Building a 1/35 UNIFIL FRENCHBATT Leclerc S2
ChadRach
Seine-Saint-Denis, France
KitMaker: 28 posts
Armorama: 28 posts
Posted: Tuesday, January 01, 2019 - 10:10 AM UTC
The Leclerc tank was deployed in south Lebanon by the French Army for UNIFIL peacekeeping mission from 2006 until 2010. The model kit is based on the UNIFIL Leclerc S2 number 643 as seen in november 2007.
Kit and aftermarket products used for this project:
Tamiya 35279 French Tank Leclerc Series 2
Bronco AB3525 Leclerc MBT Workable Track Link Set
Blast Models BL35138K Update Set for Leclerc SERIE 2
Voyager Model PE3507 Leclerc Series 2 update set
Echelon Decals ECH356002 UNIFIL Leclerc T6 UN
Sources and documents which helped me builduing this project are:
Samer Kassis tremendous photo archives (the main source for the Leclerc 643)
My own photo archives of the Leclerc tank (available trough Flickr)
https://www.flickr.com/photos/[email protected]/collections/72157705226234535/
Oliver Carneaus website: http://olivier.carneau.free.fr
Walter Lampel amazing and inspiring job on Armorama http://www.armorama.com/modules.php?op=modload&name=SquawkBox&file=index&req=viewtopic&topic_id=164355&page=1
terminators
France
KitMaker: 1,932 posts
Armorama: 1,907 posts
Posted: Tuesday, January 01, 2019 - 10:21 AM UTC
A big project ! Have fun !
panamadan
KitMaker: 1,511 posts
Armorama: 1,447 posts
Posted: Tuesday, January 01, 2019 - 11:55 AM UTC
Finish that Merit kit!
I'll be watching!
Dan
ChadRach
KitMaker: 28 posts
Armorama: 28 posts
Posted: Wednesday, January 02, 2019 - 07:06 AM UTC
First thing to do is the anti-slip surface. After having tested several types of sand and sprays I found the most matching texture for French anti-slip surface by using the Montana Cans Granit effect spray.
ChadRach
KitMaker: 28 posts
Armorama: 28 posts
Posted: Wednesday, January 02, 2019 - 07:25 AM UTC
Real vehicles show rough cast parts on the rear end of the turret. To recreate it in scale I've tried another effect spray, this time the Crelando/Baufix stone effect spray.
ChadRach
KitMaker: 28 posts
Armorama: 28 posts
Posted: Thursday, January 03, 2019 - 08:28 AM UTC
The hull is updated with elements from both Blast Models and Voyager Model sets. Bolts made from Plastruct styrene hex rod are added where needed.
LeoCmdr
KitMaker: 4,085 posts
Armorama: 3,917 posts
Posted: Thursday, January 03, 2019 - 10:06 AM UTC
Great start to your build. Very nice work on the anti-slip. I used a very similar product on my Leclerc. The Tamiya Leclerc kit is one of their best modern kits.
Not to highjack your awesome build, but perhaps for more inspiration, here is my UNIFIL Leclerc build and completed diorama.
ChadRach
KitMaker: 28 posts
Armorama: 28 posts
Posted: Monday, January 14, 2019 - 08:08 AM UTC
Wonderful work Jason, your Leclerc looks great and your diorama recreats nicely a southern Lebanese scenery , I love it!!
ChadRach
KitMaker: 28 posts
Armorama: 28 posts
Posted: Monday, January 14, 2019 - 08:35 AM UTC
Voyager Model gun barrel is drilled
The final result.
I combined both the sets from Voyager Model and Blast Models to come out with a better looking 120mm smoothbore cannon
ChadRach
KitMaker: 28 posts
Armorama: 28 posts
Posted: Monday, January 14, 2019 - 08:43 AM UTC
Work in progress...
flugwuzzi
Lower Austria, Austria
KitMaker: 633 posts
Armorama: 599 posts
Posted: Monday, January 14, 2019 - 11:16 PM UTC
Great work on the details.
How do you cut clean discs from the Plastruct rods?
I always get dodgy rivets this way ... yours look much better ;-)
Keep up the good work.
cheers
Walter
dutik
Germany
KitMaker: 134 posts
Armorama: 134 posts
Posted: Tuesday, January 15, 2019 - 09:25 AM UTC
Looks really nice right now!
Great idea to use granite spray to create non-skid surfaces. I've used granite spray in modelling too - but just to paint granite...
What is the reason behind the Blast set? Did Tamiya miss something (do't beleave that Tamiyas details are not good enough) or is it to create a version not provided in the kit?
Keep rolling!
ChadRach
KitMaker: 28 posts
Armorama: 28 posts
Posted: Friday, January 18, 2019 - 06:12 AM UTC
cheers
Walter
Thanks Walter, your work on the Leclerc inspired me a lot.
As for the clean cuts, I used first an 8 blade pickle slicer to cut an end of the Plastruct rod into 7 equal parts. Each part measuring about 2 mm would be cut into 4 or 5 slices.
I used a smaller cutter blade I got to lighten the pressure while cutting the 2 mm rods
I admit that even with such a technique I manage to get a certain amount of waste.
ChadRach
KitMaker: 28 posts
Armorama: 28 posts
Posted: Friday, January 18, 2019 - 06:26 AM UTC
Keep rolling!
Thanks
Blast models did a really nice detail work regarding most of the kit and notably for the Leclerc 120mm gun. Tamiya's Leclerc is fine enough but lacks of extra details when you manage to get next to the beast in real life
ChadRach
KitMaker: 28 posts
Armorama: 28 posts
Posted: Friday, January 18, 2019 - 06:30 AM UTC
Applying a basic coat of Tamiya XF-67 NATO Green
ChadRach
KitMaker: 28 posts
Armorama: 28 posts
Posted: Friday, January 18, 2019 - 06:42 AM UTC
Applying roughly Tamiya XF-68 NATO brown and XF-69 NATO black without worrying about the sharpness of the camouflage scheme since it will be covered with a UN white camo.
Making the Leclerc side skirts looking a bit more realistic
JSSVIII
KitMaker: 1,169 posts
Armorama: 1,067 posts
Posted: Friday, January 18, 2019 - 12:14 PM UTC
Very nice work Chadi!
Bodeen
#026
KitMaker: 1,742 posts
Armorama: 1,357 posts
Posted: Friday, January 18, 2019 - 04:36 PM UTC
A beautiful job so far. Can't wait to see the finished product.
flugwuzzi
KitMaker: 633 posts
Armorama: 599 posts
Posted: Monday, January 21, 2019 - 07:56 AM UTC
Great work Chadi.
Good luck with the white paint. Can't wait to see your approach.
Walter
ChadRach
KitMaker: 28 posts
Armorama: 28 posts
Posted: Saturday, March 16, 2019 - 06:36 PM UTC
Applying salt for the chipping effect:
ChadRach
KitMaker: 28 posts
Armorama: 28 posts
Posted: Saturday, March 16, 2019 - 06:42 PM UTC
The white paint job is now finished:
ChadRach
KitMaker: 28 posts
Armorama: 28 posts
Posted: Saturday, March 16, 2019 - 06:46 PM UTC
Removing the salt:
ChadRach
KitMaker: 28 posts
Armorama: 28 posts
Posted: Saturday, March 16, 2019 - 06:50 PM UTC
Preparing the rubber skirts for paint:
ChadRach
KitMaker: 28 posts
Armorama: 28 posts
Posted: Saturday, March 16, 2019 - 07:05 PM UTC
Conceiving the UN markings templates out of the Echelon decal sheet:
ChadRach
KitMaker: 28 posts
Armorama: 28 posts
Posted: Saturday, March 16, 2019 - 07:08 PM UTC
Basic painting, cleaning and building Bronco's Leclerc tracks:
