Matilda - Caunter- Masking
wildbill426
KitMaker: 403 posts
Armorama: 375 posts
Posted: Monday, January 13, 2020 - 07:07 AM UTC
In not too long I intend to start Tamiya's new tool Matilda. But masking over all those irregular surfaces for the camo makes me....well....irregular. But I know it can be done! Can some intrepid readers share with me some tips, videos, articles and words of encouragement that may make this happen? Thank you, and happy new year to all.
Posted: Monday, January 13, 2020 - 07:25 AM UTC
https://www.youtube.com/watch?v=9VENE4ns_8o
https://www.themodellingnews.com/2015/04/a-matilda-in-caunter-clayton-shades-his.html
http://armorama.com/forums/277129
McRunty
#491
Missouri, United States
KitMaker: 602 posts
Armorama: 191 posts
Posted: Monday, January 13, 2020 - 09:03 AM UTC
I masked mine with Tamiya tape. I didn't push down too hard on the tape so it was laying flat over irregular shapes and then sprayed at a 90 degree angle straight at the tape, doing my best to ensure I didn't get any bleed.
Came out ok in the end.
wildbill426
KitMaker: 403 posts
Armorama: 375 posts
Posted: Tuesday, January 14, 2020 - 02:37 AM UTC
That's a great tip: it makes sense...and your tank looks great.
AgentG
KitMaker: 1,109 posts
Armorama: 1,095 posts
Posted: Tuesday, January 14, 2020 - 03:29 AM UTC
This is a Valentine, but the idea is exactly the same. I used tape, more tape, additional tape and Silly Putty. Cutting the tape into strips and shapes helps it to conform to the irregular shapes. I burnished the edges tight. I also cut the tape between the engine louvers and inserted Silly Putty in the gaps. I left the headlights and some other bits off until painting was complete. Having a guide is essential.
G
Posted: Tuesday, January 14, 2020 - 03:53 AM UTC
Just be aware that silly putty does suffer from mission creep the longer it is left on the model which can make it hard to remove.
AgentG
Posted: Tuesday, January 14, 2020 - 04:09 AM UTC
Never had an issue with it what so ever.
G
Posted: Tuesday, January 14, 2020 - 04:47 AM UTC
No matter how carefully you mask, there is always the danger of paint seeping underneath your mask. Rather than press too hard on your mask (possibly lifting previous color) you can seal the mask very easily with a quick shot of clear. That way, any seepage underneath the mask is clear. Let it dry, spray next color. Easy.
TankManNick
KitMaker: 551 posts
Armorama: 543 posts
Posted: Tuesday, January 14, 2020 - 06:41 AM UTC
Of course it is also likely that the real thing was hand painted (though you may still want to use masking on a model).
TopSmith
KitMaker: 1,742 posts
Armorama: 1,658 posts
Posted: Tuesday, January 14, 2020 - 02:12 PM UTC
I to found that spraying a coat of clear on the tape edges helped with paint bleeding under the masking tape.
Tankrider
KitMaker: 1,280 posts
Armorama: 1,208 posts
Posted: Wednesday, January 15, 2020 - 04:13 AM UTC
Sounds like someone has been watching HGTV...
Great Tip Rob, I will be using that tonight as I start applying the Caunter scheme to a Meng Rolls Royce Armored Car model.
Posted: Wednesday, January 15, 2020 - 06:01 AM UTC
I will certainly look forward to seeing that.
wildbill426
KitMaker: 403 posts
Armorama: 375 posts
Posted: Thursday, May 07, 2020 - 03:08 AM UTC
Hi Rory:
I wanted to thank you for your advice. I'm just finishing my Matilda, and I did what you said on the masking. It came out so well that I didn't bother to do any touch up painting; it really wasn't necessary. I'll be remembering your advice for future projects as well. By the way, I really enjoyed this kit; what a pleasure to build, and I really like the figures as well.
Namabiiru
#399
Rhode Island, United States
KitMaker: 2,888 posts
Armorama: 1,920 posts
Posted: Thursday, May 07, 2020 - 04:08 AM UTC
The variation on that idea which I learned from an aircraft modeler was to respray the previous color after putting down the mask.
