After I removed the trailer frame from the sprue, I cleaned up the mould seems. I tried using an emery board and small jewellers files like with the ammo trailer but that was taking too long. I experimented and found that an Excel super sharp scalpel blade was much faster and did a very good job.
After cleaning up the springs on the suspension I glued the first one on using a slow setting gel glue. I find this glue best for small scale as it gives you some working time.
The pins on each suspension component fit very nicely into their respective recesses. This next picture you can see suspension parts in place and the forward support leg in the folded position.The right winch has been added on the back of the frame and in the lower right of the picture you can see the unattached winch.
I let those parts dray and then used a liquid weld cement to make sure they were secure. While it dried I assembled the wheels leaving one part still attached to the sprue to aid in painting later.
THe last picture is of the trailer complete with the winch handles added. The penny in the picture gives you an idea of the size one will have to deal with.
Dealing with the small size of the parts and waiting for the gel glue to set takes the most time. Once I start on the gun proper there will be more "hurry up and wait" as the glue sets between parts. While this trailer is virtually identical to the ammo trailer it went together quicker than the first one.
