KitMaker: 392 posts
Armorama: 281 posts
Posted: Monday, April 22, 2019 - 11:28 AM UTC
There was no command version of the /7 A thru D.
The platoon command vehicle would have been a /10 followed later on by a /17D with the latter schweben lafette configuration.
I believe KStN 714 (fG) (gp) says this, but double check just to be sure.
Chris
johnstone
KitMaker: 77 posts
Armorama: 69 posts
Posted: Monday, April 22, 2019 - 12:32 PM UTC
Sounds like Dragon is allowing me to build a vehicle that never existed!!?? This thing has been a LOT of work !!??
smydi01
KitMaker: 219 posts
Armorama: 197 posts
Posted: Monday, April 22, 2019 - 12:35 PM UTC
You could have a look at http://www.pietvanhees.nl/251/index.htm for more information
27-1025
Posted: Monday, April 22, 2019 - 12:44 PM UTC
Adding this to my bookmarks. Lots of good info.
johnstone
KitMaker: 77 posts
Armorama: 69 posts
Posted: Monday, April 22, 2019 - 02:31 PM UTC
Yes very good info -great website. Thanks!!
panzerbob01
Louisiana, United States
KitMaker: 3,128 posts
Armorama: 2,959 posts
Posted: Monday, April 22, 2019 - 03:22 PM UTC
John:
The D has done many funny things, but I'm pretty sure that you are OK in this case...
The "command track" is a legit version on that hull - removed one bench seat, added radios, antenna systems, a code table and Enigma machine, and a few other internal and external widgets, and "voila!" - a command track.
Most of the SdKfz 251 versions (/1 through /22 with a possible prototype /23) are defined by the way the standard hull was fitted out. The "odd" /17 (some used as a command track, and some converted to a FlaK track) with the clam-shell rear hull is pretty much the exception. Notably, the D has kitted both /17 versions - the clam-shell and the standard-hull - with the clam-shell version kitted as both command and FlaK versions, and the standard hull kitted with a Schwebellaffette 2cm turret.
Cheers! Bob
johnstone
KitMaker: 77 posts
Armorama: 69 posts
Posted: Monday, April 22, 2019 - 04:08 PM UTC
Thanks Bob! Maybe all is not lost. Still can't find a photo or diagram of the radio in the Dragon kit. I'll just have to wing it. I've been modeling since the mid 60"s when all we did was "wing it"!
deathdork
KitMaker: 314 posts
Armorama: 296 posts
Posted: Monday, April 22, 2019 - 05:38 PM UTC
So after your plea who will be able to challenge you? Go for it!
smydi01
KitMaker: 219 posts
Armorama: 197 posts
Posted: Monday, April 22, 2019 - 06:51 PM UTC
If you look at the illustrations on the site I supplied there's a set up for the radios in a C it should give an idea
Good luck
panzerbob01
Posted: Monday, April 22, 2019 - 06:54 PM UTC
John:
See this site - great photos and stuff about German WWII AFV radios, including at least one AFV radio set-up diag. Basically, you'll have a transmitter, a receiver (linked), power supplies and relays, loud-speaker and head-phones extensions, antenna cables... So you won't have to "wing" all of it!
http://www.warrelics.eu/forum/field-equipment-accessories-third-reich/evolution-headsets-throat-mikes-panzers-1935-1945-a-618866/
Also look up the Aber German radios set... "Aber 35A079 German Tank Radio Set Fu 2 and Fu 5". This PE set comes with some nice wiring diags. Again, won't provide all the "command" set-up, but great stuff for some of the core radio sets.
IF you can identify the specific radio sets involved, you can likely find a lot of photos and diags for it - typical vehicle radio sets included Fu-2, Fu-5, Fu-8, plus ancillary relay, fuse, power-supply boxes.
Hope this helps!
Bob
LonCray1
KitMaker: 55 posts
Armorama: 42 posts
Posted: Tuesday, April 23, 2019 - 01:10 AM UTC
Isn't that the kit where Dragon's picture has a /7 with the bridge units AND the howitzer in one machine? I know it's a 3 in 1 model, but they put 2 of them together on the cover. It looks really cool but isn't real.
johnstone
KitMaker: 77 posts
Armorama: 69 posts
Posted: Tuesday, April 23, 2019 - 01:58 AM UTC
Bob - thanks so much!! (You are a goldmine of information.
Pak_40
KitMaker: 392 posts
Armorama: 281 posts
Posted: Wednesday, April 24, 2019 - 04:42 PM UTC
Here is something that may help as well
https://www.wwiidaybyday.com/kstn/kstn714fg1jun44.htm
Not perfect, but it should do.
Chris
