Trumpeter containers
Recon
KitMaker: 1,571 posts
Armorama: 764 posts
Posted: Monday, August 08, 2016 - 08:08 PM UTC
Would the 40 foot container fit on the M1070/M1000?
Thanks
Mike
Posted: Monday, August 08, 2016 - 08:27 PM UTC
No, it is too long for the trailer deck. The overall deck length is 10.58 m, which equals only 34.71 feet. The container would overhang the rear by a little less than 6 feet, which would not allow the rear ramps to come up. Their 20 foot container would fit though.
The 40 foot container is usually carrier on an M872 40' flatbed trailer.
Miniman Factory offers the M872 in resin...
...along with an M915A1 tractor...
... which has also been announced by Trumpeter. Hopefully they will do some trailers to go with it.
Recon
Armorama: 764 posts
Posted: Monday, August 08, 2016 - 08:52 PM UTC
Thanks for the reply.
Mike
terminators
France
KitMaker: 1,932 posts
Armorama: 1,907 posts
Posted: Monday, August 08, 2016 - 09:09 PM UTC
This one looks very cool with armored cab
Posted: Monday, August 08, 2016 - 09:50 PM UTC
That is actually an M915A3, which is a totally different truck built by Freightliner.
The M915 and M915A1 were AM General-built trucks.
Here is Miniman Factory's M915A1 guntruck.
terminators
France
Posted: Monday, August 08, 2016 - 10:21 PM UTC
Oh yes perhaps for a next kit ?
pgb3476
KitMaker: 977 posts
Armorama: 976 posts
Posted: Monday, August 08, 2016 - 11:27 PM UTC
Trumpeter also makes a 20ft Conex.
Vodnik
Warszawa, Poland
KitMaker: 4,342 posts
Armorama: 3,938 posts
Posted: Tuesday, August 09, 2016 - 12:20 AM UTC
Of course they will.
Posted: Tuesday, August 09, 2016 - 01:30 AM UTC
Very cool. I had not seen the M872 trailer yet. Any other trailers they plan on doing? An M870A1 Lowbed would also be nice. It would be perfect to put the Meng D9R on.
KurtLaughlin
KitMaker: 2,402 posts
Armorama: 2,377 posts
Posted: Tuesday, August 09, 2016 - 04:55 AM UTC
In point of fact they are not CONEX containers, rather I believe they are ISO containers. CONEX containers are smaller and use different locking connections (I think). So, if you are planning on doing a US military container make sure it is the right type.
KL
Thirian24
KitMaker: 2,493 posts
Armorama: 2,344 posts
Posted: Tuesday, August 09, 2016 - 05:24 AM UTC
If they did the M870A1, then this would be a sweet build.
matt
KitMaker: 5,957 posts
Armorama: 2,956 posts
Posted: Tuesday, August 09, 2016 - 05:08 PM UTC
KL
CONEX seems to have turned into a generic term for any intermodal container.
Posted: Tuesday, August 09, 2016 - 05:29 PM UTC
1/35th scale CONEX container from MecModels :
AFAIK, these have been replaced by the Tricon and Quadcon container series :
Tricon :
Quadcon :
Vodnik
Warszawa, Poland
Posted: Tuesday, August 09, 2016 - 05:31 PM UTC
You would also need M983A4 for that...
Posted: Tuesday, August 09, 2016 - 06:19 PM UTC
AFAIK, these have been replaced by the Tricon and Quadcon container series...
You are correct. The reason they are called Tricon and Quadcon is that each smaller section connects together to make a 20 foot ISO-sized container. On the Tricon, 3 sections are joined together. On the Quadcon, 4 sections are joined together.
Tricon
Quadcon
To build it exactly as in the picture, yes. The current Trumpeter M983 tractor could also pull the M870A1 /w D9R just fine as well though.
Removed by original poster on 08/10/16 - 13:32:45 (GMT).
easyco69
KitMaker: 2,275 posts
Armorama: 2,233 posts
Posted: Tuesday, August 09, 2016 - 06:59 PM UTC
Whats the name of that big hauler?
Posted: Tuesday, August 09, 2016 - 07:04 PM UTC
Well I just bought into Italeri's new LHS HEMTT so if Trumpeter makes good on their announcements then it looks like I am going to be in the trucking business!
Posted: Tuesday, August 09, 2016 - 07:06 PM UTC
It is an M983A4 HEMMT tractor.
Trumpeter offers an M983 tractor (earlier version) as the prime mover for the Patriot system...
...which is the one I will use to build my M1074 PLS, along with Italeri's M1120 LHS parts. This combo is what I was talking about in your M1120 LHS thread.
DG0542
KitMaker: 125 posts
Armorama: 125 posts
Posted: Tuesday, August 09, 2016 - 07:43 PM UTC
I'm building this kit (well the AFV CLUB Re-box with the Patriot PAC2) and its very nice. I would post pictures but at work, and don't have a third part photo share site.
Hisham
Al Qahirah, Egypt / لعربية
KitMaker: 6,856 posts
Armorama: 6,363 posts
Posted: Tuesday, August 09, 2016 - 07:46 PM UTC
Regarding the M915, I hope we get the option of separate tractor and trailer kits
For the M1120... To build something like this one unloading the HUMVEE.. is the Italeri kit sufficient, or would you need to kitbash both the Italeri and Trumpeter kits?
Hisham
mvaiano
Sao Paulo, Brazil
KitMaker: 1,054 posts
Armorama: 1,050 posts
Posted: Tuesday, August 09, 2016 - 08:03 PM UTC
Sorry, but it isn't a D9. This tractor is probably a D6, much smaller than a D9.
Posted: Tuesday, August 09, 2016 - 08:10 PM UTC
Hisham
It is looking like for a really top notch model you are going to have to combine the Italeri LRS parts with the Trumpeter HEMTT tractor.
(Just my opinion - and Gino's)
Hisham check out my thread (I'm sure you have already) over at:
http://armorama.kitmaker.net/forums/250147
Where in I attempt to bring the Italeri HEMTT up to the same standards as the new LHS parts in the kit.
Posted: Tuesday, August 09, 2016 - 08:21 PM UTC
Yes, the Italeri kit will build into what you see in your pic, minus the cab armor, which is available from Real Model via an Eduard PE set.
It comes down to how detailed of a model you want. If you want a highly detailed model, I recommend kit-bashing the Italeri LHS parts with the Trumpeter M983. If you just want a model of an M1120 LHS, go with the Italeri kit from the box.
Bottom line, kitbashing isn't a must to get an M1120 LHS as you see in the pic.
Oh well, it would still be great to have an M870A1 in plastic as well. Again, Miniman Factory already does one in resin if Trumpeter doesn't do one.
HermannB
Bayern, Germany
KitMaker: 4,099 posts
Armorama: 4,067 posts
Posted: Tuesday, August 09, 2016 - 09:52 PM UTC
Hisham
I also highly recommend Trumpeters M983 kit since you can save all the updates and scratch builds that you need for the Italeri base. I can tell you that upgrading the LHS and flatrack is a work for itself. Perhaps if you wait a while, I think (hope) that Trumpeter will release other HEMTT variants. I provided them with references on M977 and M978.
