Hi Robert, thanks for taking the time to read through the review. Personally I completely agree with your point on the casting marks regarding the turret. There are references back and forth and show both prominent and not so predominant lines. In the effort up speeding up the building process, softening the joint a bit and moving on might be best...mainly because there is only a couple mm showing through all the add on parts. As for the ERA blacks, you make a point as well...Legend has made a fantastic conversion for the blocks. I did notice a couple different styles in the blocks not to mention the haphazard approach to attaching them that opens the door for the kit supplied blocks to be sufficient in still being able to make a fine model OOB. Always the toughest decision a builder has when approaching a kit...to Aftermarket or Not to Aftermarket...that is the question!!
Thank you for your thoughts on the kit!
Kev, Looking forward to hearing about what you think of the GWN AMPS show! Only about 8 hours drive for me...much better than the 15 it took me to get to Indiana...LOL!!!
