Chieftain Mk 10
KitMaker: 10,955 posts
Armorama: 8,572 posts
Posted: Thursday, October 29, 2015 - 02:55 AM UTC
Darren Baker provides us with a close look at the contents of the Chieftain Mk 10 from Takom in 1/35th scale.
arpikaszabo
Praha, Czech Republic
KitMaker: 674 posts
Armorama: 637 posts
Posted: Thursday, October 29, 2015 - 03:09 AM UTC
I am building one right now. The detail is great, some shortcuts here and there, but nothing major as far as I can see. The turret assembly requires some persuasion, otherwise I can see nothing to complain about.
David_StoryModels
KitMaker: 113 posts
Armorama: 7 posts
Posted: Thursday, October 29, 2015 - 04:03 AM UTC
Will this cable be correct?
Metal Cable
RLlockie
KitMaker: 1,111 posts
Armorama: 938 posts
Posted: Thursday, October 29, 2015 - 12:44 PM UTC
Unlikely, I'd say.
The Valentine was a few tons lighter than a Chieftain so I'd be very surprised if the wire tow rope would be the same diameter. I have dims somewhere but around an inch is what I recollect.
Posted: Thursday, October 29, 2015 - 01:31 PM UTC
Sorry David wrong time period. I suspect Eureka or RMG will come to the rescue. If you just want the cable then RMG offers that I believe. but I will need to check scale.
Littorio
KitMaker: 4,728 posts
Armorama: 504 posts
Posted: Thursday, October 29, 2015 - 03:10 PM UTC
Darren thanks for the peek into the box, I do have a couple on order.
Regarding the tow cable and I'm not an expert but would it be the same as used on Chally 1? Eureka do have a Chally 1 tow cable set.
Dannyd
KitMaker: 803 posts
Armorama: 793 posts
Posted: Thursday, October 29, 2015 - 04:40 PM UTC
Accurate Armour do a set of modern British tank recovery ropes, I'm pretty sure the Challenger and Chieftain items are the same.
Also again with ref to the decals the rear hazard plates are the wrong colour, they should be a high visibility orange and red, they provide red and white which would suit a modern German tank.
Dan
arpikaszabo
KitMaker: 674 posts
Armorama: 637 posts
Posted: Saturday, November 21, 2015 - 02:34 AM UTC
Building my model, I have managed to come across an annoying issue: running alonside the top of the hull there is a rail, which is moulded solid on the Takom kit. It shold be recessed, on the Meng CAD images this detail is represented correctly. Prepare the razor saw, this was not fun to mend at all
Cantstopbuyingkits
European Union
KitMaker: 2,099 posts
Armorama: 1,920 posts
Posted: Saturday, November 21, 2015 - 03:09 AM UTC
Unlikely, I'd say.
A few tons? At 55 tons the Chieftain weighted as much as 4 of the 15 ton archers.
KitMaker: 6,687 posts
Armorama: 5,556 posts
Posted: Saturday, November 21, 2015 - 03:52 AM UTC
Which rail do you mean ? Is it the U-channel lying on its side visible in this image ?? :
http://data3.primeportal.net/tanks/erik_jan_eskes/chieftain_mk10_rev/images/chieftain_mk10_rev_100_of_136.jpg
Will be a lot of work if it needs fixing ...
RLlockie
Armorama: 938 posts
Posted: Saturday, November 21, 2015 - 01:11 PM UTC
It would be a lot of work if you used a razor saw and I'd anticipate the result not looking great anyway. A much better solution (I did it in the 1980s on a Tamiya MK 3) is to remove the upper section and replace with 1mm brass U channel on its side. It is surprisingly easy and quick and looks much better than the solid kit part.
Technically the cross section is an 'F' but doing this gives you a '6', which is better than the kit 'B' section. For a rebuild though, as this kit represents, remove all the wading rail behind the transverse depression stop rail and do not replace it, as that part was all cut off to fit the raised transmission covers. Obviously deep wading as a requirement had been dropped by then.
Sorry if my 'a few tons' caused confusion; call it British understatement😀
