scratching schurzen - fail
phil2015
KitMaker: 114 posts
Armorama: 109 posts
Posted: Monday, March 16, 2020 - 11:27 AM UTC
So I had a plan....
I'm working on a Das Werk early Panther A. Looking at pictures of winter whitewashed panthers, it seems like there are a lot with a visible scratch on the skirts. I thought... I can do that.
I use Tamiya for the paint and sealer, and Heavy Chipping Fluid in place of hairspray. I mixed up a red oxide from Red Brown and Red and covered the skirts with that. Waited overnight. Sealed them with two coats of Tamiya clear (X-22). Waited overnight. Put on two coats of heavy chipping fluid then a coat of dark yellow and an overspray of olive green. I thought I'd do two levels of scratches, one on this coat, and then another when I went to do the white overspray. But trying to do the scratch here failed.
I used a cocktail stick, wetted the surface with water, then tried scratching the surface with the cocktail stick. It kinda worked ok mostly, but in several places it took the paint right off to the plastic.
It gave me an opportunity to try some other things. I used a sculpting tool (metal with a dull point) to try some scratches and it worked beautifully, so I'll use it next time.
After applying some vallejo acrylic to where the bare plastic was showing and realizing that was going to look too different, I started sanding the skirts down to start over. One notices that a coarse sanding stick gets some absolutely terrific scratching before applying it with enough force to take the paint off.
Anyone else have similar experiences and willing to share some tips on doing this?
GazzaS
#424
KitMaker: 4,469 posts
Armorama: 2,176 posts
Posted: Monday, March 16, 2020 - 05:38 PM UTC
The only thing I might add would be to sand your schurzen first to help the paint adhere better. And wear rubber gloves when handling. Skin oils can undermine your paint.
KitMaker: 7,337 posts
Armorama: 5,914 posts
Posted: Thursday, March 26, 2020 - 06:15 AM UTC
I've used a toothpick and even the end of a piece of stretched sprue, dip in gray paint (to simulate bare metal) and drag along the surface in the direction of the scrape or scratch. As usual, a bit of experimentation is needed to develop a technique. Another technique is to use a small piece of sponge, grip in tweezers or forceps, dip in paint and squeeze it out until almost dry then gently daub where you want a worn or scratched surface. When the paint on the sponge is almost all used you can drag it for very fine scratches and scuffs. Again, experiment.
cabasner
KitMaker: 1,037 posts
Armorama: 986 posts
Posted: Monday, April 06, 2020 - 03:05 PM UTC
So I had a plan....
How did you thin your (assumed) Tamiya paint yellow top coat? If your thinning too much, you may not be getting good enough 'grip' on the hairspray layer. Also, I'm thinking you may have overdone the chipping fluid layers, either to thick of a layer of fluid, or perhaps you can repeat everything, just use the light chipping fluid instead of the heavy duty version. Michael Rinaldi notes these as possible contributors to 'sheet' removal of paint when trying to chip.
KitMaker: 3,738 posts
Armorama: 3,187 posts
Posted: Monday, April 06, 2020 - 11:22 PM UTC
I always clean and prime raw plastic - my go-to primer at the moment is Halfords Grey autobody primer in a rattle can, but similar primers are available in the States. This grips the plastic so the Tamiya paint will adhere. But any time you abrade the paint (even with a cocktail stick) you risk scraping all the way down to the plastic simply because our paint layers are mighty thin!
Namabiiru
#399
Rhode Island, United States
KitMaker: 2,834 posts
Armorama: 1,883 posts
Posted: Tuesday, April 07, 2020 - 12:53 AM UTC
I also prefer to use acrylic floor polish to seal the base coat. My experience has been that it seals better and is more durable than other clear coats.
phil2015
KitMaker: 114 posts
Armorama: 109 posts
Posted: Tuesday, April 07, 2020 - 01:51 AM UTC
Thanks for the responses everyone. I stripped the paint off and started over. In the new version, I wiped it down with alcohol after stripping it then primed it with mr surfacer and let that sit for 24 hours.
I then used the same method and when I abraded it, the scratches went down to the first coat but not through. The results are pretty nice.
I've decided to replace the molded skirts with sheet styrene for the individual frames (and leave a couple off). I'll use the same method on that and see how it goes.
Phil
