We were all listening last time, but the Revell wrecker isn't really worth mentioning. The Revell 5 ton wrecker was a reboxed, early '70s(?) Renwal kit and was really bad. It is 1/32 or larger and lacks detail. It is not really that accurate. Unless you have to build something that looks kind of like a 5 ton(ish) wrecker in plastic straight from the box, it isn't worth building. You would have to rebuild almost every part to get it looking good and up to today's standards. Also, it is highly sought after on the "collectors" market, so it usually goes for a pretty high price. For what is in the box, I don't know why. One or two do come up on eBay pretty regularly.
Here is one built-up and for sale on eBay. You can see how bad it is.
I had one that I got
really cheap and used its frame, parts of the running gear, and some cab pieces as a base for my 1/35 M123A1C tractor (which is a much larger, 10 ton truck) and it looked closer to the right scale for it, not an M54 series 5 ton. The rest was tossed in the garbage can.
The lighter green parts of the cab and frame are from the Revell wrecker. Sorry for the crappy pic, but I had a cheap digicam back then.
The completed, highly modified, model.
As we stated before, the best way to get an M54 in plastic is still to use
"Animal's" M54 conversion with an M923/5 and an M35. It isn't that hard and looks great when done. Mine came out pretty good as an M54A1 guntruck and the conversion wasn't too difficult.
Same crappy digicam, but you get the idea. (Yeah, I know, I missed reshaping the nose to a flat profile, I realized it too late when I was already done painting. Oh well, so be it.)
