Moulding seams run the length of of the one piece chassis, inside and out, and the soft plastic chatters when scraped to clean-up.
Well, following your comments, I began building the model yesterday.
There WERE moulding seams on the chassis which, scraping with the X-Acto, I got rid of in a couple of minutes. Now, the angular ones, towards the rear, they could (just could) be weld-lines? Whatever, they are, clean-up time was minimal.
The attachment of the fuel tank I found extremely simple it slotted on neatly and a couple of sweeps with the glue brush held it in place.
Now the rear section being attached to the floor, did give me a few minutes of concern, The fit was far too tight so I had to do some vertical sanding on either side to get it to click into place agin, it was a few minutes work, but fit was very good.
Later on, i'll be starting a proper Build-Log and take photos of the build...![]()
