Trumpeter 1/35 M1133 Stryker MEV
PeterMax
Bayern, Germany
KitMaker: 43 posts
Armorama: 39 posts
Posted: Saturday, February 08, 2020 - 05:03 AM UTC
Well, I’m doing it again……!!!
Another Stryker from Trumpeter, this time it’s a M1133 Medical Evacuation Vehicle.
To make the model look more dynamic, I steered the wheels on the two front axes.
Also in order to put this Stryker on a diorama, when it should be finished.
I started work, by drilling 0,6mm holes into the two kit parts A44.
Then I took a new, sharp blade to cut the steering linkage part A44 into its five parts.
After that I took pieces of a 0,5mm rod (EVEREEN 218) to connect the steering parts together again. Now it was possible to bring the steering linkage in every wanted position.
To make the wheels turn to the left side, I had to sand the shock absorbers A45 and A46 at their base. Due to the construction of the lower hull, the parts A45 have to be sanded at their rear side and A46 at their front side.
You don’t have to be very careful doing this, because the fine tuning will be done later, when you align the axes to each other.
Driver compartment
Due to the open driver hatch, part of the driver compartment will be visible. I built the walls, using parts from the M1129 Stryker Mortar kit from Trumpeter as a template. I simply took a sharp knife and followed the contour.
I glued everything together, once again using the Mortar Kits parts, as templates.
The cylinders were made from 6,4 mm tube (EVERGREEN 228) with different length: 11 mm the first and 9 mm the second one.
The little wall with the holes is actually the front part of a basket, jet through the open hatch, you wouldn’t just see more than this wall. The holes are 1 mm in diameter, once more drilled, using the kit part as template.
The little half tube on the left side will further on hold the fire extinguisher.
So far for this time,
Peter
GulfWarrior
KitMaker: 898 posts
Armorama: 876 posts
Posted: Saturday, February 08, 2020 - 05:15 AM UTC
Looks awesome, Peter. This one is on my To-Do list!
KoSprueOne
Myanmar
KitMaker: 3,876 posts
Armorama: 1,438 posts
Posted: Saturday, February 08, 2020 - 11:51 AM UTC
I'll be following this project. How much more interior do you plan to build? Nice touch with the steering linkage
bison126
Correze, France
KitMaker: 5,151 posts
Armorama: 5,026 posts
Posted: Sunday, February 09, 2020 - 06:41 AM UTC
Very nice job on the driver station.
Olivier
PeterMax
Bayern, Germany
KitMaker: 43 posts
Armorama: 39 posts
Posted: Friday, February 14, 2020 - 02:25 AM UTC
Hi Richard, Hi Olivier, thank you very much!
Hi, KoSprueOne, It will be just the driver compartment at this one.
But, as I mentioned I plan to put it on a diorama, together with ...... another Stryker. And this one will get an interior.
PeterMax
Bayern, Germany
KitMaker: 43 posts
Armorama: 39 posts
Posted: Sunday, February 16, 2020 - 04:38 AM UTC
Haven‘t had much time.
Last week was really busy. Therefore, just a “tiny little”
update today.
My plan for this MEV includes a tow hook in opening position.
So, I used the tow hook which is included in the Stryker Upgrade Equipment set AF35S59 from AFV Club, but modified it for my needs.
I cut off the upper part, sanded the rear part to reduce width and finally drilled a hole into the hook.
After that I rebuild the upper part.
I used reference photos, regarding “US-Army tow hook” and “NATO tow hook”.
Due to my researches I built it using two small sheets for the side parts and a 1.5mm x 1 mm block for the centerpiece. The two 0.6mm screws are from Plus Models.
In the end, the tow hook is now movable! Yet for its fragile structure, I will keep it in open position.
Peter
PeterMax
Bayern, Germany
KitMaker: 43 posts
Armorama: 39 posts
Posted: Sunday, March 01, 2020 - 05:17 AM UTC
Some progress on my MEV!
This time I worked on the driver compartment. I added some interior things, like the connector for the communication system and a green tube, which I don’t know what it is for. The front part is shown by a photo. I had made this photo some time ago from parts, I have had built. The two black cubes represent the control boxes of the vehicle. I colored the fire extinguisher, which is from the M1129 Mortar kit, by Trumpeter and added a carton to the end of the driver compartment.
In-between, I colored the driver compartment in bright white. I added some traces from boots to the ground, by using different pigments, scratched from chalks and applied with the help of a small brush.
Well, as you can see, there is not much to see any more.
Peter
KoSprueOne
Myanmar
Posted: Sunday, March 01, 2020 - 05:41 AM UTC
Excellent detailed progress!
HermannB
Bayern, Germany
KitMaker: 3,885 posts
Armorama: 3,853 posts
Posted: Sunday, March 01, 2020 - 09:09 AM UTC
Stryker usually don´t have the towing pintle attached. If they were attached, you can`t lower the rear ramp. The only vehicles with towing pintle were M1132 ESV pulling MICLIC trailer. In this case i think the crews will enter the truck via the rear door.
guni-kid
KitMaker: 458 posts
Armorama: 453 posts
Posted: Sunday, March 01, 2020 - 09:15 AM UTC
Even though Strykers are not my topic I really like what you've done with it so far! Will have the occasional look at this thread for sure!
PeterMax
Bayern, Germany
KitMaker: 43 posts
Armorama: 39 posts
Posted: Wednesday, March 04, 2020 - 02:03 AM UTC
Hi KoSprueOne, Hi Marian,
thanks a lot!!!!!!!!
Servus Hermann,
you are right ………,
but, as I mentioned earlier, I plan on doing a diorama with this Stryker involved. And its story will explain my choice.
Peter
GTDeath13
Attica, Greece / Ελλάδα
KitMaker: 869 posts
Armorama: 867 posts
Posted: Wednesday, March 04, 2020 - 05:32 AM UTC
Very nice work and very interesting. Will be paying attention to the build.
