BEST HAIRSPRAY FOR CHIPPING
jagmkx
KitMaker: 1 posts
Armorama: 1 posts
Posted: Friday, February 07, 2020 - 07:47 AM UTC
Greetings,
I'm trying to experiment with hairspray chipping. Many of the U Tube and online tutorials recommend pump (no need to decant obviously) hairspray - odorless - matte - medium hold. After a diligent search, I have yet to find a hairspray, pump or aerosol that meets this criteria? I trust someone can recommend a specific brand version that works for them? Greatly appreciated, thanks.
Bravo36
KitMaker: 224 posts
Armorama: 206 posts
Posted: Friday, February 07, 2020 - 07:52 AM UTC
I just picked up some no-name brand. I did look for ‘fine spray’ aerosol.
Works fine.
It’s cheap. Experiment...
jekrott
KitMaker: 480 posts
Armorama: 348 posts
Posted: Friday, February 07, 2020 - 08:15 AM UTC
I've had great success with TRESemme.
KitMaker: 929 posts
Armorama: 756 posts
Posted: Friday, February 07, 2020 - 08:16 AM UTC
I use TRESemmé TRES Two Ultra Fine Mist
https://www.youtube.com/watch?v=mCHVn47E6LA
HTH
d6mst0
#453
KitMaker: 1,696 posts
Armorama: 592 posts
Posted: Friday, February 07, 2020 - 01:00 PM UTC
The cheapest and un-scented.
Monsoon
KitMaker: 74 posts
Armorama: 62 posts
Posted: Friday, February 07, 2020 - 03:33 PM UTC
Aquanet Pink can. It's what all the hair bands of the 80's used.
joepanzer
KitMaker: 755 posts
Armorama: 699 posts
Posted: Friday, February 07, 2020 - 03:55 PM UTC
So after you spray, do you try to scrub all of it off, or just the areas that you want chipped? What affect does unchipped hairspray have on a finished model?
SSGToms
KitMaker: 3,533 posts
Armorama: 3,024 posts
Posted: Friday, February 07, 2020 - 06:43 PM UTC
Clarence - Aquanet Pink can.
Joe - You spray a base color, then the hairspray, then the second color. Then you scrub away with a wet brush where you want the base color to show through. So there is no exposed hairspray.
KitMaker: 929 posts
Armorama: 756 posts
Posted: Saturday, February 08, 2020 - 12:01 AM UTC
All depends on what your project is and why your using chipping. A cargo bed or white wash would look better imho if you did the whole area otherwise just in select areas. As long as base coat and hairspray layers are dry/cured then I have not seen any effect the hairspray has on the top coat if you don’t remove the hairspray.
ttwells
KitMaker: 294 posts
Armorama: 66 posts
Posted: Saturday, February 08, 2020 - 12:16 AM UTC
Aquanet to be sure... the travel size is the most economical to buy and experiment with. Tres is also pretty good...
joepanzer
KitMaker: 755 posts
Armorama: 699 posts
Posted: Saturday, February 08, 2020 - 02:14 AM UTC
Thanks Ryan!!
GulfWarrior
KitMaker: 922 posts
Armorama: 900 posts
Posted: Saturday, February 08, 2020 - 05:13 AM UTC
TRESemmé 3 works great for me!
joepanzer
KitMaker: 755 posts
Armorama: 699 posts
Posted: Saturday, February 08, 2020 - 05:59 AM UTC
Thanks Matt!!
So there's no residual texture if you don't scrape it off?
Cool!
KitMaker: 929 posts
Armorama: 756 posts
Posted: Saturday, February 08, 2020 - 06:07 AM UTC
Thanks Matt!!
Nope, the hairspray is under the second coat. Watch the YouTube link I posted, Michael covers a number of questions.
