Bushmaster PMV - 1/16 experiment.
2805662
KitMaker: 546 posts
Armorama: 541 posts
Posted: Monday, July 06, 2020 - 07:23 AM UTC
Gluing & clamping the lower hull:
Thanks for checking in.
terminators
France
KitMaker: 1,932 posts
Armorama: 1,907 posts
Posted: Monday, July 06, 2020 - 10:16 AM UTC
Interesting built. A lot of design work !
What the material used for the printed parts ?
2805662
KitMaker: 546 posts
Armorama: 541 posts
Posted: Monday, July 06, 2020 - 06:58 PM UTC
Thanks Alex.
The filament is PLA (Polylactic Acid) which is a thermoplastic polymer. Goes in the print head at 1.75mm, extruded though the 0.4mm nozzle.
knewton
New Zealand
KitMaker: 1,217 posts
Armorama: 1,092 posts
Posted: Wednesday, July 08, 2020 - 09:34 PM UTC
Great work, GK; a whole lot more interesting now NZ brought this vehicle.
2805662
KitMaker: 546 posts
Armorama: 541 posts
Posted: Wednesday, July 08, 2020 - 11:42 PM UTC
Cheers, Kylie. Your new trucks look pretty sweet - a lot nicer than the earlier generation. Apparently your guys from the Group had borrowed some, but I only heard that claim today.
2805662
KitMaker: 546 posts
Armorama: 541 posts
Posted: Thursday, July 09, 2020 - 06:35 PM UTC
Moving on to the front of the engine compartment, it’s time for the upper & lower engine grills:
Upper:
Lower:
knewton
New Zealand
Posted: Thursday, July 09, 2020 - 08:05 PM UTC
I’ll find out tomorrow night when I catch up with a couple of them. I’ve seen we’re going for overall sand; clearly someone put a lot of thought into that.
2805662
KitMaker: 546 posts
Armorama: 541 posts
Posted: Monday, July 13, 2020 - 09:42 PM UTC
One of the side effects of learning as you’re designing is the error rate is high. A review of the bottom of the engine bay revealed that it wasn’t wide enough at the top. So, as I redrew it, I added some additional details.
There may be some redesign of the front end required.
Golikell
Noord-Holland, Netherlands
KitMaker: 1,757 posts
Armorama: 914 posts
Posted: Monday, July 13, 2020 - 10:32 PM UTC
This really an awesome project mate, and not for the faint hearted! I'd love to have a (resin) 3d printer, but SWMO and the bank won't let me... Curious how this will turn out...
2805662
KitMaker: 546 posts
Armorama: 541 posts
Posted: Friday, July 17, 2020 - 03:34 PM UTC
Thanks, Erwin. Resin printers & their materials can be pretty pricey. I don’t think I could do a project of this size on a resin printer, just from a cost perspective.
The front end redesign continues.
2805662
KitMaker: 546 posts
Armorama: 541 posts
Posted: Saturday, July 25, 2020 - 04:32 AM UTC
As I’m building the combat Winnebago closed up, I’m only adding enough detail to it to give the impression of what’s there, not going nuts. The seat frames on the 1:1 are pretty involved structures, which is represented by the recesses on otherwise solid blocks, here.
2805662
KitMaker: 546 posts
Armorama: 541 posts
Posted: Sunday, July 26, 2020 - 01:00 AM UTC
Added some more detail to the driver’s & commander’s stations, forward, as well as an approximation of the radio rack in the rear compartment.
2805662
KitMaker: 546 posts
Armorama: 541 posts
Posted: Sunday, July 26, 2020 - 08:15 AM UTC
Thought I’d post a comparison between the current interior design compared to the initial design. More detail & more refined, more accurate, detail.
2805662
KitMaker: 546 posts
Armorama: 541 posts
Posted: Monday, July 27, 2020 - 11:18 PM UTC
Waiting for some spare parts for the printer has helped enable (force?) more work on the redesign.
New upper hull:
Finished the rear compartment, less seats (lots of copy/paste there):
With international shipping being what it is, I’ve probably got two more weeks to refine the design.
2805662
KitMaker: 546 posts
Armorama: 541 posts
Posted: Wednesday, July 29, 2020 - 09:15 PM UTC
Mostly finished the upper hull:
Added air conditioning ducting to the hull ceiling. First half:
The rest:
Running out of excuses to redo the front on the hull for the fourth time!
2805662
KitMaker: 546 posts
Armorama: 541 posts
Posted: Saturday, August 01, 2020 - 06:53 AM UTC
Work continues.
Ongoing fit checks should avoid some of the mismatches I’ve generated to date.
Almost done with the latest - & hopefully last - iteration of the front end.
2805662
KitMaker: 546 posts
Armorama: 541 posts
Posted: Tuesday, August 04, 2020 - 05:07 AM UTC
Finally finished the redesign of the front of the truck.
And a comparison between the first & current version.
2805662
KitMaker: 546 posts
Armorama: 541 posts
Posted: Saturday, August 08, 2020 - 12:10 PM UTC
With work ramping up, time has become a little tight!
Simple projects, like wheel hubs, are simple & quick.
Step 1: draw the cross section of the hub.
Step 2: rotate the section around the axis & add whatever detail is required.
Tyres will be sourced from the Trumpeter 1/16 M-ATV kit.
jon_a_its
KitMaker: 1,336 posts
Armorama: 1,137 posts
Posted: Saturday, August 08, 2020 - 08:11 PM UTC
Astounding work, far past my own small efforts in CAD
2805662
KitMaker: 546 posts
Armorama: 541 posts
Posted: Saturday, August 08, 2020 - 11:14 PM UTC
Thanks, Jon. Very slow learning on my behalf, but getting there.
2805662
KitMaker: 546 posts
Armorama: 541 posts
Posted: Monday, August 10, 2020 - 11:56 PM UTC
Realised I hadn’t posted the seat back models for the interior.
2805662
KitMaker: 546 posts
Armorama: 541 posts
Posted: Monday, August 17, 2020 - 09:36 PM UTC
Moving on to the stowage redesign. Thought I’d add alignment tabs to the hull and recesses in the bins themselves.
The rearmost stowage bin is for the DUKE electronic countermeasures.
2805662
KitMaker: 546 posts
Armorama: 541 posts
Posted: Tuesday, August 18, 2020 - 05:30 PM UTC
Switched to the right side of the vehicle. Some tricky geometry that needs to be sorted before adding detail.
Also added the underside detail.
As well as the alignment recesses.
Just have to add the battery box to the rear.
2805662
KitMaker: 546 posts
Armorama: 541 posts
Posted: Wednesday, August 26, 2020 - 11:01 PM UTC
Gathered up all of the prototype pieces on one spot. Wow. A lot of trial and error!
The clean sheet “real” model is up to 271 hours, so far. Will spend the weekend cleaning up & gluing to show actual progress.
2805662
KitMaker: 546 posts
Armorama: 541 posts
Posted: Sunday, August 30, 2020 - 04:13 PM UTC
Some actual progress.
