Panda Hobby HMEE-1 Build/Review
Epi
KitMaker: 3,570 posts
Armorama: 2,542 posts
Posted: Thursday, March 05, 2020 - 06:14 PM UTC
Got the opportunity to do another Panda Hobby review/build for Armorama. This time it's the HMEE-1 (High Mobility Engineer Excavator), kit #PH35041, in 1/35 scale.
There has been a couple of reviews already on the web. There has also been a very good build of the kit where the builder carefully cuts away the engine cover to be to show off the engine. I will be doing that in this build also.
After going thru the instructions a couple of times, I came to the conclusion that I will be doing this build in 4 major sub-assemblies, the engine/hull, cab, out riggers and back hoe, and the bucket with arms. I will be adding a majority of the missing hydraulic hoses and adding more and/or missing detail from the cab since you have two big windows you can see through.
Upon opening the box, I could see right away that there is a lot of punch marks and yes, a lot of them can be seen. The first glance through the instruction booklet, I noticed a couple of major missing items other than the hydraulic hoses. In the cab, there is no roof or wall detail, no AC unit and instrument cluster located on the right wall and no back hoe controls. This will be covered when I do the cab sub-assembly.
The cab sub-assembly looks like it is going to take more work than the others. So for know, I am going to start on the out riggers and back hoe.
Step 10 and 12 cover the out riggers and back hoe. The out riggers went together with out no issues, just filling punch marks and sanding seems.
As you can see from the pictures, I deviated from the instructions a bit to aid in the build. I added five pieces from the back hoe step to the out rigger step. Parts A27, A32, and A37 are supposed to be sandwiched between parts B28 and B31 and then attached to the out riggers. Because of the ugly seem and possibly gluing the pins of the back hoe to parts B28 and B31, I chose to leave them off the back hoe and drill out the pins. I will add pins with Evergreen rod stock.
There is one instruction correction for step 12. Part A32 is not labeled in the instructions, but it is shown in it's correct position. Start with putting B31 and B28 together along with hydraulic tube D52. Glue B50 and B51 together and before moving on, fill and sand the large seem. After gluing B55 and B56, again, fill and sand the big seem. To have parts B60, A23, and A22 kept moving, just snap in place and do not glue. The instructions have you not place glue on three locations of these parts, but to make workable, glue is NOT to be used at all on these parts.
Remember, careful gluing and the out riggers and back hoe will move.
Next update will be adding the hydraulic hoses to the out riggers and back hoe. After that I will be moving on the the bucket sub-assembly.
barny
KitMaker: 265 posts
Armorama: 264 posts
Posted: Thursday, March 05, 2020 - 08:58 PM UTC
Excellent start following this sir
trahe
KitMaker: 1,153 posts
Armorama: 947 posts
Posted: Friday, March 06, 2020 - 12:03 AM UTC
Definitely following!
KitMaker: 849 posts
Armorama: 700 posts
Posted: Friday, March 06, 2020 - 12:08 AM UTC
x2.
Pete, what size evergreen rods are you using?
jvazquez
KitMaker: 850 posts
Armorama: 804 posts
Posted: Friday, March 06, 2020 - 02:28 AM UTC
Looking good and nice review
Couple things I was a little disappointed on this kit was the cab that didn't have much detail and the doors were molded on, so even if you did want to spruce up the interior you would hardly see much of it
HermannB
Bayern, Germany
KitMaker: 3,885 posts
Armorama: 3,853 posts
Posted: Friday, March 06, 2020 - 04:22 AM UTC
Was thinking about building one from 2CR. Until I found out the 2SR has the unarmored cab. With details lacking in the cab, maybe building the unarmored cab from scratch isn`t that scaring.
KoSprueOne
Myanmar
KitMaker: 3,876 posts
Armorama: 1,438 posts
Posted: Friday, March 06, 2020 - 03:46 PM UTC
Following this build.
Epi
Posted: Saturday, March 07, 2020 - 07:32 AM UTC
Ryan K, I used a 2mm piece of Evergreen rod.
Epi
Posted: Saturday, March 07, 2020 - 08:13 AM UTC
Ok, I finished with the back hoe and out riggers.
I wanted to add some better detail to all the hydraulic hoses by using this product from Blast Models, but with a deadline to finish the article, I couldn't wait for them to come from overseas.
And here is the finished product:
Some missing added detail, missing small bolts/rivets:
And two "holes" of different sizes and two more bolt heads:
And as you can see, everything still moves:
Like I said, the hydraulic connectors from Blast Models would make this stand out even more, so maybe another build will be in the future.
Next update will be the bucket. I've already started it and it is not fun. I really had to deviate from the instruction for construction.
KitMaker: 17,328 posts
Armorama: 13,474 posts
Posted: Saturday, March 07, 2020 - 09:25 AM UTC
Looking good Pete. Great job on all the hydraulic lines.
HermannB
Bayern, Germany
Posted: Saturday, March 07, 2020 - 04:51 PM UTC
Good job there. But I wonder if the M109 A7 has the same "quality". Looking forward to see a review of the gun somedays.
Posted: Sunday, March 08, 2020 - 01:40 AM UTC
...I wonder if the M109 A7 has the same "quality". Looking forward to see a review of the gun somedays.
It is about the same quality.
Ask an you shall receive: Panda M109A7 Paladin Review
HermannB
Bayern, Germany
Posted: Sunday, March 08, 2020 - 01:47 AM UTC
Thanks Gino!
Epi
Posted: Sunday, March 08, 2020 - 10:57 PM UTC
I want to apologize guys, I am building faster than I am posting. This kit, if you take your time and break the build down to sub-assemblies, it is an ease to build and add details.
I was supposed to update you all with the bucket build and hydraulic hoses added. I did get the bucket finished, but did not get the hydraulic hoses added yet. I kind of jumped to the engine and chassis. I wanted to show you all that the engine can be shown with a little work and if your up to it, scratch build the radiator and AC coils under the front hood.
The family and I are heading to Colorado for Spring Break tomorrow, so it will be about a week before I post an update.
I take that back, I will post the bucket build update, but it will be a week before I can add all the hydraulic hoses.
Epi
Posted: Sunday, March 22, 2020 - 06:17 PM UTC
Finally back with another update.
Now the build of the front bucket. The front bucket is covered in steps 9, 10, 11, and 13.
After cleaning up all the parts in step 9, I found that the bucket build was a bit complex and needed about 8 hands! A lot of the parts do not require glue in order for the bucket to be movable. It is possible, but you need to jump around between the four steps and adjust the build order.
With that said, I skipped to step 10 to make the bucket arms. The way the arms go together, there was no need for putty, just the little seem lines and sprue cut off points need clean up. There is no need to add parts D48 and D51 at this time. They will be added during the main hull build with hydraulic hoses added. Parts D55 and D61 are added, but be careful that you don't break them.
Ok, now we go back to step 9. First thing is filling all the punch out marks!!!!!!!! Lots of seem lines to clean on all the round pieces. On parts D31 and D32, there are pins on both parts and should be only on one. So one or the other pin needs to be cut off.
Here is were the build order is changed up a bit. Your going to use the bucket arms to "stack" all the braces to along with the round parts.
You have to add parts A36 and D29 in step 11 first before stacking the other braces. You will end back at step 11 adding parts D29 and to finish off, part A35.
If done right and carefully, everything will move and you can remove part A45 for adding the metal hydraulic lines. Also, don't forget to attach parts B2 and B3 to the arms.
A couple of notes before starting step 13 and the bucket itself. If you are going to add hydraulic lines, drill holes in parts D47 for the lines. Check your parts D8 and D9. Both my D8's where short shot. More punch marks need to be filled here too. Again, with careful gluing, everything can be movable.
Now the fun part, adding the hydraulic lines. On the inside of the arms are molded on metal hydraulic lines, that is all. Metal lines need to be added to part A45. Metal lines also need to be added behind the main bucket itself. There is also a missing junction box that is supposed be on the left of part B40. I did this with just a piece of rectangle plastic stock. The metal lines behind the bucket was made from plastic rod. The flexible hoses was made from flexible coated wire. The hoses and lines make a lot of difference in the build.
Oh, I forgot! There is a 3rd line attached to the inside of the left arm. it is for electrical connection of other attachments other than the bucket.
As you can see from some of the pictures, I have already gotten ahead with the main hull build. Plus being locked down in the house should help out in the modeling area. So stay tuned for the next update....
terminators
France
KitMaker: 1,806 posts
Armorama: 1,781 posts
Posted: Sunday, March 22, 2020 - 10:25 PM UTC
Nice improvements !
The wiring step is essential on this model but still complicated to do.
bison126
Correze, France
KitMaker: 5,151 posts
Armorama: 5,026 posts
Posted: Tuesday, March 24, 2020 - 05:40 AM UTC
Very nice job on all the hydraulic lines Pete. They make the difference.
Olivier
Posted: Tuesday, March 24, 2020 - 09:34 AM UTC
It looks awesome Pete. Great job.
KitMaker: 6,749 posts
Armorama: 5,684 posts
Posted: Wednesday, March 25, 2020 - 03:42 AM UTC
Always a pleasure to see your work, Pete.
