What are you working on now?
Ontario,
CanadaJoined: September 26, 2006
KitMaker: 210 posts
Armorama: 81 posts
Posted: Wednesday, August 19, 2009 - 08:53 AM UTC
.............just curious as to what other Canadian's are up to.
I've just finished building a very old Tamiya kit........ a Panzer II F that's been of the shelf for ever................ detailed with the Eduard photoetch kit and some further mods/details to satisfy my creative side. Priming has been done and the first coats of desert yellow applied. So far, everything is proceeding decently........... outside of the airbrush acting up a bit.............. or it could be just the rusty old operator !!! I'll try and post up some pictures.....................
Wouldn't mind seeing what everyone else is up to..............
Ontario,
CanadaJoined: April 12, 2002
KitMaker: 831 posts
Armorama: 614 posts
Posted: Thursday, August 20, 2009 - 06:35 AM UTC
A 1/16 scale leopard C2 uparmoured TFA based on the old Tamiya RC kit with a Perfect Scale CAst Turret and the rest scratchbuilt.
Paul Fredenburg
LCol (Ret'd)
Royal Canadian Engineers
President Trackjam Models
http://www.trackjam.com/
Ontario,
CanadaJoined: September 18, 2005
KitMaker: 1,226 posts
Armorama: 819 posts
Posted: Thursday, August 20, 2009 - 12:09 PM UTC
Well nothing as ambitious as Paul's build
but here is what I have on the work table:
DML JSU-152 for our club "Korea" theme build
DML M4A4 "Orange box" as either a BCD or a Calgary Regt tank
DML 251/17 that is almost done
Darryl
blackpoolkennels.com
Do not meddle in the affairs of dragons, for you are crunchy and taste good with ketchup.
Ontario,
KitMaker: 210 posts
Armorama: 81 posts
Posted: Friday, August 28, 2009 - 02:55 AM UTC
The Panzer II is coming along............ gave her that worn look with some German tank grey to look like the desert yellow has worn off. Need to add a bit more chipping details to the desert yellow.............. then it's time to apply some washes.............. bit of rust. Then start the little base ................ and she'll be done. Likely finish painting the 20mm Flak gun I have sitting with the same sort of finish and get her done as well.
I'm actually itching to move onto something else................ the Panzer II has been a fun little project that grew beyond just an out of the box exercise. I think next will be.................. a T34 I've had on the shelf for a long while.
AND........... have to get onto the shelf build project to place these finished projects on as well.
Ontario,
CanadaJoined: May 21, 2008
KitMaker: 537 posts
Armorama: 439 posts
Posted: Friday, August 28, 2009 - 07:28 AM UTC
Mainly Alanger's T-35, but I've also got Tamiya's Universal Carrier on the go, Dragons Bedspring T-34, and Dragon's Marder IIIm. When I finish one of these, I'll start the Bronco Canadian Staghound.
You might think he loves you for your money
But I know what he really loves you for
It's your brand new leopard-skin pill-box hat
Ontario,
CanadaJoined: November 05, 2006
KitMaker: 384 posts
Armorama: 338 posts
Posted: Friday, August 28, 2009 - 11:58 AM UTC
I'm currently working on upgunning a Panther F from 75 mm to 88 mm.
Ontario,
KitMaker: 210 posts
Armorama: 81 posts
Posted: Tuesday, September 01, 2009 - 11:45 AM UTC
Had a minor set-back with the Panzer II............ while my son was painting his german plane light blue......... and dad was putting clear coat on the turret for the washing process............ guess what got sprayed on instead cause the old man forgot to double check the can he grabbed !!! Doh !!! I should have snapped a pic !!!
Nova Scotia,
CanadaJoined: July 16, 2003
KitMaker: 33 posts
Armorama: 2 posts
Posted: Tuesday, September 01, 2009 - 02:38 PM UTC
1/72 IBG CMP steel body, after that the rest of the CMP's from IBG. Cheers Pete
Ontario,
CanadaJoined: January 05, 2005
KitMaker: 347 posts
Armorama: 47 posts
Posted: Wednesday, September 02, 2009 - 10:18 AM UTC
Currently working on a M151A2 in NATO colours, as well as converting a 1/32nd scale M62 wrecker to a Canadian vehicle early 70ies period.
Art
Incoming fire always has the right of way, friendly fire - isn't, and always remember, your weapon was probably made by the contractor with the lowest bid.
Ontario,
CanadaJoined: January 09, 2005
KitMaker: 577 posts
Armorama: 446 posts
Posted: Thursday, September 03, 2009 - 03:18 AM UTC
M32, M4, M51, M4A1 (W) (76) all started and in various stages of build. Touch-ups to a few others (hoping to get to CAPCON in Ottawa).
On the shelf- Calliope, ARV, M50, Ambutank (Late), M4A2 (cast & welded hoods), M4A1 DV...
Doug
Manitoba,
CanadaJoined: May 17, 2009
KitMaker: 9 posts
Armorama: 4 posts
Posted: Sunday, September 06, 2009 - 04:09 PM UTC
2 leopard 2a4 and a ARV a2
CanadaJoined: December 29, 2008
KitMaker: 316 posts
Armorama: 264 posts
Posted: Monday, September 07, 2009 - 04:22 PM UTC
I'm working on the new dragon sd.kfz.7 8t cargo version in a dio.
Alberta,
CanadaJoined: February 10, 2008
KitMaker: 221 posts
Armorama: 217 posts
Posted: Monday, September 07, 2009 - 06:02 PM UTC
Working on a Tunisian tiger, Lynx, Challenger 2, and a Leopard 2A6M CDN.
http://www.mvpa.org/
"Live, So That You May Live Forever".
Ontario,
KitMaker: 210 posts
Armorama: 81 posts
Posted: Wednesday, May 12, 2010 - 01:46 AM UTC
Panzer II is done. Moved onto a Russian SU-85 and finished it as well. The SU-85 is mounted on a base and I'm considering adding a figure to the finished product. Hmmmmm...
Anyways, currently working on a 1/16th scale Tamiya WWII German car that someone else started........ I pulled apart and re-built their work and now am finishing it.
I'll see if I can pull out some pictures (finally) and post up.
Alberta,
CanadaJoined: January 19, 2008
KitMaker: 6,743 posts
Armorama: 5 posts
Posted: Friday, May 14, 2010 - 04:10 AM UTC
Well it may not be a tank thingie , but I'm working on a RAF FE-8 in 48 scale , WNW SE5a and a BF 109 E3
Ontario,
KitMaker: 210 posts
Armorama: 81 posts
Posted: Friday, May 14, 2010 - 04:48 AM UTC
Awesome Terri..............
Pictures of my recently completed SU-85.... straight out of the box..... the old Tamiya kit. Leaves a lot to be desired compared to the newer kits now available (especially the tracks), but it was a really fun build............... for me anyways!! Got to mess with some new weathering techniques.
Let me know what you think...........
Ontario,
Armorama: 819 posts
Posted: Friday, May 14, 2010 - 08:31 AM UTC
Tom,
Nicely done!
I'm working on the Old DML Jagdpanzer IV L/48, added atak zimm, an armorscale barrel, replaced the molded on handles with wire, and will probably add replacement tracks.
I am almost finished an Italeri Staghound and a DML M2 Halftrack. Both just need a few little things done. I hope to get some pictures taken soon. I always have a problem posting here though
Darryl
CanadaJoined: April 01, 2008
KitMaker: 43 posts
Armorama: 36 posts
Posted: Saturday, May 15, 2010 - 11:27 AM UTC
Nice job on the SU-85.
I am currently working on a Lebanese Charioteer, a Magach5 from Lebanon in 82' and a French M-47 from operation Musketeer in 56'
Ontario,
CanadaJoined: January 11, 2003
KitMaker: 1,339 posts
Armorama: 637 posts
Posted: Saturday, May 15, 2010 - 12:38 PM UTC
After just over two years with the majority of my stash in hiding, I just recently finished Dragons "grasshopper" and have started working on AFV Clubs T34/76... Will be the first kit Ive attempted with a full interior.
Dave
Ontario,
Armorama: 819 posts
Posted: Sunday, May 16, 2010 - 12:45 AM UTC
Looks like lots of great builds. I hope people post them here for us to see
Darryl
Alberta,
Armorama: 5 posts
Posted: Sunday, May 16, 2010 - 04:03 PM UTC
Okay , here you go . This is where I'm at with the FE-8 so far . Scratch built with a few PE parts for the seat belts and instruments . You can see the build blog in the early aviation fourms on Areoscale .
Ontario,
KitMaker: 210 posts
Armorama: 81 posts
Posted: Wednesday, May 19, 2010 - 03:33 AM UTC
......well, sat down for around 1/2 an hour last night to put a few more parts on the 1/16th scale Tamiya German Kubelwagen. Build is going super slow........ time has not been on my side to sit down and get it done. Some pictures coming shortly.
Also already thinking about the next project I want to do. I think I'm going to dive into something Canadian from WWII. The time has come as it's something I've always wanted to do. I think it will be a Sherman..........
Ontario,
CanadaJoined: May 20, 2010
KitMaker: 11 posts
Armorama: 1 posts
Posted: Wednesday, May 19, 2010 - 05:36 PM UTC
Well, just joined this site today... found it googling for a way to create canvas cover which is missing from my FAMO 18t halftrack from Tamiya. Beautiful model but no canvas cover??? anyway found an answer here using tissue paper and white glue.. go figure lol.
back into scale modeling after 40+ years.. and working on the FAMO 18t , tamiya JSU-152 (also great), Dragon T34/85, Trupeter LMV (old model but godd practice) which has some fit issues.
Love this site and looking for a Club in my area..
Ontario,
CanadaJoined: January 03, 2007
KitMaker: 1,505 posts
Armorama: 382 posts
Posted: Friday, May 21, 2010 - 01:17 PM UTC
Ive seen it in the flesh..its stunning!
Im working on several things (go figgure) Emhars Whippet, A resin figure"morte",1:72 scale Snowberry, Stranraer"whistling shi*house",EDF battleship,and the Varyag.
Projects:
K44 Anti Tank gun
Diana
Albatros DIII
British Columbia,
CanadaJoined: March 12, 2010
KitMaker: 791 posts
Armorama: 592 posts
Posted: Thursday, May 27, 2010 - 11:07 AM UTC
On the Bench:
Diopark Mercedes
AFV Club CM-11
