Removing decals
T-55A5
KitMaker: 493 posts
Armorama: 68 posts
Posted: Monday, April 27, 2020 - 03:25 PM UTC
I'm redoing a old T-55 and a aircraft and I need to remove the decals from them
I have tried tape, but it takes the paint off which I want to save
Is there a way to remove the decals without taking the paint with it
Billy
Matty-man
KitMaker: 5 posts
Armorama: 1 posts
Posted: Monday, April 27, 2020 - 11:54 PM UTC
I have never tried it, but my bottle of Microscale Micro Sol says it can be used to soften old decals that have not been overcoated so that they can be peeled or brushed off.
Jedite
KitMaker: 44 posts
Armorama: 21 posts
Posted: Tuesday, April 28, 2020 - 01:15 AM UTC
I recently done decal removal.
I used decal fix and water to soften the decals up. After that with a cotton bud started gently rubbing the edge inwards then gently peel it off after the edge started to come up.
Grauwolf
#084
KitMaker: 2,485 posts
Armorama: 743 posts
Posted: Tuesday, April 28, 2020 - 06:23 AM UTC
If there is no raised detail under the decals and it has been overcoated,
you can try wet sanding with extreme fine grit sandpaper, be gentle, not
too much pressure as you sand.
I have done this many times without issues.
barnslayer
KitMaker: 102 posts
Armorama: 102 posts
Posted: Tuesday, April 28, 2020 - 06:38 AM UTC
Did you coat the decals with clear flat?
T-55A5
KitMaker: 493 posts
Armorama: 68 posts
Posted: Tuesday, April 28, 2020 - 10:09 AM UTC
decal fix??
Billy
T-55A5
KitMaker: 493 posts
Armorama: 68 posts
No
Billy
barnslayer
KitMaker: 102 posts
Armorama: 102 posts
Posted: Tuesday, April 28, 2020 - 10:58 AM UTC
No
Billy
Good. Go with decal softener or try very warm water on a cotton swab or large paintbrush.
Jedite
KitMaker: 44 posts
Armorama: 21 posts
Posted: Tuesday, April 28, 2020 - 08:25 PM UTC
decal fix??
Billy
I use Ammo's decal set and fix and what I found is that the fix solution softens them up and gets them wrinkly.
