Armored Warfare - Camo Schemes
ccordoba7141
KitMaker: 27 posts
Armorama: 24 posts
Posted: Saturday, March 23, 2019 - 06:13 PM UTC
After doing about a full year of modern IDF AFV's, I've gotten a bit numb of doing the normal "Israeli Desert Grey" paint scheme......not much to the imagination there......so I've been toying around with the idea of spicing things up a bit, even if it might fall into the realm of "what if". Even though I do not play or participate in the computer on-line game of Armored Warfare, I have noticed that players in the game add some quite interesting and unique camo schemes to their fighting vehicles. I was wondering if anyone has done this on a real kit, or knows of anyone that might be able to give me some pointers of how to proceed? Some examples would be:
https://www.google.com/search?biw=1188&bih=566&tbm=isch&sa=1&ei=cxKXXO7LIqKk_QbO6JSoCg&q=sabra+mk2+camo+armored+warfare&oq=sabra+mk2+camo+armored+warfare&gs_l=img.12...111014.121985..128550...3.0..1.717.10177.3-1j7j9j2......1....1..gws-wiz-img.m0XW2HWK_VU#imgrc=eHtVhnL34wa9DM:
https://www.google.com/search?biw=1188&bih=566&tbm=isch&sa=1&ei=-hCXXIX8Da_L_QbNm7uoCA&q=flashpoint+1+camo+armored+warfare&oq=fla&gs_l=img.1.0.35i39l2j0i67l7j0.362467.369539..373374...1.0..3.1601.6866.3-1j4j8-3......2....1..gws-wiz-img.....0..0i10.TzA1rxYuvI0#imgrc=1af_7UXZIOBOcM:
https://www.google.com/search?q=merkava+2d+black+eagle&source=lnms&tbm=isch&sa=X&ved=0ahUKEwj31Ly0gZrhAhXMJt8KHTeHB7UQ_AUIDigB&biw=1188&bih=566&dpr=1.15#imgrc=evNhTkq82--L7M:
https://www.google.com/search?biw=1188&bih=566&tbm=isch&sa=1&ei=-hCXXIX8Da_L_QbNm7uoCA&q=flashpoint+1+camo+armored+warfare&oq=fla&gs_l=img.1.0.35i39l2j0i67l7j0.362467.369539..373374...1.0..3.1601.6866.3-1j4j8-3......2....1..gws-wiz-img.....0..0i10.TzA1rxYuvI0#imgrc=VidNCBW21bPaKM:
Posted: Saturday, March 23, 2019 - 10:00 PM UTC
It would require a LOT of tedious masking
Some of the patterns are "easier" or a least on the same level of difficulty as any "normal, real world" hard edged pattern.
For the mesh patterns I wonder if it would be possible to use some kind of real mesh.
Paint the orange, hold down a mesh and carefully fill in with black/very dark grey. Narrow masking tape would probably do the job better though (but with more work ...)
This, real life, camo is probably just as difficult:
TopSmith
KitMaker: 1,742 posts
Armorama: 1,658 posts
Posted: Sunday, March 24, 2019 - 05:09 AM UTC
The second link might be effective but you have to keep in mind the purpose of camouflage. Usually, it is meant to hide or conceal. A dazzle scheme is meant to make it difficult to judge size or distance. Today's laser range finders make dazzle ineffective. The other 3 links schemes are the here I am, shoot me schemes. Another thing to consider is the skill it takes to apply the scheme. Can the average guy apply the scheme/paint or will it be a factory team that is required?
If a gaming signature paint is wanted, Look at some of the Flying Circus paint schemes from WW1 or the Dazzle schemes from WW2 ships. You could try a mirror paint scheme so when you backed into the brush it looked like the brush.
ccordoba7141
KitMaker: 27 posts
Armorama: 24 posts
Posted: Sunday, March 24, 2019 - 07:51 AM UTC
You guys are all probably correct. I know it's not too "real world" to paint these types of camo's, but I was considering the challenge and the appeal of something "different". Robin makes a good point with that Berlin camo on the Chieftain....even though it's bright, it's purpose was not to hide or conceal, but to breakup the silhouette of the tank within an urban environment. I figure that some of these I'm considering (as well as others) could serve the same or similar purpose.
I've also been checking around the web all of today for some type of help or ideas as to how to proceed and I've found two gaming websites that have stencils for gaming models (www.fallouthobbies.com and www.anarchymodels.co.uk). Seems that they produce or have just what would help in this project. Even have some additional things I hadn't considered.
Thanks for the comments.
M4A1Sherman
KitMaker: 4,403 posts
Armorama: 4,078 posts
Posted: Sunday, March 24, 2019 - 08:08 AM UTC
Hi, Guys!
Way back in the '80s, I did a "What-If" using the lower half of an old TAMIYA M60A1 mated to an equally old TAMIYA M551 Turret that I "souped-up" with various "stand-off" weaponry. The paint job was kind of wild- I started with an FS 34087 OD base-color, and then I airbrushed on a medium-to-Dark Gray (FS 36081) "cloud-pattern", after which, I applied a lightened, smaller "cloud-pattern" of Field Drab (FS 30118)... Lastly, I applied smaller "blotches" of Medium Brown (FS 30252) and Green Drab (FS 34086), overall... The thing looked SICK!!! I was almost embarrassed to place it with my other stuff that I keep behind glass.
Don't know what happened to it... I'm sure that it's tucked away in a box somewhere at the other house. I'm able to refer back to the colors and particulars of my models because I keep an inventory file-system of my built and un-built stuff... I'm just too lazy to check right now, it being Sunday and all that...
Posted: Sunday, March 24, 2019 - 08:09 AM UTC
Keep us posted!
It would be interesting to see how it turns out
ccordoba7141
KitMaker: 27 posts
Armorama: 24 posts
Posted: Sunday, March 24, 2019 - 08:20 AM UTC
Dennis......if you ever find it, please make sure to post it. Sounds definitely interesting.
M4A1Sherman
Posted: Sunday, March 24, 2019 - 08:30 AM UTC
I'll need to buy a good digital camera with a USB port, first...
b2nhvi
KitMaker: 1,124 posts
Armorama: 1,014 posts
Posted: Sunday, March 24, 2019 - 08:18 PM UTC
Hey, Robin. Is this the Hawaii National Guard's new camo scheme???
b2nhvi
Posted: Sunday, March 24, 2019 - 08:24 PM UTC
Got tired of 3 tone NATO on Leopards. Did this as a "what if" ....
Posted: Sunday, March 24, 2019 - 09:41 PM UTC
Certainly looks hot enough ....
ccordoba7141
KitMaker: 27 posts
Armorama: 24 posts
Posted: Monday, March 25, 2019 - 02:16 PM UTC
Tim, are those Colombian markings on that Leo?
MLD
Vermont, United States
KitMaker: 3,569 posts
Armorama: 2,070 posts
Posted: Monday, March 25, 2019 - 02:39 PM UTC
I can attest to the usefulness and value for the money of the Fallout hobbies stencils.
But that said, I used them as 'positive' masks (or is it negative?) placing the cut out centers of the hexes down in layers on a sci-fi project.
The hex set comes with three sizes, I used the smallest two of them here.
I have not sprayed cammo through the 'net' yet, but hope to soon on the Gundam hovertruck.
Their youtube videos show the effects on sci-fi ships.
ccordoba7141
KitMaker: 27 posts
Armorama: 24 posts
Posted: Monday, March 25, 2019 - 03:05 PM UTC
Mike, looks sharp. I went ahead and ordered a few of their stencils this morning, hoping that they will help me do the job. Got the hex mesh and the digi-camo, but all the others look quite interesting also.
b2nhvi
Posted: Monday, March 25, 2019 - 06:32 PM UTC
CAC : Yes. Colombian Army. When the Dutch had the fire sale on their armor Finland jumped on the Leo 2 A6s. With their neighbors to the east getting more and more rabid I thought Colombia might be interested in some first grade armor. Added A/C to the rear of the turret, some extra stowage and bumped up the loader's gun to a .50 cal. (The better to shred the jungle!)
ccordoba7141
KitMaker: 27 posts
Armorama: 24 posts
Posted: Tuesday, March 26, 2019 - 06:36 AM UTC
Nice work on that Tim. Definitely liked the added .50. Keep up the good work!
b2nhvi
Posted: Thursday, March 28, 2019 - 06:36 PM UTC
M 1A1. KaHe Pele (Lava Flow) camo. Mauna Loa Armored Cav. King Kamehameha Guard. Puna District. Hawaii. Blame Robin, guys. He's the one that put the idea in my head. url=https://gallery.kitmaker.net/showphoto.php/photo/469062][/url]
b2nhvi
Posted: Thursday, March 28, 2019 - 09:15 PM UTC
"Definitely liked the added .50. Keep up the good work!" .... Have the guys on here to thank for helping me logic out the .50 mount.
ReluctantRenegade
Wien, Austria
KitMaker: 2,408 posts
Armorama: 2,300 posts
Posted: Thursday, March 28, 2019 - 09:36 PM UTC
In the late '80s the IDF tested a three-tone, as well monochrome haze-gray and olive-green schemes on Merkavas.
https://armorama.kitmaker.net/forums/252044#2134430
ccordoba7141
KitMaker: 27 posts
Armorama: 24 posts
Posted: Tuesday, April 07, 2020 - 10:16 AM UTC
Hope all are staying safe. I've been holed up here in my apartment in Queens NYC trying to keep safe from Covid. Under normal conditions my wife has a problem with me taking over a corner of the dining room table in order to practice my hobby (no room for a workbench in these small apartments), but she finally gave in (at least for now). Trying to finally start on this project of doing different camos based on some that I have seen in Armored Warfare PC game.
ccordoba7141
KitMaker: 27 posts
Armorama: 24 posts
Posted: Tuesday, April 07, 2020 - 10:21 AM UTC
Just finishing up on painting, next will come sealing and weathering.
ccordoba7141
KitMaker: 27 posts
Armorama: 24 posts
Posted: Tuesday, April 07, 2020 - 10:48 AM UTC
This is the inspiration:
Posted: Tuesday, April 07, 2020 - 11:34 AM UTC
God to hear that you are getting some painting done
ccordoba7141
KitMaker: 27 posts
Armorama: 24 posts
Posted: Tuesday, April 07, 2020 - 01:05 PM UTC
More inspiration:
work so far:
ccordoba7141
KitMaker: 27 posts
Armorama: 24 posts
Posted: Tuesday, April 07, 2020 - 01:08 PM UTC
larger picture:
