Juweela of Germany has released a nice 1/32nd to 1/35th scale set of 15 plastic corrugated iron sheets.
Dioramas
Corrugated Iron Sheet
Posted: Monday, May 19, 2014 - 06:57 AM UTC
jimbrae
Provincia de Lugo, Spain / Espaņa
KitMaker: 12,927 posts
Armorama: 9,486 posts
Posted: Monday, May 19, 2014 - 10:10 AM UTC
I don't to be honest, see much if any sense in this product. Recently, i've been working with sheets of corrugated card and the effect is excellent (just paint on Gesso to make it impermeable). Probably considerably cheaper as well....
Trisaw
Posted: Monday, May 19, 2014 - 10:52 AM UTC
I believe one can buy a huge Evergreen or Plastruct corrugated styrene sheet close to 8X11 size for a few dollars as well.
jimbrae
Posted: Monday, May 19, 2014 - 10:57 AM UTC
Quoted TextI don't to be honest, see much if any sense in this product. Recently, i've been working with sheets of corrugated card and the effect is excellent (just paint on Gesso to make it impermeable). Probably considerably cheaper as well....
Yep, you can - I don't have any local stockists so......
Posted: Monday, May 19, 2014 - 11:03 AM UTC
I wouldn't knock anything until I've actually tried it. However, the best stuff I've ever sen is the corrugated metal (actual metal) in old HO scale Suydam building kits. The metal is actually better scaled for 1/35 than HO.
maartenboersma
Posted: Monday, May 19, 2014 - 11:38 AM UTC
I got a set there way to thick for 1/35,1/32 scale
Posted: Tuesday, May 20, 2014 - 02:26 AM UTC
I've also used heavy gauge corrugated aluminum siding from the model RR dept. You can dent it and ding it just like the real thing. And you can rust it and weather it with etching acid (but not too much as you won't have any siding left!)
erichvon
KitMaker: 1,694 posts
Armorama: 1,584 posts
Posted: Friday, May 23, 2014 - 08:04 AM UTC
I tend to use aluminium food trays and a paint tube squeezer. I just cut the required size sheet and run it through the squeezer. Produces great looking corrugated iron plus will bend to show damaged sheets. I saw the idea on here somewhere and would never dream of buying preformed sheets now when I can make the same thing for pence.
Posted: Friday, May 23, 2014 - 09:24 AM UTC
What I did was that I got a pack from Plastruct.. it has two large sheets.. then I get those aluminum food trays (I try to get the thin ones) and I cut a piece then I press it down on the sheet and just keep pushing it into it till it pretty much takes the corrugated shape.. and like the others said, you can bend it.. puncture it to simulate bullet holes.. so, it's more versatile
Hisham
Hisham
Posted: Friday, May 23, 2014 - 10:31 AM UTC
I got a set there way to thick for 1/35,1/32 scale![]()
actually not really:
the tite is missleading... those are supposed to be "Faserzement Platten" which would be better translated to "fiber cement plates"... those are know here as "Eternit"
those plates might look simmilar to corrugated iron and they are used the same way, but as they are thicker they are less flexible (not at all, to be exact)...
Posted: Friday, May 23, 2014 - 11:43 AM UTC
Asbestolux sheeting then?
Posted: Friday, May 23, 2014 - 05:55 PM UTC
yep...
Posted: Saturday, May 24, 2014 - 02:32 AM UTC
As Emily Litella was wont to say, "Never mind!"
