Takom Chieftain Mk.11 build blog
RLlockie
KitMaker: 1,112 posts
Armorama: 938 posts
Posted: Sunday, April 24, 2016 - 11:56 PM UTC
Yes, Darren's pictures show the bin attachment brackets very well, which saves me uploading mine.
LeoCmdr
KitMaker: 4,085 posts
Armorama: 3,917 posts
Posted: Monday, April 25, 2016 - 01:08 AM UTC
Good...but can you explain your other recommendation?
"You might want to remove the wading rail behind the transverse depression stop rail, as these were removed when the raised transmission covers were fitted."
I don't know all the jargon used on the Chieftain so an image or explanation would be great...if you have time of course.
AKirchhoff
Germany
KitMaker: 307 posts
Armorama: 304 posts
Posted: Monday, April 25, 2016 - 01:31 AM UTC
Hi Jason,
I think what he meant is this:
The wading rail formerly surrounded the full engine deck covers. During upgrades, the rearmost engine covers were lifted up a little. During this conversion, at the rear of the engine deck covers this wading rail was removed. You can see this on the picture enclosed, when you look at the rear filler caps and behind the rear engine deck covers. There you can see only the remains of this wading rail. All the rail that was present behind the gun depression stoppers (these bars with the rubber top) was removed.
http://data3.primeportal.net/tanks/erik_jan_eskes/chieftan_mk11/images/chieftan_mk11_55_of_83.jpg
Hope that helps a little...
Andreas
LeoCmdr
Posted: Monday, April 25, 2016 - 01:46 AM UTC
Thanks, that clears it up Andreas. I knew where the wading rail was but just wasn't sure where it was trimmed down.
At least now I won't have to ask for a phased plasma rifle in the 40 Watt range.
RLlockie
Armorama: 938 posts
Posted: Monday, April 25, 2016 - 02:45 AM UTC
Yes, Andreas has it exactly. I was rather relieved to observe it when I built mine based on the Tamiya kit because it saved me the challenge of getting a length of 1mm brass channel to match the profile of the original with six bends in two directions and keeping it symmetrical.
The lower flange was left in place so it's not necessary to remove all traces of the wading rail, as photos show. I can post some tomorrow if desired.
Scottosaurus
KitMaker: 83 posts
Armorama: 59 posts
Posted: Monday, April 25, 2016 - 03:06 AM UTC
"Just what you see on the shelf, buddy." :-)
It's great to see this kit being blogged - it's next on my build list after the TAKOM AMX-13/90.
Scott
ChrisJohnson
KitMaker: 65 posts
Armorama: 53 posts
Posted: Monday, April 25, 2016 - 04:47 AM UTC
Hi Jason,
The wading rail formerly surrounded the full engine deck covers. During upgrades, the rearmost engine covers were lifted up a little. During this conversion, at the rear of the engine deck covers this wading rail was removed . . . you can see only the remains of this wading rail. All the rail that was present behind the gun depression stoppers (these bars with the rubber top) was removed.
In the image below, taken from the same series, it appears that the rail is only fully missing between the arrows I've added. While it looks as though it's been cut down at the rear of the deck, there is still a pronounced rail visible there.
Am I mistaken in my interpretation?
Chris
LeoCmdr
Posted: Thursday, June 09, 2016 - 11:25 AM UTC
Any updates on this build? I'm looking forward to seeing how it all goes together.
toby2282
KitMaker: 195 posts
Armorama: 112 posts
Posted: Saturday, July 04, 2020 - 01:57 AM UTC
Hi everyone. First of all an apology to Darren as this build has not moved on in four years. I have had a move to ship building and this kit has sat in a box awaiting completion.
However, it will be resurrected and completed. I’ve decided to do it as a vehicle on exercise as part of North Army Group parked up in on the side of a road with some crew.
There will be a short delay whilst we have some building work done in the new house then this will be my priority build.
Johnnych01
KitMaker: 604 posts
Armorama: 506 posts
Posted: Saturday, July 04, 2020 - 02:36 AM UTC
Will look forward to watching you complete this one Toby. This was the last mk Chieftain that I was on in Germany before we converted to Chally 1's in Sennelager.
