Could you fellas that have used these Vallejo acrylic-polyurethane primers, give me an indication of the drying times you experienced?
cheers,
Grant.
Grant, actually Russ mentioned that and I agree. Dry times are very quick, fully cured (completely hardened) takes longer. I do believe the curing process continues even with top coats applied. I've top coated over these primers within an hour or two on occasion, although my preference is to let the primer dry/cure for a day before applying the other coats.
Kevin: Water-based paints such as Vallejo aren't going to adhere well to metals such as PE without something to bite onto. Tamiya is not a water-based paint and can obtain an adequate bite, and I would recommend priming first with the Tamiya you are using or a similar primer and then laying down a coat of the Vallejo primer over the top of it for color consistency under the base coat. Alternatively you can etch the metal with a mild acid, by scuffing/sanding, or by using a self-etching primer if you wish.
