Bushmaster PMV - 1/16 experiment.
jon_a_its
KitMaker: 1,335 posts
Armorama: 1,136 posts
Posted: Sunday, August 30, 2020 - 11:23 PM UTC
impressive work
2805662
KitMaker: 546 posts
Armorama: 541 posts
Posted: Monday, August 31, 2020 - 05:17 AM UTC
impressive work
Thanks, Jon. Lots of work to get it to this stage.
2805662
KitMaker: 546 posts
Armorama: 541 posts
Posted: Tuesday, September 01, 2020 - 07:47 AM UTC
Most of the work now will be sanding & priming, so that’ll be fun.
In the meantime, the base for the remote weapon station - known as the Protected Weapon Station (PWS) or the EOS R-400 - was CAD’d up. More work to come on this one: it replaces the normally-fitted gun ring.
2805662
KitMaker: 546 posts
Armorama: 541 posts
Posted: Tuesday, September 01, 2020 - 10:19 PM UTC
Slight tweak:
2805662
KitMaker: 546 posts
Armorama: 541 posts
Posted: Friday, September 04, 2020 - 12:24 PM UTC
Using this mishap as a reference (everybody unhurt, thankfully)...
I detailed the underside of the stowage bins:
Some cleanup to go, but progress nonetheless.
2805662
KitMaker: 546 posts
Armorama: 541 posts
Posted: Thursday, September 10, 2020 - 10:56 AM UTC
Some pretty significant progress over the last fortnight.
Was put onto a new glue that welds PLA together.
Started on the fuel cell & battery box:
Finished up gluing the major components of the lower hull:
Lastly, some consumables for the incoming newer & larger printer arrived. Check out the size difference between the current print area (small black mat) & the new print area (enormous black mat). Will definitely speed things up!
2805662
KitMaker: 546 posts
Armorama: 541 posts
Posted: Monday, September 28, 2020 - 09:07 AM UTC
There’s been a bit of progress thanks to the new & significantly larger printer. Fewer pieces reduces the chance of inducing tolerance errors, but makes print times a lot longer.
The first print was 182 hours - over a week! That meant that the upper hull could be printed in a single piece. Fresh off the printer, complete with some print defects.
Still, starting to look good with some clean up.
Version 2 is also a lot better than version 1.
With more interior detail & better overall shape & look.
And the error that made me restart the entire design.
An error of 4.5mm. Ouch.
2805662
KitMaker: 546 posts
Armorama: 541 posts
Posted: Sunday, October 04, 2020 - 07:29 AM UTC
Cleaned up the upper hull print & added anti-slip with Tamiya light sand textured paint.
Other side:
jon_a_its
Posted: Sunday, October 04, 2020 - 06:28 PM UTC
very interesting work!
Not.Jealous.at.all.b.t.w!
What are you using to smooth out the ridges?
I did some wings in PLA, Used Holts Knifing Putty (3M/Bondo) and Halfords (UK) primer, smoothed well, but after a week, it looked like crazy paving!
gibbo
KitMaker: 30 posts
Armorama: 30 posts
Posted: Sunday, October 04, 2020 - 06:46 PM UTC
Gee this is looking sweet!
Whats wpn is going in the PWS?
G
2805662
KitMaker: 546 posts
Armorama: 541 posts
Posted: Monday, October 05, 2020 - 02:59 PM UTC
G
G’day Gibbo,
50 cal QCB ftw.
2805662
KitMaker: 546 posts
Armorama: 541 posts
Posted: Friday, October 16, 2020 - 10:30 PM UTC
Link to the build on the new forums: https://forums.kitmaker.net/t/1-16-bushmaster-pmv-cad-3d-print-scratchbuild/666?u=2805662" TARGET="_blank"> https://forums.kitmaker.net/t/1-16-bushmaster-pmv-cad-3d-print-scratchbuild/666?u=2805662
