Dragon M1A2 SEP v2 #3556 RFI
2805662
KitMaker: 447 posts
Armorama: 442 posts
Posted: Thursday, July 12, 2018 - 01:24 AM UTC
Could someone with this kit please measure the height/diameter of part A29 for me? This is the v2 specific ICWS cupola adapter. Thanks.
amoz02t
#192
KitMaker: 1,154 posts
Armorama: 1,121 posts
Posted: Thursday, July 12, 2018 - 03:11 AM UTC
Hello. Is this the correct part for the ICWS cupola adapter?
Sorry for the poor quality cell phone photos as I just ran these quickly during my lunch break.
amoz02t
#192
Posted: Thursday, July 12, 2018 - 03:15 AM UTC
If this is the correct part, here are some dimensions. All of this measured in inches.
Hope this is helpful? Please let me know if there is another feature I can try to measure. All the best- Stuart
2805662
KitMaker: 447 posts
Armorama: 442 posts
Posted: Thursday, July 12, 2018 - 09:25 AM UTC
Wow! Thanks Stuart! Very helpful! And thank you for removing the piece from the spruce!
Just confirming that the overall height (including the 0.015” mounting plate) is 0.0965”? Also confirming that the diameter of the tallest piece is 1.1795”...just can’t see the outside diameter of that mounting piece (with the bolts - I may’ve missed that).
amoz02t
#192
Posted: Thursday, July 12, 2018 - 10:10 AM UTC
G'day Greg! Oops... You are correct sir! I missed the outer most diameter... here it is
Yes I also confirm all your numbers read above. No worries on getting the part free if it helps the cause! Happy to help and best of luck with the effort.
Stuart
2805662
KitMaker: 447 posts
Armorama: 442 posts
Posted: Thursday, July 12, 2018 - 12:08 PM UTC
Thanks Stuart.
Trying to understand the spacer and cupola compared to the non-CROWS equipped tanks. If possible (no stress if you can’t!); how does part X33 interface with part A29? Is there a size difference between the unused X32 and its replacement part, A12?
Cheers.
amoz02t
#192
Posted: Thursday, July 12, 2018 - 03:43 PM UTC
Greg if I understand your question correctly, are you asking how these fit together? Please see the images here showing the four guides on A29 mating with the inner diameter of X33 that hold the parts flush.
The X sprue
X33 upper side
X33 under side
amoz02t
#192
Posted: Thursday, July 12, 2018 - 03:48 PM UTC
Now A29 laid into the under side of X33
...and parts off set to show the interface...
When set together, the outer part diameters are flush.
amoz02t
#192
Posted: Thursday, July 12, 2018 - 04:11 PM UTC
No. Looks like the only differences are the attachment points, (or depressions) on part A12. Likewise top and underside. Both parts measure the same across flats. Please see here...
Please let me know if this is clear as it is easy to add more photos or details.
Greetings from Louisville, KY! -Stuart
2805662
KitMaker: 447 posts
Armorama: 442 posts
Posted: Thursday, July 12, 2018 - 04:25 PM UTC
Stuart - fantastic. Thanks!
You interpreted correctly, I was confirming how the two pieces fit together to see how tall the overall spacer was (was it 0.0965” or was it 0.0965” + the height of the cupola itself).
If I could find this kit at a reasonable price, I’d grab it! Thanks for helping out.
Greg - from chilly, winter Australia 🇦🇺
2805662
KitMaker: 447 posts
Armorama: 442 posts
Posted: Thursday, July 12, 2018 - 04:34 PM UTC
Stuart - could you compare the original spacer (X3 + X12?) to the new one (A29)?
amoz02t
#192
Posted: Friday, July 13, 2018 - 07:38 AM UTC
Greg- Please see the photos here. I guess I do not fully understand how X3 & X12 work with each other as the diameter of X12 is larger? I overlaid A29 with each to try to show this as well as the overall dimensions. Please share your insights into how this should look together as I clearly need help?
Hope to discuss this with you soon my friend!
amoz02t
#192
Posted: Saturday, July 21, 2018 - 06:03 AM UTC
Bump?
2805662
KitMaker: 447 posts
Armorama: 442 posts
Posted: Sunday, July 22, 2018 - 06:25 AM UTC
Thanks for the bump - thought I had replied 😊
I think I need to get this kit. The hunt begins.
