Armor/AFV: Allied - WWII
Thunder Models Scammell Tank Transporter
robw_uk
KitMaker: 1,218 posts
Armorama: 1,201 posts
Posted: Thursday, April 16, 2020 - 12:11 AM UTC
So, as the Matilda heads to be painted and the Type 16 awaits paint, I am starting my next build. This one will probably take me the rest of the year but hey, mad not to start it. I have a couple of reviews with some scratch build improvements I will look to try (nothing horrendous I think) but I still think I must be mad! 14 sprues, 1 clear sprue, 3 sheets of PE. The biggest build I will have attempted. Only problem is, at the moment I have the wrong radiator (manufacturing issue on initial run) and no response from Thunder Models as to whether that are still shipping the replacement..
This will be a North African theatre build so that the Matilda can be mounted on the back...
usual sprue box etc shots...
IMG_20200416_125431 by Robert Worth, on Flickr
IMG_20200416_125525 by Robert Worth, on Flickr
IMG_20200416_125542 by Robert Worth, on Flickr
IMG_20200416_125545 by Robert Worth, on Flickr
As I am waiting to hear on the radiator I thought I would start with the (simpler?) trailer...
philhendry
KitMaker: 57 posts
Armorama: 56 posts
Posted: Thursday, April 16, 2020 - 02:55 AM UTC
Looking forward to seeing you build this... I have one in the stash, along with some of Accurate Armour's 'extra' bits - tank tie-downs and the like.
robw_uk
Posted: Thursday, April 16, 2020 - 03:07 AM UTC
Cheers Phil. Do you have the part number for the Accurate Armour set? Need to make sure the Matilda is properly tied down
jon_a_its
KitMaker: 1,330 posts
Armorama: 1,132 posts
Posted: Thursday, April 16, 2020 - 03:23 AM UTC
THunder Models have a (slow) parts service here: http://www.thundermodel.com/Spare-parts-service.html
Top marks for actually making it available at all though.
My copy Part no 35200 already had it in the box.
Options
Bare Rad:
Scammell update set no. 1 for Thunder Model
Resicast | No. 35.2393 | 1:35
Covered Rad:
Scammell update set no. 2
Resicast | No. 35.2396 | 1:35
LZ Models make PE & Resin bits as well, & useful wheel assembly diagram
LZ Models
philhendry
KitMaker: 57 posts
Armorama: 56 posts
Posted: Thursday, April 16, 2020 - 03:59 AM UTC
A153 Tank Transporter Tie Set#1 WW2/Post War £13.00
robw_uk
Posted: Thursday, April 16, 2020 - 04:40 AM UTC
thanks both... seems AA aren't shipping tie-downs and the resicast radiator/detail set is not available in the UK so would need to import at an extortionate cost... will see if Thunder come good.
jfeenstra
KitMaker: 336 posts
Armorama: 336 posts
Posted: Thursday, April 16, 2020 - 05:27 AM UTC
A 3D printed replacement radiator is also available on Shapeways.
FarmerDave
KitMaker: 62 posts
Armorama: 62 posts
Posted: Thursday, April 16, 2020 - 08:39 AM UTC
Shes a complex beast alright. I advise double checking the fit of the cab onto the chassis before painting it. I had issues with the cab hitting bits of the winch and other items.
Lovely kit though.
robw_uk
Posted: Thursday, April 16, 2020 - 10:22 PM UTC
Lovely kit though.
thanks David. Leaving the tractor unit for now but would dry fit
OK, so started the trailer. The bed was very thin but with the first length-wise strut it has firmed up. Wheels done as well (plastic is fairly brittle so not looking forward to some of the fiddly bits and there are some large sprue gates & pour nubs around)..
IMG_20200416_210042 by Robert Worth, on Flickr
IMG_20200416_210034 by Robert Worth, on Flickr
and with her payload on... hope i can do both kits justice
IMG_20200417_105744 by Robert Worth, on Flickr
robw_uk
Posted: Saturday, April 18, 2020 - 02:24 AM UTC
rigidity achieved. Nothing really challenging at this part apart from he which at the front which was a tad fiddly
IMG_20200418_152051 by Robert Worth, on Flickr
and of course with payload
IMG_20200418_152040 by Robert Worth, on Flickr
petbat
KitMaker: 3,318 posts
Armorama: 3,093 posts
Posted: Saturday, April 18, 2020 - 09:14 AM UTC
I am not sure what the current situation for you guys is, but Australia has suspended receipt of mail from several countries.
However, when I ordered the radiator part for my kit last year, I got no communication back from Thunder but it came within 5 days of order..... I hope you get yours just as quick.
robw_uk
Posted: Saturday, April 18, 2020 - 09:25 AM UTC
We are in lockdown but not sure how that affects international post. I am in communication with them around delivery time - think they had some sourced in the UK when the kit was first released
robw_uk
Posted: Sunday, April 19, 2020 - 04:23 AM UTC
OK, so more progress. Ramp in progress (just dry fitted to the trailer bed at the moment). a few little gaps but they are filled. Should've read the instructions as there are 2 pieces that go on either side of the bed under the bogies - just manged to get them in place and gaps filled - would've been much easier to fit before the bogies (as the instructions told me)!!!!
IMG_20200419_170437 by
IMG_20200419_170430
IMG_20200419_170605
IMG_20200419_170548
robw_uk
Posted: Monday, April 20, 2020 - 09:35 PM UTC
Thunder Models confirmed any replacement radiator would be after COVID situation clears up. Not sure whether to go with the wrong radiator or to wait (and probably start something new)
Vodnik
Warszawa, Poland
KitMaker: 4,342 posts
Armorama: 3,938 posts
Posted: Monday, April 20, 2020 - 09:55 PM UTC
It is indeed, my design.
https://www.shapeways.com/product/TE6EJJXA2/replacement-radiator-for-thunder-models-scammell-p?optionId=64194974&li=shops
jon_a_its
Posted: Monday, April 20, 2020 - 10:03 PM UTC
I'm not sure if they corrected the sprue part, other than including a separate part in the box, might be worth checking the sprues.
The corrected part 'W' shaped find has 7 fins closely spaced, the old part has 6 spaced fins.
[EDIT: I don't know if different models of the Scammel, (Arty tractor, etc.), had different styles of fins on the radiator]
robw_uk
Posted: Monday, April 20, 2020 - 10:22 PM UTC
nice... problem with Shapeways is that it costs more to ship to the UK than the piece itself ;-)
robw_uk
Posted: Tuesday, April 21, 2020 - 06:26 PM UTC
Some small bits on the underside now added
IMG_20200422_071728 by Robert Worth, on Flickr
IMG_20200422_071704 by Robert Worth, on Flickr
2020-04-22_07-23-57 by Robert Worth, on Flickr
robw_uk
Posted: Wednesday, April 22, 2020 - 05:46 AM UTC
Erm, seem to have finished the trailer apart from 1 piece of PE. Still amazed how easily it went together, am sure the tractor unit will need more time but that is awaiting the correct radiator so could be months. Wont paint this until the tractor is done.
IMG_20200422_183543 by Robert Worth, on Flickr
IMG_20200422_183536 by Robert Worth, on Flickr
IMG_20200422_183608 by Robert Worth, on Flickr
IMG_20200422_183551 by Robert Worth, on Flickr
IMG_20200422_183558 by Robert Worth, on Flickr
petbat
Posted: Wednesday, April 22, 2020 - 07:53 AM UTC
Looks great Rob.
Personally I would wait for the replacement radiator before finishing the combo, as it is a noticeable difference, but build it as you want and enjoy.
robw_uk
Posted: Wednesday, April 22, 2020 - 08:47 AM UTC
Looks great Rob.
yeah am waiting - mostly as it is blatantly obvious right at the front of the tractor and, as the trailer looks so good I want to do my best work
robw_uk
Posted: Saturday, September 19, 2020 - 03:28 AM UTC
have dusted this one off. Still waiting to see if TM can provide a replacement radiator - if not am going to do a sand "cover" which I would want to use to stop sand/dust clogging the engine during a sandstorm (no proof this was ever done but sounds feasible)
An engine... 27 pieces and still a few more (plus some very small PE). I am going to hold off using the radiator as long as I can just in case TM confirm they can get me one (there are enough components I can build up in the cab to give them a few weeks)...
cheyenne
KitMaker: 2,184 posts
Armorama: 1,812 posts
Posted: Saturday, September 19, 2020 - 12:22 PM UTC
Beautiful work so far Robert !!
robw_uk
Posted: Sunday, September 20, 2020 - 03:43 AM UTC
still waiting to hear from TM if they will provide a replacement, the Shapeways one looks good but a little expensive...
it has a lot of smaller parts BUT on the whole goes together well (user error not withstanding). Think for the engine it calls out either the grey/blue or base vehicle colour (ie sand)... Quite like the idea of the blue if it is accurate...
anyway today's build completed the engine (barring small PE bits) and started on the chassis.  Didn't attempt steering, too much of a wimp  (engine just dry fitted for now)
I did find a couple of magically appearing pieces within the engine build. After much searching I believe this is correct:
robw_uk
Posted: Monday, September 21, 2020 - 06:42 AM UTC
More small components... ordered the recommended blue paint (think it will do for the SU-122 ans T-54-2 builds planned for latter - think their interiors have a blue part or two) but need to work out if I paint the engine now then look to fit and, if I do, how to mask when I paint the chassis etc
