Review
RyeField: M1 Assault Breacher
staff_Jim
Staff MemberPublisher
New Hampshire, United States
KitMaker: 12,490 posts
Armorama: 6,577 posts
Posted: Friday, May 05, 2017 - 02:53 AM UTC
A look inside the box of this new kit from Rye Field Model, the M1 Assault Breacher Vehicle (ABV), nicknamed The Shredder. A mine and explosives clearing vehicle, based on the M1 Abrams-chassis.
Read the Review
duttons
Australia
KitMaker: 190 posts
Armorama: 181 posts
Posted: Friday, May 05, 2017 - 04:15 AM UTC
To answer your question.
Minefields are generally termed an obstacle or obstacle belt as they often have more than one type of obstacle, like tank ditch etc all designed to achieve an effect.
During an assault you initially breach the obstacle, often under fire, allowing assault forces through then reduce the obstacle, making it smaller allowing more and more forces through, then follow on forces remove it completely.
Hence the vehicle name, assault, as its designed to do it under fire so no crew exposed, breach as in the initial making and proving of the lane through the obstacle.
Hopefully clears it up without going into all the details that might be available on these sort of operations.
Thanks for review, had hoped this would come out in plastic as there are some awesome videos of its use, particularly the viper explosive charge, on the internet. Awesome vehicle, hope they do the other configuration with rollers to prove the lane rather than the blade as well.
KitMaker: 17,499 posts
Armorama: 13,591 posts
Posted: Friday, May 05, 2017 - 07:37 AM UTC
...hope they do the other configuration with rollers to prove the lane rather than the blade as well.
I have never seen the ABV with rollers. I have only seen it with the plow (as this kit has) and with a Pearson dozer blade. I believe the lanes are still proofed with standard roller tanks.
duttons
Australia
KitMaker: 190 posts
Armorama: 181 posts
Posted: Friday, May 05, 2017 - 08:12 PM UTC
My mistake, absolutely right, just recalled two variants, as you say, the full width blade or track width ploughs.
Hope they do both options.
Thanks for fixing failing memory.
DutyFirst1917
KitMaker: 93 posts
Armorama: 86 posts
Posted: Sunday, May 07, 2017 - 02:27 AM UTC
I like seeing the anti slip molded on...too much of a PITA to make on my own
Taeuss
Manitoba, Canada
KitMaker: 3,495 posts
Armorama: 3,484 posts
Posted: Monday, May 08, 2017 - 03:21 AM UTC
Thanks for the peak inside, wow, what cool-looking beastie! Ditto on the anti-slip as its easy for them to mold it on.
