Armor/AFV: Group Builds
Build a model with your online buddies!
1/76 CHURCHILL A.V.RE - S.B.G Assault Bridge
KoSprueOne
Myanmar
KitMaker: 4,011 posts
Armorama: 1,498 posts
Posted: Sunday, March 15, 2015 - 05:11 AM UTC
JPTRR, Thanks for the compliment and for looking in
I followed the i-sheet for decal markings option 1, 5th Assault Regiment. And started a little weathering too
All WIP and finished pictures for this BLOG is here: https://imgur.com/a/T9zbg
KoSprueOne
Myanmar
Posted: Saturday, March 28, 2015 - 01:05 AM UTC
I started the rigging using 10-lb test fishing line. I couldn't work with the threads I have because of the stray fibers. The local marine/boat supplies store doesn't have the waxed rope fine enough for this scale either.
a little more weathering on the lower hull and running gear. This is not in final condition.
BTW, I've expanded my web search for the material this SBG Bridge is made to include "WWII Bailey Bridge". This was made of steel.
http://www.thinkdefence.co.uk/2012/01/uk-military-bridging-equipment-the-bailey-bridge/
thanks for looking …
KoSprueOne
Myanmar
Posted: Monday, March 30, 2015 - 06:11 AM UTC
Rigging is done before paint. I see there needs to be more tension (weight) on the lines. The Bridge Carrier Hinge points are not glued yet. I'll put weight on the bridge while I apply glue at these points later
KoSprueOne
Myanmar
Posted: Thursday, April 02, 2015 - 10:20 PM UTC
I have the day off today so I'm finally getting to this step of applying 'weight' to the rigging. This is what I did this morning.
The red ' ! ' and dotted arrows signify the cotton swab applying tension to the monofilament rigging. The white arrows indicate points of CA glue applications.
Hope this works …
DaGreatQueeg
Napier, New Zealand
KitMaker: 1,049 posts
Armorama: 841 posts
Posted: Friday, April 03, 2015 - 02:57 AM UTC
Hope this works …
Well it looks good so far My fingers are crossed for you too!
Brent
KoSprueOne
Myanmar
Posted: Friday, April 03, 2015 - 09:02 PM UTC
Thanks, Brent.
Yes, it worked I removed the cotton swab this morning and it stayed in position. It's not totally perfect but I'm satisfied with this look of 'weight' on the rigging supporting the bridge
next is final weathering with the turret installed with some dusting with pastels. Thanks for looking
JPTRR
RAILROAD MODELING
#051
KitMaker: 7,772 posts
Armorama: 2,447 posts
Posted: Friday, April 03, 2015 - 09:08 PM UTC
KoSprueOne,
She's shaping up! The weathering looks authentic. Did you find the Bailey? I recall someone made one long ago but don't recall who: Airfix; FROG; Heller..,.?
KoSprueOne
Myanmar
Posted: Friday, April 03, 2015 - 09:17 PM UTC
Thank you, Sir!
I found the history of the Bailey Bridge because I was researching what material it was made of. I figured it will give me a clue as to what the SBG Bridge was made of.
The link I found and posted above describes a material that is, welded but certainly not aluminum alloy. I then assumed it was steel
KoSprueOne
Myanmar
Posted: Saturday, April 04, 2015 - 12:46 AM UTC
This model is done.
Thanks, Matt, for the build campaign.
Thank you all for your comments, suggestions, assistance and just looking in to see how I was doing
firstcircle
KitMaker: 2,249 posts
Armorama: 2,007 posts
Posted: Saturday, April 04, 2015 - 02:44 AM UTC
Model looks really good. Maybe where the lines slightly curve as they meet the block pulleys, you might try just bending them straighter with something like a little loop of wire to pull them in a little, then just leaving it for a couple of days and removing the loop... it might just straighten them a little.
Love the scenic photos, fabulous instant diorama.
The weather looks absolutely terrible, and the scenery even worse!!! I'm practically in tears looking at it!
KoSprueOne
Myanmar
Posted: Saturday, April 04, 2015 - 06:33 AM UTC
Yeah, I hear what you're sayin. I might do that if over time it stretches out too much and sags. Thanks for the tip
and yes the weather
Dangeroo
#023
Zurich, Switzerland
KitMaker: 2,058 posts
Armorama: 1,656 posts
Posted: Saturday, April 04, 2015 - 11:54 PM UTC
Congrats on a great result! Really like the weathering, too. Though I do think the sand pebbles and dead tree are a bit out of scale...
Stefan
PS: What's up next?
KoSprueOne
Myanmar
Posted: Sunday, April 05, 2015 - 12:39 AM UTC
Hi Stefan, Thanks for the very keen observation.
what's next? While I have a few more 1/72 kits in the stash (picture), I'll probably take a break away from the small scales for awhile. I need to restart and finish a few unfinished projects waiting on the side of the bench
I'll get to these at a later time . . .
