Previous topic: https://armorama.kitmaker.net/forums/154046&page=1
I'm currently reading the book while re-watching the HBO series (3rd time). I am going to model my Humvee off the HBO series humvee, for several reasons:
- lots of reference material
- more 'recognizable' as people who've seen the series will be able to easily identify with it
I have the undercarriage done, complete with D-Toys resin wheels/tires and I was just starting on the main chasis, although I'm haulting work on the humvee itself for now until I get the Eduard PE kit as the Verlinden PE kit is a disater and as I found out, not ment for the newer Tamiya M1025 kit.
So now I'm going to get started on the 'bits & bobs' like jerry cans, ammo boxes and doing some custom work on all the ruck sacks that hang off the side of the vehicle (doing some putty work to get the bed rolls nicely formed on top of the rucks as well as doing some lead foil straping).
The kits I'm using to create this uniqe vehicle are:
TAMIYA M 1025 Hummer
Edurads Hummer PE kit
Verlinden HumHummer Weapons Carrier Detail Set (useless)
TAMYIA Modern US Military Equipment Set
Trupeter US Marines Corps Iraq-2003
x2 Verlinden US Modern Soldier Gear
D-Toys Blue Force Tracker Kit
D-Toys HUMVEE Agressive pattern wheels/tires
Dragon M16/AR15 Quatermaster Series set
Legend AT4/LAW kit
x2 Eduard 1/35 Camouflage Netting/Masking US Type II 35672
I have just begun the project after 14 years away from modeling (yikes). My last model was a 1/48 A-10 Warthog.
Here is what I have done so far:
Undercarriage
Wheels:
Not fnished yet as I have a lot of weathering yet to do on them.
Body:
Just started with the main body. The interior is JA green and the exterior is a custom mix light tan.
Mk19:
A combination of the TAMIYA, Verlinden resin and PE. I cut the feed guides and barrel off the TAMYIA Mk19 and added them onto the resin body.
Colbert's M4:
Best I could do with using the Dragon Quatermaster kit to replicate Colbert's M4A1, which is equipped with a AN/PVS-17 night sight and a M203 grenade launcher. Even mannaged to get a little AN/PEQ-2 unit on it as well. Still needs some more work.
Packs:
I adding some putty to get the molding right of having the bed rolls on top of the rucks, plus adding the 'top flap' of the rucks coming over top of the bed rolls and added in strap grooves for some lead foil straps.
That's all so far. I'll keep everyone posted with my progress.
Dave
