Meng PLZ05 Build Log
morcmarc
KitMaker: 6 posts
Armorama: 6 posts
Posted: Friday, February 07, 2020 - 08:29 AM UTC
Meng PLZ05 (TS-022)
First impressions
Opening the box reveals not huge amount of sprues, a metal barrel, polycaps, a sprue of clear parts, decals and two sheets of photo-etched brass all in individual bags.
Instructions are clear, colour callouts are for Vallejo only so have a conversion chart ready for other brands (I’ll be using mr hobby aqueous). Painting guide is for three versions.
Details are crisp, sharp even on small parts however there’s a considerable amount of flash and moulding lines on some of the sprues which can be awkward to clean up properly. The other noticeable feature of this and other Meng kits is the generous use of release agent. Therefore a warm, soapy bath before assembly is highly recommended.
Decals are nice and in-register.
The build
Instructions recommend to start with the road wheels and tracks... let’s not ruin all the fun so early.
I’ve started assembly with the lower hull and suspension arms:
One slight issue; the gates are quite thick and placed at a visible spot:
A sharp pair of cutters, a sanding stick and patience will be needed. The arms themselves fit nicely and the whole setup feels sturdy however:
I also noticed a few ejector pin marks on the bottom. I’ve decided to not to clean them up, because they are tiny and I’d lose the surface texture:
Next up, tow hooks, handles, and covers for the sprocket base:
There was not much else to do on the lower hull (ignoring the back) so I’ve moved on to upper hull. This part was mostly photoetch work. Details are nice however the brass is on the thicker side which makes bending some parts tricky. Upside is that mistakes are easily fixed and won’t break the piece. I also glued the upper hull to the lower at this point. I didn’t want to risk doing it later (as the instructions recommend) with all the small details in place.
This one was a nightmare to bend to shape (you can probably still see that it’s not a perfect fit but I’ve given up):
Installing lights and drivers hatch, then some more PE work. Kudos to Meng for including a jig:
Unfortunately I forgot to take photos of finishing the lower hull but this is what it looked like in the end:
Next, the gun (this is why you’re all here for . Dare I say the weakest part of the kit? Meng has included a metal barrel, however most parts to “decorate” it are plastic and they placed horrible ejector pin marks in places where it’s difficult to clean up but essential for a prefect fit. It took a lot of dry fitting and brute force to make it look acceptable. I’ll still probably have to go back and use filler
This is it so far. Enjoying the build despite of the hurdles. Parts all really well laid out, the whole upper and lower hull is 3 sprues basically (A, B, C) — looking at you miniart T-54. The amount of PE is just in my sweet spot as well, not too much, only used where it adds detail. Fits like Tamiya (for the most part).
